CLOSED. Kelford Cams for 1GR GB.
Discussion in 'Performance and Tuning' started by BillDaCat8, Jun 27, 2019.
  1. Jun 29, 2019 at 10:25 PM
    #161
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Rear mount only turbo kit, built by APR, for Balboa's close friend. Two problems arose. Torque was lower than the HP. HP was around 420-440. TQ was in the mid to upper 300's.
    Second problem was the stock engine blew. I believe the ring lands snap, crackle, popped, but cannot remember exactly. Too much boost, timing, and RPM for stock internals.
  2. Jun 29, 2019 at 10:27 PM
    #162
    ThomasMore66
    Dallas/Fort Worth & Durango
    Do you need to sleeve? Stock crank is good to 600 or so, right?
    Roostfactor, GT7 and Torspd like this.
  3. Jun 29, 2019 at 10:28 PM
    #163
    ThomasMore66
    Rocky?
  4. Jun 29, 2019 at 10:32 PM
    #164
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    @JustDSM must have deleted his question.
    Do you think you remember who he is?
  5. Jun 29, 2019 at 10:36 PM
    #165
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I wonder what power could be achieved with BC stroker kit, Darton MID bored to 98mm. 4.66 has a nice ring to it.
    White lightning boosted and GT7 like this.
  6. Jun 29, 2019 at 10:36 PM
    #166
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Shhh you always do this
  7. Jun 29, 2019 at 10:37 PM
    #167
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I did. That’s personal info, I figured I’d keep it off the board.
    The reason I asked was I had seen a post on HPTuners Facebook a about a guy in Houston saying if HPT was available back in the day, he might have been able to sell his “kits”. I’m assuming some turbo setup. Wondered if it was this Balboa dude.
    GT7 likes this.
  8. Jun 29, 2019 at 10:40 PM
    #168
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I always start making these lists. The cost of parts alone gets to 5 figures in a hurry.
    GT7[QUOTED] likes this.
  9. Jun 29, 2019 at 10:56 PM
    #169
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Too much on the over bore. If I combined both engines, they still wouldn't add up to 4.66L. I don't know how BC came up with that value, but I know Cometic was reluctant to make head gaskets for me with what I had machined the bore to. The machinist was even complaining about the boring to what I had chosen.
  10. Jun 29, 2019 at 11:02 PM
    #170
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Probably another guy. As arrogant and "first" as he was, he was unfortunately still partly the puppet of a puppeteer. He didn't make anything to sell. He used his influence to get things to market. His influence stemmed from his excitement to try new things. That is where he was taken advantage of. Never sold any parts or kits though. One of his best accomplishments was helping bring the T56 swap to market.
    HPTuners back then would still have had issues. The same encountered recently. MAF scaling limits, as well as load table limits.
  11. Jun 29, 2019 at 11:04 PM
    #171
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    What for a 10%+ off all BC parts sale, from some vendor. ;) That's what I did for my crank. :D
  12. Jun 29, 2019 at 11:05 PM
    #172
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Darton says 900-400 OD is 4.29” / 108mm what is the biggest you could go?
    https://dartonsleeves.com/mid_07.html
  13. Jun 29, 2019 at 11:07 PM
    #173
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    So then it comes back to the limitations of the head gaskets available. Which then takes you to a custom copper head gasket. Which can be made fairly easily.
  14. Jun 29, 2019 at 11:07 PM
    #174
    JustDSM
    Justin
    Ogden, UT
    I really appreciate the history lesson there. The "old school" stuff the X-Runners were up too intrigues me. Just like learning about how things got to where they are now.
    Roostfactor and Torspd[QUOTED] like this.
  15. Jun 29, 2019 at 11:07 PM
    #175
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    So you’re running BC crank with your original Pauter rods? What pistons?
  16. Jun 29, 2019 at 11:09 PM
    #176
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    We did stuff years ahead of what is taking place here now. Took a lot of long rentless years of effort to get those minds changed here.
    Roostfactor likes this.
  17. Jun 29, 2019 at 11:13 PM
    #177
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Had Pauter Rods. Now CP Carrillo Rods. With CP pistons as well. The Pauter or BC Rods clear the oil squirters without issue. The CP Carrillo rods require a lot of massaging of the squirters. Very time consuming and tedious. The are the strongest on the market though. With a matching price. ~$2200.
    Most affordable rods are the Molnar and Brian Crower rods.
    Roostfactor and Hawk373 like this.
  18. Jun 29, 2019 at 11:15 PM
    #178
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Is there anyone trusted in Houston that can install Darton MID sleeves?
  19. Jun 29, 2019 at 11:16 PM
    #179
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Possible where my engines were built. H Squared Racing Engines.
    Roostfactor, DiamondW and loginfailed like this.
  20. Jun 30, 2019 at 5:24 AM
    #180
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
