Clunk noise when reversing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CuseFan, Apr 22, 2014.
  1. Dec 11, 2018 at 9:49 AM
    #41
    limited2015
    limited2015 Member
    Andris
    Lake Placid NY
    Limited
    I had this issue and it ended up being the breaks
    Fight4Function and BillsSR5 like this.
  2. Dec 11, 2018 at 11:50 AM
    #42
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap AC drip line mod
    Ah, I'll see if those need tightening
  3. Dec 11, 2018 at 7:30 PM
    #43
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Brakes.
    2009Access4x4 and Satxoi like this.
  4. Dec 30, 2018 at 10:39 AM
    #44
    melforest
    melforest Member
    2011 Red Tacoma 4WD manual
    maybe I'll send my kid under mine. I bought my 11 new and on one of the early free oil changes asked about that clunk. Has ALWAYS done it. They told me everything looked fine. It still does it. I have not lost anything yet ;)
  5. Dec 30, 2018 at 12:33 PM
    #45
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    That would be the bolts that attach the rear leafs to the rear axle itself.
  6. May 29, 2019 at 12:57 PM
    #46
    Nikolav1990
    Nikolav1990 Well-Known Member
    Niko
    Magog, QC, Canada
    2018 toyota tacoma sr5 access cab automatic 2.7
    Hey guys i know this is old thread but i had a front end and rear end clunk or pop nose when reversing and going forward, after i got my 3 inch bilstein lift installed. The problem was my front lca bolt when not tight enough and the bushing was popping into place, and also my rear leaf spring u bolt were not tight enough causing another popping or clunk noise. Now its fixed just like new
    2009Access4x4 and IanR561 like this.
  7. Jan 5, 2021 at 5:30 PM
    #47
    Jaybuilt
    Jaybuilt New Member
    Rolando
    2018 Toyota Tacoma trd sport
    3”x2.5” lift kit
    I know this is an old thread but I had the same issue on my 3rd gen Tacoma so I had my wife drive it forward and reversed. I found that the LCA bushing would move forward and back. So I re torqued it down but was still making that noise very slightly. So I sprayed it with a lot of degreaser on both bushing and on both side than hosed it down after I let it dry for a couple of hours and the clunk is gone. I hope this helps
    2009Access4x4 likes this.
  8. Jan 5, 2021 at 7:46 PM
    #48
    Fight4Function
    Fight4Function Slightly Mutant
    G
    SF Bay Area
    2014 DC TRD OR
    Seems like there are few possible sources to this elusive clunk. I just wanted to update that I changed my front rotors and pads about 12 months ago @ 88Kmiles (because they were worn out -- not because of the clunk) and I haven't heard the clunk since. I was fairly confident that my clunk was coming from within the brake and eventually replacing them is what fixed it for me.
    2009Access4x4 and Jaybuilt like this.
