clutch disengeing issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by turtle142, Nov 17, 2021.
  1. Nov 17, 2021 at 8:44 PM
    turtle142
    turtle142 [OP] Active Member
    Rob
    Tacoma
    Pull my engine about 3 weeks ago and but in a new clutch and pressure plate.
    Few days after the transmission wasn't dissengageing property, (rolling forward on start up with the clutch in)
    Replaced the slave and master cylindes. But still no luck
    found out that a bolt was missing out of thr transmission and that was causing the issue.
    Last week it started doin it again, 2 more bolts where loose in the bell housing.
    Last night it stared doing it for a 3rd time. As this point i guess its time to pull the transmission. All the bolts are tight on the bell and the slave is blead.
    Any ideas on anything else to check before ripping the trans out? Any thoughts on what it could be? Bad throw out/ pressure plate?
  2. Nov 17, 2021 at 9:42 PM
    Glamisman
    Glamisman Well-Known Member
    IIRC if it is a 3.4 the disc installs with the offset towards the flywheel and not towards the pressure plate.
  3. Nov 17, 2021 at 10:06 PM
    turtle142
    Rob
    Tacoma
    Are you saying the clutch may be in backwards?
  4. Nov 17, 2021 at 10:20 PM
    Glamisman
    Yes possibly. Timmah the toolman has a 2 part video on clutch replacement.
  5. Nov 18, 2021 at 11:24 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    This happens even with the parking brake Applied ??
    Flat ground no slope at all ??
    If you step on the brake does the engine stall??
  6. Nov 18, 2021 at 12:07 PM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 180k
    881/5100/Dakars 4R wheels / TBU / New frame
    This seems to be an issue with the Aisin clutch kit. Read some of the reviews on the Amazon page and it gets really unclear:
    https://www.amazon.com/Aisin-CKT-040-Clutch-Kit/dp/B00340FETK/
    This guy seems to be saying the opposite though:
    I feel like there was a thread on here a few weeks/months ago where someone had a shop do a clutch job and they installed the clutch disc incorrectly.
  7. Nov 19, 2021 at 7:19 AM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    If you drop the tranny again, make sure you check the clutch fork for cracks.
