Clutch Fluid Reservoir
Discussion in '2nd Gen. Tacomas (2005-2015)' started by papabear050, May 12, 2009.
  1. May 13, 2009 at 12:20 AM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    As far as I know, the above is how it goes. Lack of fluid or air in your lines, you are screwed. I've experienced air in my brake lines due to a leak and the brake pedal was almost completely useless. Lucky I wasn't going very fast that the e-brake stopped the car. On another experience, lack of pressure or fluid flowing through the clutch line render the clutch useless also. Clutch either stayed on the floor or depressing it did absolutely nothing.
  2. May 13, 2009 at 8:05 AM
    papabear050
    papabear050 [OP] Well-Known Member
    11 dc 4x4 TRD OR Auto
    Seems like a safety feature fail to me.
    Looks like the 09's have the seperate clutch resevoir.
  3. May 19, 2009 at 9:48 AM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    The reservoir is separated by a divider. You fill both at the same time, but once down to a certain level, you only loose fluid on one side.
  4. May 19, 2009 at 9:50 AM
    drew02a
    San Antonio, TX
    Also, in the 2nd Gen Tacomas, you'll only have a separate reservoir for the clutch if you have VSC.
  5. Dec 7, 2012 at 3:24 PM
    iamjoealex
    iamjoealex Member
    joey
    new Bedford ma.
    12 trd sport dcsb
    i got a 12 no clutch fluid res
  6. Dec 7, 2012 at 3:30 PM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I have not really examined under the hood of the 12/13's. Toyota makes mini changes all the time. The only thing I've noticed from the new ones I've seen are ethe extra smog device by the airbox.
  7. Dec 7, 2012 at 3:44 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    You sure? I've seen a combined fluid reservoir. Can't recall what it was on though.
  8. Dec 7, 2012 at 4:09 PM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    The ones I've had were always separate but apparently our trucks does have combined depending on the year and if you have vsc. My 09 was separate.
  9. Dec 7, 2012 at 4:36 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    The clutch fluid pickup is above the min. level in the brake cylinder very common practice.
  10. Jan 29, 2013 at 3:30 PM
    theobserver
    theobserver Member
    Everett, WA
    06 Tacoma 4x4
    What year Tacoma is picture of?
  11. Jan 29, 2013 at 3:38 PM
    theobserver
    theobserver Member
    Everett, WA
    06 Tacoma 4x4
    What year and model is thumbnail picture of?
  12. Jan 29, 2013 at 3:57 PM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Which thumbnail picture are you referring to? Gold one is of a 1st gen and white one is a 2009 DCSB 4x4 TRD OR 6speed.
  13. Jan 29, 2013 at 7:17 PM
    theobserver
    theobserver Member
    Everett, WA
    06 Tacoma 4x4
    I meant the thumbnail pic on the first page of the engine compartment pointing to the clutch reservoir. The truck appears to be white.
  14. Jan 29, 2013 at 7:27 PM
    HighTQCummins
    HighTQCummins Instagram: stormtrooptaco
    Hank
    SE PA
    '12 SW DCSB Sport
    5% all around, derp'd wheels, FMS40, 30" E-Series, 55w 6k bi's, 35w 5k fogs
    the resivoir is certainly not there on the '12s. I just put my sPOD right in that same spot on the inner fender well. It must be combined together. I guess i'll take a look next time i swing the hood open
    Nwasbotten likes this.
  15. Jan 30, 2013 at 3:26 PM
    #35
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    They're both in the first page :D The one with the label "clutch reservoir" is indeed white and the 09 DSCB TRD 4x4 6 speed.
  16. Jan 30, 2013 at 3:28 PM
    #36
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I'm assuming the separation is only on the off road model as they have A-trac so they want to keep the brake fluid separte from the clutch fluid.
  17. Jan 31, 2013 at 11:48 AM
    #37
    theobserver
    theobserver Member
    Everett, WA
    06 Tacoma 4x4
    What I was trying to determine was the year and model of:
    The one with the label "clutch reservoir" ( white engine compartment )
  18. Jan 31, 2013 at 12:31 PM
    #38
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    See post 32. 2009 DSCB Off Road 4x4 6speed.
  19. Feb 1, 2013 at 10:41 AM
    #39
    theobserver
    theobserver Member
    Everett, WA
    06 Tacoma 4x4
    Gotcha. Thank you
  20. Jul 26, 2013 at 9:55 AM
    #40
    13TRDsport
    13TRDsport Well-Known Member
    NE PA
    13 Access cab TRD Sport
    Aero Turbine 2525XL, K&N air filter, TRD Shift knob. Bilstein 5100's w\Eibach springs.
    I have vsc and no seperate resevoir....
