Clutch Fluid Reservoir
Discussion in '2nd Gen. Tacomas (2005-2015)' started by papabear050, May 12, 2009.
  1. Mar 29, 2016 at 8:32 AM
    #41
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    My 2008 has a shared reservoir, V6, no VSC. Has anyone converted their shared setup to use a separate reservoir for the clutch? I don't know that it matter and if it's worth it, just wondering what-if. Seems like just a matter of getting the reservoir and plumbing.
  2. May 5, 2018 at 7:25 AM
    #42
    Hacktacular
    Hacktacular Well-Known Member
    Robert
    2010 Tacoma X-Runner Turbo
    800cc Siemens/Deka Injectors URD Fuel Pump Upgrade Haltech Elite 2500 Custom Power Fab Precision Turbo 6676 @8 PSI 3" Custom Exhaust from turbo out
    I know this is old but I am trying to track down the reservoir in the photo here. I cannot find it on toyota parts sites at all.
    Can you tell me the year of the truck in the pic and possibly the last 8 of the VIN?
  3. May 10, 2018 at 3:43 PM
    #43
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Sure thing. It's a 2009. Here's the whole VIN - 5TEWN72N63Z164211
    2008 and older has no separate reservoir and shares with the brake.
  4. May 10, 2018 at 3:56 PM
    #44
    Hacktacular
    Robert
    Thank you sir!I have a 2010 Xrunner and it shares the master. Not sure what different about yours. Is this a 4x4? What model is this?
  5. May 10, 2018 at 4:00 PM
    #45
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    5TEWN72N63Z164211 would be a 10/2002 production Tacoma I think?
    Anyway, I believe the remote clutch master reservoir would be 31402-20160.
    Bracket is 31408-60010, there's a couple of hoses, cap, float, etc, too.
    I have a 10/2007 production and it's got the shared brake/clutch reservoir. I think the difference is if you have VSC with the electric brake booster. I have the old school vacuum booster.
  6. May 10, 2018 at 5:41 PM
    #46
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Yes, it is 4x4. The difference is that only the Off-Road model got the A-TRAC which has the accumulator/brake booster so the rest of the model line up did not get it. What I didn't know is that since it has accumulator/booster, it got a separate clutch reservoir.
    Hacktacular[QUOTED] likes this.
  7. May 10, 2018 at 8:21 PM
    #47
    Hacktacular
    Robert
    I will be doing this so I can install a master cylinder upgrade to accommodate the rear disk conversion. I could have went motorcycle fluid reservoir but decided to make it look factory.
  8. Apr 13, 2021 at 6:21 PM
    #48
    Nwasbotten
    Nwasbotten Member
    Nic
    Minnesnowta
    2012 Black Tacoma V6 Access Cab
    I also have a 12 v6 and I am not seeing a clutch fluid res
  9. Apr 14, 2021 at 11:28 AM
    #49
    Taco'09
    Taco'09 Well-Known Member
    It is not part of the brake fluid reservoir but a rather smallish thing mounted underhood on the driver's side fender adjacent to the big fuse box.
  10. Jul 25, 2023 at 9:31 AM
    #50
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    Wow this is finally starting to make sense to me...
    My clutch is weeping in the cab from the master somewhere...
    AND my brake fluid was low a few weeks ago so I topped that off but could not figure out if my clutch fluid was low..
    SO now I see the reservoir is shared for the brakes and clutch and the brake light can also mean low "Clutch Fluid" :)
    Now I have to figure out the leak...
    shakerhood likes this.
  11. Dec 4, 2023 at 10:04 PM
    #51
    TreeFortRichard
    Brian
    Long ago update...this was a leak of the master cylinder behind the clutch pedal...I did a replacement with an after market METAL replacement...It's about a 4hr job if everything goes right...I had fluid all under my floor mat...that's where it was weeping...
    The hardest part is getting the hard line into the new master cylinder and threading it. .
  12. Dec 8, 2023 at 11:39 AM
    #52
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Reviving an older thread but anyone have the part number for the shared brake/clutch MC reservoir?
  13. Dec 8, 2023 at 12:09 PM
    #53
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    47201-04180 for 09 and up
  14. Dec 8, 2023 at 12:33 PM
    #54
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Awesome! Thanks for that. Looks like the whole MC assembly is 47201-04180 but searching off of that diagram, it looks like just the reservoir is 47220-0R050...at 90% of the cost.
    Also...was typing this and your S2 lights showed up at the door. They look great. Thanks for those, too.
    Strictlytoyz likes this.
  15. Dec 8, 2023 at 1:24 PM
    #55
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Ah, my bad didn't realize you wanted just the reservoir.
