clutch friction plate
Discussion in 'Performance and Tuning' started by bmur63, Oct 18, 2010.
  1. Oct 18, 2010 at 11:02 PM
    bmur63
    bmur63 [OP] New Member
    I have a 09 taco V6 4.0 L 4x4 6spd double cab that will not move with 37k on it. I was driving on the freeway and shifted to 5th at 70mph and i suddenly had no response. i shifted to 6 , and nothing. i pulled over to the shoulder and slowly shifted down to 1 and there was no effect. i can hear the shifter engaging the gear with or without the clutch pressed, but theres no spinning of the wheels? i was told it could be the clutch plate? any ideas on why i can shift into gear and have no movement?
  2. Oct 19, 2010 at 6:07 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    If the engine idles and revs and you cannot get the truck going, no matter what gear you shift in, the problem is most likely in the clutch, friction plate, flywheel or drive shaft. Check drive shaft first, if that looks intact, its most likely something in the bell housing. To find out what, you will have to most likely drop the transmission...
