Clutch Habits (Auto trans drivers plz don't vote)
Discussion in 'Technical Chat' started by gozar, Sep 5, 2009.
Coming to a stop
Poll closed Oct 5, 2009.
  1. Clutch in - Coasting while braking
    29 vote(s)
    27.1%
  2. Downshift
    57 vote(s)
    53.3%
  3. Clutch out 'til just before stopping
    21 vote(s)
    19.6%
  1. Sep 7, 2009 at 6:49 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    what do you mean by heel-toe shifting?
  2. Sep 7, 2009 at 6:52 PM
    ttylerr
    Tyler
    09 MGM 4Banger 4x4
    sorry i worded that wrong, clutch pedal pressed with the tranny in gear can wear your clutch out faster if you re-engage in the wrong gear and overspeed the clutch... but thats not really what we're talking about so disregard my comment lol
  3. Sep 7, 2009 at 6:58 PM
    jfr02
    jfr02 Well-Known Member
    2012 dcsb 6spd sport
    i kinda thought thats what happened didn't mean come off shitty
  4. Sep 7, 2009 at 7:15 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    I usually downshift, going through every gear under the current one except for 1st
  5. Sep 8, 2009 at 3:47 AM
    MaineYota
    MaineYota Well-Known Member
    Portland, Maine, USA
    '05 SR5 Doublecab
    Soft tonneau, vent shades, tube steps, bed extender, and tacomaworld.com sticker
    It's a way of downshifting that let's you hit the brake pedal (to slow down) and the accelerator (to increase engine RPM to match the next lowest gear) at the same time.
    You use the right half of your right foot to take care of the gas, and the left half to take care of the brake. You push your foot down on the brake normally, but you "roll" your right foot to the right to blip the throttle for the rev-matching part.
  6. Sep 9, 2009 at 9:42 AM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    3. I just keep in gear say 5th-6th, truck will gradually slow down. Clutch in when close to a stop.
    From what I understand, with our trucks and many modern vehicles the throttle is closed with foot off the gas and in gear. Throttle is open when in neutral, so your burning fuel, and you lose braking from being in gear.
  7. Sep 11, 2009 at 3:05 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    In previous cars I would downshift along with braking thru 2nd, just not into 1st.
  8. Sep 11, 2009 at 4:11 PM
    bobwilson1977
    bobwilson1977 Well-Known Member
    KaliFORN-I-A
    96 Tacoma 2WD ( pizza delivery model)
    none except for crappy hub caps and floor mats.
    I downshift through all the gears, which I've been told puts unnecessary wear on the tranny. But I've been doing this for 225,000 miles and so far it is still in good shape.
  9. Sep 11, 2009 at 4:17 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Normally I wont do any of the above. I put the truck in neutral and release the clutch, which ends up causing less wear between the friction disk and flywheel since the two are in complete contact with eachother. Of course, many will probably say this is less safe in the even that someone was to come hauling ass behind you, but thats what situational awareness is for. I also do the same at red lights. Clutch out, and in neutral.
    The only time I will ever downshift is when the throttle is getting punched. Clutches cost much more than brakes.
  10. Sep 11, 2009 at 7:07 PM
    taco06
    taco06 Well-Known Member
    Alex
    pomona ,California
    06 sprt
    I can't let the wife know
    X2
  11. Sep 12, 2009 at 12:09 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    FYI - Coasting in gear shuts off the fuel, idling along uses about 1.5 -2 gallons per hour. I coast in gear, scangauge shows a big mileage increase this way.
  12. Sep 14, 2009 at 4:32 AM
    BMBIG
    BMBIG Active Member
    Bryan
    SE Mass
    '11 4X4 Access 4-Cyl
    I had been wondering if Tacoma's do this - interesting.
  13. Sep 15, 2009 at 5:02 PM
    Kappes03
    Kappes03 Legend of the UG
    Colorado
    2014 Tundra CM
    I always downshift, I grew up in the mountains and I have much more control then just putting in the clutch or coasting in nuetral. Plus what Isthatahemi said, better fuel milage keeping it in gear since it shuts off the fuel while coasting.
  14. Sep 29, 2009 at 11:24 PM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    #1 for me...brakes are cheaper than a new transmission or clutch.
  15. Sep 30, 2009 at 3:01 AM
    #35
    jfr02
    fuel does not get shut off if it did you would loose engine vaccum thus no brakes.while driving turn you truck off and see what happens.but do this while not on a busy road.only thing i found is fuel injector pulse width is reduced thats it.
  16. Sep 30, 2009 at 8:44 AM
    #36
    Outlaw
    Outlaw Well-Known Member
    Iowa City, Iowa
    2006 GX470
    Water Pump, Timing Belt, Sparkplugs, Plastidip Grill emblem
    It really depends on the situation. First rule, embedded in me by my father, is to not wear the clutch out. so I try to not ever hold the clutch in. Brake pads are cheaper to replace than a clutch.
    If i need to coast, then I just put it in neutral or leave in gear and gradually slow. If there is plenty of time to stop, then i gradually slow using brakes, and downshift. If coming to a complete stop quickly, after slowing by braking and downshifting, i put in neutral right before stopping. I was told that whether the vehicle is in gear or neutral, holding the clutch in will increase wear.
  17. Sep 30, 2009 at 10:11 AM
    #37
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16's
    In my old X-Runner I would just throw it in neutral and let it coast, apply brakes as needed.
  18. Oct 1, 2009 at 8:40 AM
    #38
    Demoncleaner
    Upstate NY
  19. Oct 1, 2009 at 8:50 AM
    #39
    t-com09
    t-com09 Well-Known Member
    Connecticut
    2010 single cab 4x4 sr5
    Bilstien 5100's yellow foglights toolbox pop n' lock
    i clutch in, pop it into nuetral then coast on the brakes to the light
  20. Oct 1, 2009 at 8:59 AM
    #40
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    X2, This is how I learned to drive.
