Clutch Issue?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Madjik_Man, May 15, 2013.
  1. May 16, 2013 at 5:06 PM
    Madjik_Man
    Madjik_Man [OP] The Rembrandt of Rattle Can
    Colorado Front Range
    We looked up my history on the truck... did the master cylinder 3 years ago.
    Not gonna touch it for now because that's a $125 part with my friend's discount.
  2. May 16, 2013 at 5:07 PM
    tacoma04
    tacoma04 Retired to the lake
    Bruce
    Tennessee
    2017 TRD OR DCSB BBP
    Good for you man. Wish I could get a discount:( Prices sound fine to me. Think about doing that rear main also, while it is easy to get to.
  3. May 16, 2013 at 5:09 PM
    Madjik_Man
    Yeah well I'm hoping it's just the slave cylinder that we replace in his driveway Saturday morning.
    If not, I have to start doing yoga now...so I can grab my ankles and grit my teeth for that $1000 hit.
  4. May 16, 2013 at 5:11 PM
    tacoma04
    Bruce
    Tennessee
    I know exactly how you feel and more....with the gearbox rebuild, my total was $2500. Had to replace all the bearings and two shafts. Those shafts are not cheap.
  5. May 16, 2013 at 5:18 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    The discounted parts WEAR OUT FAST- 3 years is not unusual.
    REBUILD KIT $300???????
    I will look--that is EXPENSIVE.
  6. May 16, 2013 at 5:25 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    Sent a link with both master and slave rebuild kits. genuine Toyota parts.
    That was just a quick search--I am sure there are more.
  7. May 16, 2013 at 5:26 PM
    Madjik_Man
    The master is OEM
    And I think the $325 kit is all brand new OEM parts to replace the clutch (mechanical parts - not the cylinders). Not just a rebuild kit. Although I admit, I really don't have a clue wtf I'm talking about right now :eek:
  8. May 16, 2013 at 5:26 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    Its EASY to do--PROMISE
  9. May 16, 2013 at 5:27 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    Did you get the PM?
  10. May 16, 2013 at 5:27 PM
    Madjik_Man
    The cylinders absolutely.
    No way I'm touching replacing the entire clutch etc....
  11. May 16, 2013 at 5:30 PM
    Madjik_Man
  12. May 16, 2013 at 5:33 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
  13. May 16, 2013 at 5:33 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
  14. May 16, 2013 at 5:35 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    The previous two posts are what i believe are what you are looking for.
    Not the clutch itself--just the actuators.
    Do you see ?
  15. May 16, 2013 at 5:37 PM
    #35
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    I am done for tonight--Send me a private message--I will reply tomorrow.
    Hope that the info is some help.
  16. May 16, 2013 at 5:41 PM
    #36
    Madjik_Man
    I hear ya, lol.
    There seems to be a disconnect in communication here.
    I'm hoping/praying that it's just a bad slave cylinder. For that I'm replacing it brand new with an OEM slave cylinder. That cost me $55. Like I said earlier for $55 if it fixes my problem and gets me another 166,000 miles, I'll take it.
    We replaced the master cylinder with OEM 3 years ago. I am not going to mess with that for now because that's $125.
    If it turns out that it is not a hydraulic issue (master or slave cylinders) and it is indeed a mechanical issue, then I would need to replace the clutch, eg the clutch disc, pressure plate, release bearing, etc...
  17. May 18, 2013 at 11:08 AM
    #37
    Madjik_Man
    Replaced the slave cylinder (which was original with 166,000 miles on it)
    At first everything felt great but after about 7 or so pushes/releases of the clutch pedal the same symptoms arose.
    Going to try and replace the master cylinder with OEM to see if that fixes it. My friend says that ideally a bench bleed is what you need to do, but just bleeding it normally works fine too... just takes longer. He doesn't have a bench bleeder and I don't think we'll be able to use the shop to do this. Do you guys concur with that?
    If not I'm gonna just have to bend over and have my friend's shop drop the transmission and diagnose the clutch mechanics.
    If the clutch needs replacing I was going to just replace the whole thing with OEM parts (since I got 15 years and 166,000 miles out of it). The kit costs $325. Are there any recommendations for other clutch kits for around the same price that you would say, "dude, if you're spending $325 you should definitely get the ------ kit"
    I don't race this thing, I don't jump it, etc... it's a DD that sees a pretty decent amount of 4wheeling during spring/summer.
    Thanks.
  18. May 18, 2013 at 11:18 AM
    #38
    Madjik_Man
    Sweet... just name dropped again and the cost out the door for the mater cylinder is going to be $98
    Let's hope this does it.
    If not you might hear me scream like Chewbacca after I bend over for a clutch job.
  19. May 18, 2013 at 11:49 AM
    #39
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    can't imagine the clutch would be causing it. Only would need to replace it if its slipping..that said..166k on it..might not be so bad to do anyways. Mine is slipping in 1st gear now.
    Hope the master cylinder fixes it man. Bleed the system good!
  20. May 18, 2013 at 12:53 PM
    #40
    Madjik_Man
    Yeah I'm hoping it's just the master too.
    My friend said a stuck bushing, or broken fork could be a culprit. But it honestly feels hydraulic to me. The fact that it acted normal after replacing the slave and bleeind the system well, but then got all FUBAR'D again after I worked the pedal a few times makes me believe it's hydraulic.
    I hope.
