Clutch Masters hydro bearing failure!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rheath08, May 9, 2021.
  1. Aug 4, 2021 at 8:55 PM
    #61
    rheath08
    rheath08 [OP] Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    I don't think it's clutch dust. I believe it is aluminum partials as the piston spins in the housing. Look at the pics from page one.
    garciav likes this.
  2. Aug 4, 2021 at 8:57 PM
    #62
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
    In my case its clutch dust as it was very fine and black-ish in color.. I did however have some aluminum slivers come up to my clutch res at one point. Pretty distinguishable ...
  3. Aug 4, 2021 at 8:58 PM
    #63
    TacoTuesday1
    FL
    what is this Tilton setup you speak of
    livpool14 and garciav[QUOTED] like this.
  4. Aug 4, 2021 at 8:59 PM
    #64
    garciav
    Houston, TX
    TRD SC,HPTuners
  5. Aug 4, 2021 at 9:05 PM
    #65
    rheath08
    Russell
    Bakersfield, CA
    Mine was black as well. I fail to see how clutch dust will get past a dust seal and a hydraulic seal.
  6. Aug 4, 2021 at 9:10 PM
    #66
    garciav
    Houston, TX
    TRD SC,HPTuners
    well, when you get inferior parts, things can happen
    rheath08[QUOTED][OP] likes this.
  7. Aug 4, 2021 at 9:27 PM
    #67
    TacoTuesday1
    FL
    I took mine apart then re-assembled prior to install.
    Not sure if I lubed the rubber pieces or not.
    I've noticed some squeaking lately. During my last bleed fluid was clear yellow.
    But the squeaking was:
    -short
    -faint
    -might even be from my accessory drive rotating components
    -was only really heard next to a big wall that reflected sound off the truck
    -nowhere near as bad as the stock parts that prompted trans removal
    So, still working for now but, no idea if it's constantly riding the pressure plate/pre-loaded; haven't taken the time yet to remove bellhousing inspection cover and watch how it looks spinning
  8. Aug 24, 2021 at 2:54 PM
    #68
    09bluetrdsport
    09bluetrdsport Active Member
    nick
    09 blue trd sport 6 speed manual
    Intrested on hopefully a better fix for our 6 speed manual transmission problem soon
    as i got to do mine clutch soon ☹
  9. Aug 24, 2021 at 3:22 PM
    #69
    rheath08
    Russell
    Bakersfield, CA
  10. Aug 24, 2021 at 3:38 PM
    #70
    09bluetrdsport
    nick
  11. Dec 7, 2021 at 11:21 PM
    #71
    JackTRDrunner
    JackTRDrunner Well-Known Member
    Jack
    Fullerton, CA
    '13 TRD OR 4x4 6MT & '09 R1
    SAW 2.5 coilovers, TC Uniball uppers, rear 2.5x12 SAW resi's, Deavers, and Archive shock relocation, 33" KO2's, custom bed rack/tire carrier, CaliRaised bumper LED bar & ditch lights, Core Short Throw, Black Widow side pipe...more to come!
    I just got mine installed about 300 miles ago... seemed to be fine until tonight. Had URD heavy flywheel and stage II clutch installed with CM hydro bearing and a new master cylinder as the old one crapped out prompting install of parts. However tonight, as I was shifting into 6th on the highway pedal got super stiff and stuck on the floor leaving truck effectively stuck in neutral. Seemed to fix itself after pumping pedal. Did it a few more times on the rest of the drive home, but only when shifting into 5th or 6th. You guys thing this is a throwout bearing issue or an issue with the new master? I'm stumped
  12. Dec 7, 2021 at 11:31 PM
    #72
    TacoTuesday1
    FL
    I may be wrong
    but fixing something by pumping the pedal is usually a hydraulic problem
    I hope the parts were installed correctly, and I hope it was bled well.
    This is why I DIY whenever I can. Somebody else may not know how a system works, and may not give a shit about a truck that isn't theirs, prompting them to run a bottle through and call it done.
    I took the extra time to bleed the shit out of mine
    JackTRDrunner[QUOTED] likes this.
  13. Dec 7, 2021 at 11:33 PM
    #73
    JackTRDrunner
    Jack
    Fullerton, CA
    That's what I'm thinking and hoping. I've been taking cars to this shop for years with no issues, it could just be a case of unfamiliar parts. I'll bleed it myself and see what happens, I'm just hoping it's not already an issue with the CM part.
  14. Dec 8, 2021 at 7:12 AM
    #74
    rheath08
    Russell
    Bakersfield, CA
    Make sure you no of your lines are kinked. Your pedal adjustment may be off causing a bind. Double check engagement points. You don't want to over extend on the disengagement side.
  15. Dec 8, 2021 at 10:21 AM
    #75
    JackTRDrunner
    Jack
    Fullerton, CA
    Well, I think it's safe to say that it's the hydro bearing. As I'm stuck on the side of the freeway and every gear is neutral now. Think this is a record for how short one of these lasted? I got 312 miles on mine... fuckin hell
    Edit: with fluid dripping out of my bellhousing
    Jeff Lange likes this.
  16. Dec 8, 2021 at 10:42 AM
    #76
    rheath08
    Russell
    Bakersfield, CA
    JackTRDrunner likes this.
  17. Dec 8, 2021 at 10:48 AM
    #77
    JackTRDrunner
    Jack
    Fullerton, CA
    Yeah I was reading through that while waiting on the tow truck. For now gonna have the shop put the stock stuff back in there. Have neither the time nor the money to put that Tilton setup in, but it looks like a setup that actually works
  18. Dec 8, 2021 at 12:25 PM
    #78
    TacoTuesday1
    FL
  19. Dec 9, 2021 at 4:11 PM
    #79
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
    Anyone noticed CM website lately, only item they have for a tacoma now is a oil cap.
  20. Dec 9, 2021 at 4:13 PM
    #80
    rheath08
    Russell
    Bakersfield, CA
    :rofl::rofl::rofl:
