Clutch Pedal from Hell
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Beauty or Beast, Dec 14, 2016.
  1. Dec 14, 2016 at 7:29 AM
    Beauty or Beast
    Beauty or Beast [OP] Well-Known Member
    Jarred
    SWVA
    Magnaflow Off-road exhaust K&N Cold Air Intake CaliRaised Ditch lights/w Rigid D2's Soon to add Pelfreybilt bumper, Headstrong lift, AllPro Sliders
    I have a 2013 Taco with the 6sp. Everything is stock minus her breather and since day 1 I've had an issue with the clutch pedal. It's not a mechanical issue, everything works as it should but it squeaks worse than a Hoot owl in heat some days. It's not everyday either, one day i'll get in and nothing, she'll run quiet and normal. A couple weeks ago on a date it was unbearable, sounded like nails on a chalkboard everytime it was depressed and released. I've told the dealer when I had service done but it was always quiet then. I'm tempted to oil/grease the bushing under the dash which is where I believe the problem is. Any ideas or anyone else heard of this issue?
  2. Dec 14, 2016 at 7:36 AM
    uwu
    uwu Well-Known Member
    Mine is the same way, except in hot and cold. I just turn up the radio :)
  3. Dec 14, 2016 at 7:53 AM
    Pigpen
    Dan
    Northwest Montana
    A couple years ago I had the same problem. There's a spot way up under there that pivots. I shot a little white lithium grease on it and it hasn't made a sound since then. I'm sure I'll have to do it again, but I got through 2 summers - mine only did it when it was hot outside.
    DistortedAxis and Jere like this.
  4. Dec 14, 2016 at 7:55 AM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    I had this same problem, drove me up the wall. Is what finally fixed for me is I got under there with a pair of vice grip pliers and tightened down the linkage thats under the dash. It's been great ever since.
  5. Dec 14, 2016 at 8:32 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Totally normal issue on these trucks, mine was terrible when it was hot and humid and any normal grease or lube seemed to melt away so I ended up using disc brake grease and its been silent ever since.
    Arailt likes this.
  6. Dec 14, 2016 at 9:21 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    There's a few threads on this. My '13 did it too. Had the TSB done and the damn squeak came back. Like shakerhood mentioned, I used never-seize (similar to disk brake lube) on the pivot between the pedal and rod. Nice and quiet. FWIW, there was a member that had posted how his assy broke and it was thought that the drag, which causes the squeak, was enough to result in the plastic fracturing. I use the brush attached to the lid of the jar of lube to cram it in the pivot. An acid brush (like what you would use to apply solder flux to a pipe) will do just fine too.
    shakerhood likes this.
  7. Dec 14, 2016 at 12:35 PM
    glitcheffect7
    glitcheffect7 Well-Known Member
    Maine
    2014 Tacoma 6 cyl 6 spd sr5 access cab
    None, stock
    Same issue here with a 2014 6 speed. Somedays it would be fine and others would be varying levels of squeak. I had the TSB done which solved it for now (new clutch pedal and master cylinder).
  8. Dec 14, 2016 at 12:40 PM
    eon_blue
    Azusa, CA
    Same. Mine creaked as loud as a castle drawbridge being lowered. Toyota slathered it in white lithium grease (I think) and it went away for the most part, comes back if I'm driving for hours on end.
  9. Dec 14, 2016 at 5:26 PM
    gearcruncher
    Canadain bumper technician
  10. Dec 14, 2016 at 5:34 PM
    Mossyjaws
    Mossyjaws Well-Known Member
    VA
    2015 dclb
    Footprint Gas Pedal
    Sorry that I have no input on your issue but am very curious. Does a hoot owl really hoot more while in heat?? Always looking to learn here on tacomaworld.
