Clutch pedal sideways movement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ruseter08, May 12, 2011.
  1. May 12, 2011 at 5:59 PM
    ruseter08
    ruseter08 [OP] Member
    Hi all. I have a 2010 4cyl with the 5 speed and noticed substantial side to side movement when I first step on the clutch. After it goes down a bit and engages with the metal rod that goes into the master cylinder it straightens out. I have tried searching for similar issues, but couldn't find anything exactly like my issue.
    My question is, does this side to side movement on the metal rod cause unnecessary stress onto the master cylinder that could cause leaking or breakage? Has anyone else experienced something similar to what I am experiencing?
    I have owned multiple stick shift vehicles in my lifetime and never noticed any side ways movement in the clutch pedal. I just want to be sure this isn't going to cause any issues later on down the road on a new truck.
  2. May 12, 2011 at 6:33 PM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    OMG I was just about to make this same post. WTF is this? Mine is the same and it pisses me off like crazy. My truck is only a month old too
  3. May 12, 2011 at 8:54 PM
    charles08tacoma
    charles08tacoma Well-Known Member
    Santa Cruz, CA
    08 Prerunner SR-5 Access Cab
    White Snug Top shell
    It's just the POS plastic clutch pedal assembly. My 2008 has done it since new. Dealer says it's normal, even though they replaced the entire clutch pedal assembly last December. It's even more fun when it creaks when you depress the pedal. The clevis & rod assembly broke on mine a couple weeks ago, dealer replaced that, starting to creak again. No noticeable improvement on the side to side movement though. Just a crap design by Toyota.
  4. May 12, 2011 at 9:10 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    I'm not familiar withthe cluch-pedal design on Tacos, but is there anywhere you could shim it with washers?
  5. May 13, 2011 at 3:30 AM
    ruseter08
    Thanks for all the feedback. I am glad I am not the only person experiencing this. I will have to take a closer look at it and see if I can tighten it up with some washers or something.
  6. May 13, 2011 at 3:55 AM
    Jere
    Jere Outdoorsman
    Northern Chester County, PA
    '18 TRD Sport MGM with ARE Cap
    I wouldn't call my side to side movement "substantial", but it is noticable, and it certainly is not something I've ever felt on any of a long string of manual vehicles I've driven in the last 50+ years. If anyone finds the right place to add a washer or spacer and a good material (brass, nylon, ...) a post and a picture would be appreciated.
  7. May 13, 2011 at 9:01 AM
    charles08tacoma
    Santa Cruz, CA
    When my clutch pedal was replaced last December, the service advisor showed me the new pedal assembly they were installing. He said there are nylon bushings that Toyota says should be installed with no lubrication. He felt there should be some kind of silicone lubricant paste put in to keep them working smoothly, but Toyota doesn't authorize using any & it would void the part warranty. They are just thin nylon & look like they would wear fairly quickly.
  8. May 13, 2011 at 9:02 AM
    Navigator
    Navigator Well-Known Member
    Ontario, Canada
    05 DC Sport 6spd
    17" American Racing Assaults on 265/70/17 Goodyear AT/S, TRD Exhaust, TRD CAI, Toyota Roof Rack, XM install with antenna out 3rd brake light, Red LED Map Lights, AUX Amber LED rocker switch for LED footwell lights, LUND Bug Screen, EXTANG Tri-Fold Tonneau, Hertz Component Speakers w/ TacoTunes Mounts, Infinity Kappa 4 amp, Image Dynamics 10" sub in TacoTunes enclosure, Pop n' Lock, Toyota Aluminum Wedge Running Boards, BHLM, Self Performed '05 Cowl Leak TSB, E-Z Cool Insulation/Sound Deadener applied to floorboard, headliner, and cab bulkhead, 896 Foglight bulbs as backup lights, Weathertechs, Pioneer Double Din, Scan Gauge, AutoSoft Remote Start, 2010 4Runner Heated/Signal/Puddle Mirrors.
  9. May 13, 2011 at 9:06 AM
    charles08tacoma
    Santa Cruz, CA
    Yup, thats it!! Mine moves like that. Dealer says not worse than any new one on the lot they compared mine too.
  10. May 13, 2011 at 9:28 AM
    Mskwared
    Mskwared Well-Known Member
    I heard on here somewhere that the rod in the pedal assembly loosens itself in its seat and thats what creaks. He also said that if you twist the rod itself like a quarter turn or whatever that it stops creaking for a while but it will loosen itself again. Loc-tite or something maybe?
    I have the same problem in my 08. Really annoying in bumper to bumper traffic. Even more so when theres a car full of cute girls next to you.... -_-
  11. May 13, 2011 at 9:32 AM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    :notsure:Why did they go all cheesy on the 2nd gen clutch assy? The 1st gens weren't like this.
  12. May 13, 2011 at 9:38 AM
    TeXian
    TeXian Shifting Member
    Christian
    Texas
    2010 Pyrite Mica TRD Sport DC 4X4 6spd
    bone stock
    I first noticed the sideways movement almost on day 1. Then the creaking sound and it drives me crazy! I've driven manuals all my life and have never seen anything like this before. My friend is a Toyo Tech and I'm taking it in and see what he says. He'll replace the entire assembly if he has to, but like previous posts, I'm not optimistic it will permenatly correct the problem. I'll post again once I get it replaced and give any details provided.
  13. May 13, 2011 at 10:33 AM
    ruseter08
    Yes my movement is very similar to the video posted. If other people are experiencing this then I guess it is normal for our trucks. I was just concerned because I have never experienced this with any of my other manual transmission vehicles.
    Thank you all who replied.
  14. May 13, 2011 at 10:40 AM
    tvbd56
    tvbd56 Epic Member
    Tyler
    Sacramento, Ca
    2018 Black DCLB OR 4x4
    i have a 2005 and I've had it ever since i bought it. I've gotten used to it
  15. May 13, 2011 at 2:05 PM
    Navigator
    Ontario, Canada
    05 DC Sport 6spd
    Someone posted a DIY thread on Clutch Pedal Pivot Bushing replacement, all I have to do is find it.
  16. May 13, 2011 at 2:14 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    my old civic SI was 100 times worse. It was so bad the vibration made it feel like the throw out bearing was gone
  17. Sep 14, 2020 at 8:22 AM
    ricknobinson
    ricknobinson Well-Known Member
    Nick
    06 TRD Off Road Tacoma Access Cab
    I know this is an ancient thread but I’m having the same exact issue with my 06 6-speed clutch pedal. Anybody find a fix for this? Dealer wants $800 to replace the whole pedal assembly.
  18. Sep 4, 2021 at 3:06 PM
    Sauceman
    Sauceman New Member
    2015 Access cab 4x4
  19. Aug 27, 2023 at 5:59 AM
    T@coTim
    T@coTim Well-Known Member
    Tim
    I just bought a used 2015 with a 5 speed manual with the same side to side clutch pedal play. I’m wondering if it’s worth it to remove the clutch pedal assembly and rebuild it? :confused:
  20. Aug 27, 2023 at 12:32 PM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    If you're going to pull it out, I'd order the FJ Cruiser metal pedal & related parts. It's not awful to get the arm out, but once you do the upper & lower halves of the bracket can move a little (the pivot bolt goes through both) and it's super fun to get everything lined back up to get the bolt back in.
    And as far as "rebuilding" it, there's not much to rebuild, the plastic arm rides on a spacer, and the master cylinder is just a ball that just sits in a socket. I think I had about $200 into the metal arm & related parts, plus a new Aisin (aluminum) master cylinder, and then an Aisin slave cylinder since I figured I might as well at that point, rather than cross my fingers I could get the bleeder loose.
    T@coTim[QUOTED] likes this.
