Clutch Pedal will not come back up
Discussion in '1st Gen. Tacomas (1995-2004)' started by jpate, Jun 24, 2011.
  1. Jun 24, 2011 at 11:59 AM
    jpate
    jpate [OP] New Member
    Alabama
    2003 tacoma ext cab
    I have a 2003 tacoma and the clutch pedal will not come back up. It just stays stuck to the floor but the clutch still works fine except that. I have taken the assembly out and the bushings need replacing could that be the problem.
  2. Jun 24, 2011 at 12:00 PM
    cmj
    cmj Well-Known Member
    Oregon
    98 Tacoma 4x4
    Clutch master or slave cylinder failure. See if there is brake fluid visible coming from the master cylinder on the floor or in the engine bay. Also check the slave cylinder for visible leaks
  3. Jun 24, 2011 at 12:00 PM
    Bfoster133
    Bfoster133 If i asked my dad for money, He'd knock me out
    Blake
    Thousand oaks, California
    2011 PreRunner TRD offroad
    15% Tint, 5100's at 1.75, Rear Diff Breather, CB radio, Black rattle canned rims, 265/75/16 Goodyear MTR, Magnaflow Offroad pro cat back, hi-lift bed mounted, shovel bed mounted
    if the bushings are causing friction then yes
  4. Jun 25, 2011 at 12:06 PM
    67tone67
    67tone67 Well-Known Member
    Tony
    Fulton Ms
    04 Dbl cab TRD
    Check your fluid levels and try bleeding your clutch before you start buying new parts
  5. Jun 25, 2011 at 12:12 PM
    Quast
    Quast Well-Known Member
    Dustin
    Mission, BC
    03 toyota tacoma 3.4L
    3'' OME lift, Deck plate mod, spidertrax wheel spacers, 12'' alpine type S sub.
    agreed i had the same problem did this but i still needed to replace the master and slave cylinders works good now.
