CLUTCH PEDAL WON'T FULLY RETURN.
Discussion in '1st Gen. Tacomas (1995-2004)' started by 96WHITEONBLUETACO, Sep 23, 2013.
  1. Sep 23, 2013 at 1:39 PM
    96WHITEONBLUETACO
    96WHITEONBLUETACO [OP] Member
    All stock.
    Hello TW Community,
    I have a 96 Tacoma LX 4x4 with 384,000 miles on the OD. It has been a phenomenal vehicle and has given me little trouble.
    My issue is: The clutch pedal only returns about 90-5% percent. There is roughly one inch left for the pedal to fully return. I simply pull the clutch pedal out with my toe, so I don't wear the clutch.
    Is my slave cylinder bad? Is the clutch pedal assembly worn? (although it doesn't seem to be hung up or obstructed in any way)...
    FYI: The master cylinder fluid is full. There are no apparent leaks of any kind.
    Any help or direction would be greatly appreciated. I would like to fix it myself without having to take it to the dealer.
    Thanks!
    TM
  2. Sep 23, 2013 at 1:50 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Sounds like the slave cylinder is worn out. You can rebuild it with a kit
  3. Sep 23, 2013 at 1:59 PM
    96WHITEONBLUETACO
    All stock.
    Thanks for the quick response!
    Is the slave cylinder bolted on the firewall directly below the master cylinder?
    What is the purpose of the slave cylinder?
    TM
  4. Sep 23, 2013 at 2:44 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
