Clutch squeak Linear Spring swap (TW how to)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rucas, May 28, 2011.
  1. May 29, 2012 at 9:14 AM
    Madjik_Man
    Colorado Front Range
    lol... I have to do that all the time. It'll be hard to break the habit.
    And because I'm an anal-retentive knobular jackass, I have to ask one more time:
    You just removed that huge ass torsion spring entirely and did not replace it? And the pedal functions normally?
    Also when you removed that torsion spring, did you wrap it in a towel like the TTORA guy did? I'm always spooked out a bit popping spring with lots of tension in it.
    Thanks
  2. May 29, 2012 at 10:54 AM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    It looks like a good fix for the creaky clutch bushing. It's easier than taking the whole pedal assembly out to replace the bushing.
    The clutch pressure plate will push the slave cylinder piston back when you take your foot off the clutch. You don't have to worry about the clutch slipping.
    I wouldn't mind having a lighter clutch.
  3. May 29, 2012 at 2:58 PM
    valleyflyfisher
    valleyflyfisher Member
    I did this fix a few months ago and works like a charm, no more squeak is nice.
  4. May 29, 2012 at 4:10 PM
    Fejurty
    Fejurty Member
    Vancouver
    02 Ext Cab TRD
    Just throwing this out there. I did the spring mod a couple months ago and I just had to replace my clutch master cylinder. Does anyone think the new spring has anything to do with it? I'm wondering if the old torsion spring had more spring in it, helping the pedal return to it's high position and relieving some pressure on the 2 cylinders, mainly the master. I replaced the slave cylinder first and it didn't fix it so I went with master second which fixed the problem I was having. Could just be wear and tear with 220km but got me thinking...
    Anyway have any input? I don't have much knowledge on this stuff.
  5. May 29, 2012 at 4:30 PM
    Madjik_Man
    Great... now you've planted seeds of doubt into my head
    :eek:
  6. May 29, 2012 at 5:04 PM
    Madjik_Man
    Mine only squeaks in cold and humid conditions.
    So all winter in Colorado and not much else.
    But you're right... I need to turn off the computer and just do it.
    I have a brake pedal return spring coming to me in the mail from a TW member whom I am sending a sheet of the rubber gasket material (for the cup holder tabs)
  7. May 29, 2012 at 9:02 PM
    rysully
    rysully Active Member
    Gainesville
    04 SR5 4WD
    I have a similar problem. How do I know for sure if its the spring? It dosen't always make a squeaking noise. I hate it I just bought my tacoma a month ago and every time I hear it I cringe. lol I just was praying it wasnt something serious.
  8. Jun 4, 2012 at 12:33 PM
    nicnicman
    nicnicman Active Member
    Maine
    03 Tacoma SR5 4 Cyl Manual
    My 2003 4x4 4 cylinder uses a different assembly. It all ready uses a spring. For me this wasn't the problem.
  9. Jun 4, 2012 at 1:19 PM
    Madjik_Man
  10. Jun 4, 2012 at 7:17 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    For those of you that did this mod. With the old spring could you feel when the clutch engaged? What about with the new spring?
    I have the old spring(the one this mod eliminates) and I cant feel when my clutch engages. It also squeaks/ pops and is really stiff
  11. Jun 4, 2012 at 7:21 PM
    trmarshall1
    trmarshall1 The Least Interesting Man In The World
    Tim
    San Jose, CA
    02 Tacoma 4x4 TRD Supercharged
    4" Pro-Comp Lift, TRD cat back exhaust, grey wire mod, clutch pedal linear spring mod
    :dancingbacon::broccoli::amen::headbang::woot:
  12. Jun 4, 2012 at 7:23 PM
    trmarshall1
    Tim
    San Jose, CA
    How's it sounding Madjik Man?
  13. Jun 4, 2012 at 7:29 PM
    Madjik_Man
    What sound? :p
  14. Jun 4, 2012 at 7:55 PM
    TACOMABOSS
    96 SR5 4x4
    anyone?
  15. Jun 4, 2012 at 8:28 PM
    #35
    Madjik_Man
    Just like I said in my build, I didn't have that issue. Hopefully someone else can chime in.
  16. Jun 4, 2012 at 9:19 PM
    #36
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    Hmmmm not really sure about that. I haven't had any problems.
    The stiffness might be a spring # issue. Or in the hydros, I remember someone saying that even with the spring off their clutch acted and felt normal.
  17. Jun 4, 2012 at 9:28 PM
    #37
    TACOMABOSS
    96 SR5 4x4
    Interesting. I hope its just the spring and not something to do with my clutch. Its been like that since I bought it
  18. Jun 5, 2012 at 8:53 AM
    #38
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    yeah then you might want to check your fluids too, just to be sure,
  19. Jun 5, 2012 at 7:16 PM
    #39
    Madjik_Man
    Well this sucks moose titties...
    Day 2 of use and I began to hear a very faint "tick" every time I engaged and released the pedal. Of course only I am the one who can hear it but it's still pissing me off beyond belief.
    Turns out that notch, in which the middle part of the torsion spring nestled into (just northeast of the spring in the pic above), rotates down when the pedal is pressed and back up again (on that axle with orange goop on it) when the pedal is released. When it does that, it ends up hitting the spring and making that ticking noise.
    More concerning is when I was manually pushing and releasing the pedal with my hand, watching this crapfest unfold before my eyes, I can see the spring ever so slightly get hung up on that notch. My fear is that it gets fully hung up on it while driving.
    Anyone else have this issue?
    Anyone have a suggested fix? I highly doubt I'm ever going back to the torsion spring so I might just try to get a jigsaw up in there and cut the bastard off.
    Please someone yell at me if that's a terrible idea.
  20. Jun 5, 2012 at 7:25 PM
    #40
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    not sure about that. I noticed that when I first used a bigger diameter spring it tended to hit on something. might want to try looking for a different spring? or turn the music up maby?
    Emmetjmcc4 likes this.
