Clutch squeak Linear Spring swap (TW how to)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rucas, May 28, 2011.
  1. Jun 7, 2012 at 8:31 PM
    #61
    Madjik_Man
    Colorado Front Range
    If you are at a dead stop, put it in gear and slowly release the clutch without giving it gas, can you feel it engage when it catches?
  2. Jun 7, 2012 at 8:32 PM
    #62
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    Yes
  3. Jun 7, 2012 at 8:35 PM
    #63
    Madjik_Man
    Does your pedal feel soft and mushy? Or do the hydraulics feel fine?
  4. Jun 7, 2012 at 8:37 PM
    #64
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    I don't mean to butt in but after i rebuilt my slave cylinder, flushed the lines and put in new fluid, and I did the spring, it made a world of difference.
    tomorrow I am going to rebuild the main clutch cylinder to make sure its in tip top shape.
    but none of that is hard, if I can get my ol fat ass down there and do it anyone can.
  5. Jun 7, 2012 at 8:38 PM
    #65
    TACOMABOSS
    96 SR5 4x4
    No it doesn't feel soft. It's basically a continuous feel all the way. And it squeaks and pops in the meantime
  6. Jun 7, 2012 at 9:23 PM
    #66
    TACOMABOSS
    96 SR5 4x4
    Don't really know. 3 maybe more
  7. Jun 8, 2012 at 7:46 AM
    #67
    TACOMABOSS
    96 SR5 4x4
    Ive felt a 2000 V6 clutch and it felt nothing like mine. And
    A bunch of my friends felt mine and said that it's not the way it's supposed to be. There's have a feel to it
  8. Jun 8, 2012 at 8:00 AM
    #68
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Clutches are supposed to have a nice linear feel to them IMO... Not just grab at some point and go. It's much smoother feeling. I think as the clutch wears it engages higher and higher in the pedal's range of motion, which makes this linear engagement much shorter to the point where it's basically on or off. I noticed this in a friend's Accord that had a known bad clutch... it was like nothing until you had the pedal almost all the way out then boom!
    Maybe your clutch is the only one that's good and all your friends have bad clutches :p
  9. Jun 8, 2012 at 8:15 AM
    #69
    TACOMABOSS
    96 SR5 4x4
    I've thought of this too, but I felt some clutches at the toyota dealer and they felt like my friends. I'm not saying you're wrong because you might be right. I just don't know haha
  10. Jun 8, 2012 at 8:19 AM
    #70
    MowTaco
    Kansas
    Frankly I have no idea. Those are just my observations in my relatively short driving career.
  11. Jun 8, 2012 at 9:59 AM
    #71
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    okay so i just checked my spring.....
    and it was so lose and stretched (that's what I said) that I barely touched it and it fell off. :eek:
    The hydros must have been keeping the pedal cycling
  12. Jun 8, 2012 at 10:14 AM
    #72
    Madjik_Man
  13. Jun 8, 2012 at 10:43 AM
    #73
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
  14. Jun 8, 2012 at 4:33 PM
    #74
    TACOMABOSS
    96 SR5 4x4
    wait Rucas did you have the #70 spring from true value? thats the one i just got..
    Edit: nevermind re-read it
  15. Jun 8, 2012 at 5:28 PM
    #75
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    I think the wire thickness is my problem
  16. Jun 8, 2012 at 5:42 PM
    #76
    milehighliving
    milehighliving Well-Known Member
    Colorado
    03 Silver Xtra Cab 4x4
    2nd Gen SC, Addicted Front Bumper, Allpro rear bumper, OME Full suspension lift, LR UCAs, Extended brake lines, Goodyear Wrangler Duratrac 285/75/r16 with level 8 wheels.
    I bought a couple #70 springs, the other day. Been planning on doing this mod, as my clutch squeaks a little but everything works fine and I'd hate to fix something that isn't broken... All you guys that bought #70 springs how's it holding up? OP you're spring look like it had way too many coils? Do you believe that is why it fell off?
  17. Jun 8, 2012 at 6:11 PM
    #77
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    yeah I think that it does have too many springs.
    I think Im going to get a toyota brake return spring and replace it.
  18. Jun 12, 2012 at 1:06 PM
    #78
    LoneWanderer
    LoneWanderer Well-Known Member
    Randy
    Ohio
    03 4x4 Access Cab 2.7l 5spd
    Bilstein 5100s, Rancho Quick Lift struts, Wheelers 3 leaf aal, Procomp 8069s, General Grabber AT2 31x10.5, AFE Pro Dry S air filter, Dynomax Super Turbo muffler
    So this only fixes a squeak that comes from inside the cab right? Because I have a squeak that comes and goes and I hear it from right under the truck. I can hear it from inside but its definitely outside as I hear it worse when the window's down.
  19. Jun 12, 2012 at 2:05 PM
    #79
    Madjik_Man
    Yup. Just fixes the squeak/squeal from the torsion spring
  20. Jun 12, 2012 at 2:06 PM
    #80
    Madjik_Man
    FWIW... the ticking noise went away on mine.
    Don't know if it's the gaffer's tape I wrapped around that welded notch, or if the clutch pedal gremlin decided to move on...
