Clutch squeak Linear Spring swap (TW how to)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rucas, May 28, 2011.
  1. Mar 16, 2013 at 4:32 PM
    #101
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    I replaced the clutch spring with a OEM brake sping 2 to 3 months ago. Super easy, just pry out the stupid coil spring and hook up a brake spring.Takes 10 min. I used a OEM brake spring . I checked it yesterday and it is working fine. Clutch feels fine, good pedal feel.
  2. May 11, 2013 at 4:34 PM
    #102
    Yooper159
    Yooper159 New Member
    Miles
    UP Of Michigan
    2003 Tacoma 4x4 5spd
    Stock
    My clutch pedal was not coming all the way up. it would stop about a half inch from top and I would also hear a definite spring creak sound when using the clutch pedal. The toyota dealer I brought it to looked at it and bleed the master and slave clutch cylinders and told me they would need to replace the master cylinder ie another $150 on top of the $80 charged to diagnos the problem. I did not agree. I could tell it was something connected to the clutch spring. Attached is the diagram of the clutch pedal linkage under the dash. I ORDERED AND replaced the little plastic "U" shaped shim 31301P that rides between the clutch pedal return spring and the clutch rod arm seen in the diagram. The part cost $3.18. I replaced it myself by removing the entire clutch assembly from the fire wall. Wasn't too bad, but if you show a mechanic the diagram and part they can do it for $100 or so. THIS LITTLE PLASTIC SHIM FIXES THE SQUEAK AND THE CLUTCH NOT RETURNING TO TOP. CLUTCH PEDAL WORKS LIKE NEW AS IT SHOULD.
  3. Jul 18, 2013 at 7:55 PM
    #103
    HF13
    HF13 Well-Known Member
    Aaron
    North Central FL
    '04 4X4 TRD Xtra Cab
    Pretty sure this is what everyone is trying to Avoid doing. Im gonna try and use the brake return spring and ill let you all know how it works, whered u get that brake spring again Madjikman?
  4. Jul 18, 2013 at 8:00 PM
    #104
    HF13
    Aaron
    North Central FL
    BTW Madjikman your clutch pedal looks like it has been brazed with a torch...pretty good looking brazing job if i might say so myself.
  5. Jul 19, 2013 at 6:18 AM
    #105
    Madjik_Man
    Colorado Front Range
    From another member (I sent him material for the cup holder tabs, he sent me the spring).
    You can get it at the dealer or online. It's like $2.50
  6. Oct 11, 2014 at 10:22 AM
    #106
    BV227
    BV227 Member
    02 Tacoma
    I know this thread is over a year old, but am hoping someone will revisit it for me. I've paid my dues with a piece of scalp, three busted knuckles, and and hour of contorted, upside down labor - - how in hell do you get the damn coil spring off to start with? Does it take some tool I've never seen before?
  7. Oct 11, 2014 at 11:44 AM
    #107
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    as you can see in my first picture, I just took a flat head and pried it out on the side of the coil spring where it goes into the hole.
    ** careful when it does come out because it has a lot of kinetic energy.
  8. Oct 11, 2014 at 12:08 PM
    #108
    BRP27
    04 4X4 Tacoma SR5
    Ya you just line up and start prying. Use of gloves and protective eye wear is recommended. I remember a bit of pucker factor prying the spring out:)
  9. Oct 12, 2014 at 7:23 AM
    #109
    Yooper159
    Miles
    UP Of Michigan
    Stock
    HI,
    I highly recommend removing the entire clutch pedal assembly. once outside it's pretty easy to replace the plastic shims/bushings. The mounting studs go through the firewall and also the master cylinder. It sounds like extra work, but believe me it's the way to go. I tried popping the coil while it was under the dash too, I couldn't do it.
  10. Oct 27, 2014 at 2:18 PM
    #110
    5280
    5280 old school
    Colorado front range
    99 Tacoma TRD
    Trail Gear Front bumper, Warn, Apex Octane rear bumper, SPC, OME 881, Dakars, Raven topper, PIAA fog lights, dog mod and a couple other things...
    Thanks Rucas for posting this - my squeaky old clutch squeaks no more! Also thanks to Madjik Man for additional help.
  11. Oct 27, 2014 at 2:26 PM
    #111
    Madjik_Man
    Awesome!
    Glad it worked out. I can't believed I lived so long with that noise before doing this.
    How does the pedal feel now?
  12. Oct 28, 2014 at 5:03 AM
    #112
    5280
    5280 old school
    99 Tacoma TRD
    Pedal is much better; feels "right," for lack of a better description.☺️
  13. Nov 13, 2014 at 5:11 PM
    #113
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    From left to right:
    1. 4Cyl Clutch Pedal Return Spring, Part # 90507-14030
    2. Brake Pedal Return Spring, Part # 90905-07028
    3. Brake Pedal Return Spring "W/VSC", Part # 90905-07020
    Going with #1 for now.
    CrustyTaco likes this.
  14. Nov 13, 2014 at 5:50 PM
    #114
    tomtom
    The Desert SW
    2012 FJ
    Not pressed:
    Depressed:
    No contact on the pedal assembly cross brace (as expected). Minor contact on the torsional spring tab.
  15. Nov 13, 2014 at 5:54 PM
    #115
    Madjik_Man
    On my phone so maybe I don't see it well, but which spring did you use?
  16. Nov 13, 2014 at 6:11 PM
    #116
    tomtom
    The Desert SW
    2012 FJ
    The 4 Cyl. clutch pedal return spring. 90507-14030
    BTW, I think the spring you used is Part #90905-07028.
  17. Nov 13, 2014 at 9:00 PM
    #117
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    so it does make contact a little with the torsion spring tab?
  18. Nov 13, 2014 at 9:01 PM
    #118
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    i make contact with both spring tab and cross bar. a ziptie holding it up prevents it from making noises lol
  19. Nov 14, 2014 at 12:39 AM
    #119
    tomtom
    The Desert SW
    2012 FJ
    yes, sir. As does both brake pedal springs.
    Possible other options to solve include grinding the tab down a little or getting a 4Cyl clutch pedal.
  20. Nov 14, 2014 at 3:32 PM
    #120
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    hmmm I don't think I've had that problem on my truck. I wonder if the clutch pedal assemblies are different.
