Clutch squeak Linear Spring swap (TW how to)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rucas, May 28, 2011.
  1. Nov 14, 2014 at 4:04 PM
    #121
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    oops. :eek: I didn't check the 07028 spring (brake pedal spring w/ long hook). I know the 07020 does make contact with the torsional spring tab. I'll check the 07028 this weekend.
  2. Nov 15, 2014 at 3:17 PM
    #122
    tomtom
    The Desert SW
    2012 FJ
    ok. took 5 minutes and tested the regular brake pedal spring (Part No. 90905-07028).
    I get contact on the torsional spring tab.
    pedal relaxed:
    pedal depressed:
    I put the 4cyl clutch pedal spring back in. If I get bored, I'll order up a 4cyl clutch pedal and swap it in so it works perfectly.
  3. May 19, 2015 at 10:24 AM
    #123
    a.smo
    a.smo Well-Known Member
    Aaron
    PHX, Az
    '99 Trd Xtra Cab 4x4 5sp
    Do you know by any chance if #2 will work for a 97 limited 4runner? I couldn't find any info on their brake pedal springs.
  4. May 19, 2015 at 9:15 PM
    #124
    tomtom
    The Desert SW
    2012 FJ
    Not sure exactly what you're asking about as we're replacing the torsional clutch pedal return spring with linear pedal return springs.
    As long as you have the same clutch pedal assembly and the attachment point up in the dash, either #1 or #2 will work to replace the torsional spring.
  5. Jun 1, 2015 at 6:53 PM
    #125
    a.smo
    Aaron
    PHX, Az
    Forgot about this.
    I'm looking to replace my torsion spring as it is worn out as well. I was curious if anyone knew if 4runner brake return springs were the same but I figured it out. Thanks!
  6. Sep 28, 2015 at 11:41 AM
    #126
    smokn
    smokn Unsenior Member
    08 DCSB TRD SPORT SR5 4x4
    I did this mod about 6 months ago. After about a month or so I had the squeak again. I used one of the 3 listed above, I'm pretty sure it was "1. 4Cyl Clutch Pedal Return Spring, Part # 90507-14030." It's still better than the dying cat squeak I had before, but it's definitely still noticeable. It's worse in the morning and gets better after driving all day.
  7. Sep 29, 2015 at 6:16 AM
    #127
    Madjik_Man
    Colorado Front Range
    Could just be cold/humidity making the remaining bushings squeak. Happens to mine all the time.
  8. Oct 8, 2015 at 4:11 AM
    #128
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
  9. Oct 8, 2015 at 6:01 AM
    #129
    Madjik_Man
    I used the brake return spring.
    It is definitely the one you want to use.
  10. Oct 8, 2015 at 3:04 PM
    #130
    TacoVio
    Kolton
    CO/WY
    Is it the one ending in 07028?
  11. Oct 8, 2015 at 8:00 PM
    #131
    Madjik_Man
    Oh geez... I'm going to have to dig through some archived photos to find out for sure. I'll check back in a bit.
  12. Oct 8, 2015 at 8:07 PM
    #132
    Madjik_Man
    @TacoVio
    I'm pretty sure I used the one ending in 07020
  13. Oct 8, 2015 at 9:12 PM
    #133
    TacoVio
    Kolton
    CO/WY
    Sounds good thank you for the help I appreciate it :thumbsup:
  14. Oct 8, 2015 at 9:50 PM
    #134
    tomtom
    The Desert SW
    2012 FJ
    Out of the three, I recommend the 4Cyl Clutch Pedal Return Spring, Part # 90507-14030
    The others have more spring contact and get a bit noisy.
  15. Oct 8, 2015 at 9:53 PM
    #135
    TacoVio
    Kolton
    CO/WY
    Right I was gonna use the 07028 because the early pics you posted it looked that one had the longest hook end that wouldn't make the coils hit that tab. :thumbsup:
  16. Oct 8, 2015 at 9:55 PM
    #136
    tomtom
    The Desert SW
    2012 FJ
    I can dig through my box of spare parts to see if I still have one and send it to you. Not like I'll be needing one anytime soon, I think.
  17. Oct 8, 2015 at 10:12 PM
    #137
    TacoVio
    Kolton
    CO/WY
    Well I'm not gonna say no lol If you don't mind I would really appreciate it!! :D
  18. Oct 9, 2015 at 6:04 AM
    #138
    Madjik_Man
    For S&Gs I might try that one day. My initial little "tick" from spring contact has been gone for years.
  19. Oct 9, 2015 at 9:31 AM
    #139
    TacoVio
    Kolton
    CO/WY
    How's the wire thickness on the 4cyl spring In comparison with how the clutch pedal feels? Is it softer than stock?
  20. Oct 9, 2015 at 9:36 AM
    #140
    TacoVio
    Kolton
    CO/WY
