Clutch Start Cancel vs Emergency Brake (E-brake)
Discussion in 'Off-Roading & Trails' started by TacomaRumble, Feb 25, 2011.
  1. Feb 25, 2011 at 10:19 PM
    TacomaRumble
    TacomaRumble [OP] Member
    Los Angeles, CA
    2009 Tacoma 4x4 V6 TRD Sport
    So I've been reading up on the Clutch Start Cancel button and its uses. My current understanding is that it is primarily used for two purposes:
    1) Start the truck w/o the clutch when you're outside and don't want to get in to depress the clutch.
    2) When you're on a hill and you stall, you use this button to help get the truck moving forward w/o rolling backwards.
    My question involves the 2nd use above.
    For better or for worse, I was taught to use the E-brake when on a hill in order to avoid rolling backward. Basically as your clutch engages you start disengaging the e-brake and begin your ascent without moving backwards. This has always worked great for me, and it seems fairly smooth and stress free. So my question is, when and why would I use the clutch start cancel button over this seemingly more controlled method of using the e-brake?
    I apologize in advance if this is a stupid question. I'm still new to the 4x4 world, and I've been unable to find the answer to this question.
  2. Feb 25, 2011 at 10:24 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab CLONE
    crap bolted and welded together....
    well using the clutch start cancel button is mainly used for just starting it without the clutch be pressed, it doesnt assist you to start on a hill like realeasing the E-Brake. the only real advantage of the button would be to limp your way out of somewhere with that button pressed and turning the vehicle over if it cant start. But i think your over thinking what that button does and/or dont really understand that button.
    thats just my take tho, im sure their are other things that im right and or wrong about.
  3. Feb 25, 2011 at 10:34 PM
    TacomaRumble
    Los Angeles, CA
    That makes sense. Definitely can see it being handy if your truck isn't starting.
    And you may be right, I may be overthinking the button, guess I'm just trying to understand the advantages of this feature. It was just confusing me that no one mentioned the e-brake method to prevent the truck from rolling (maybe it's obvious?).
  4. Feb 25, 2011 at 10:36 PM
    snowgod06
    Rob
    06 Access Cab CLONE
    yea their was a member here that actually did this, i tired to find the thread but failed lol. It'll kill your battery but if it gets you out its worth it. Im sure someone else can chime in and give knowledge, hell look in the manual. It could say something in their.
  5. Feb 26, 2011 at 12:25 AM
    06rubi
    06rubi Well-Known Member
    Kenney
    Pueblo West, CO
    10 MGM (wife's truck)
    Debadged, tinted windows, 7 pin relocated, bed lights, 12 volt socket in bed of truck, on board air, auxiliary fuse box, grill craft, hella 500's, t-rex eyelids, pink budbuilt skids, icon remote resi coil over, camburg uca, alcan rear springs, ubolt flip, icon 2.5 remote rear resi shocks
    It's designed to be used in L4. Say ur half way up an obstacle and you want to get out to check ur spot or you just killed ur engine climbing up, simply leave the truck in first gear turn the key to start and start driving. Or even if ur on a trail ride and everyone stops and ur on a hill do the same thing. Try it out before you need it to get a feel for it. I wouldn't recommend using it on the street or in 4h.
  6. Feb 26, 2011 at 12:51 AM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    OK. I also learned to drive properly in a manual and using the brake on hills to prevent rolling backwards. This method works fine, but is better suited for a hand brake system (harder to smoothly do on the 1st Gen pull brake).
    Anyway my advise is to keep using the system you are comfortable with.
    Yes, the "hill start" button is designed to start the truck in gear. This may or may not work for you depending on the situation, certainly in 4low you'll have best success.
    Your method would work equally well.
    And I am perplexed by your first stated use for the button, "
  7. Feb 26, 2011 at 1:06 AM
    TacomaRumble
    Los Angeles, CA
    Good info, thanks. I'll play with it to get the hang of it.
    For example, you have ski boots on and you wanna warm up your truck while you put your stuff away, hit the clutch start cancel switch and turn the truck on in neutral. Haven't done this myself but I could see the convenience.
  8. Feb 26, 2011 at 1:11 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
