Clutch Stuck!!! HELP
Discussion in '1st Gen. Tacomas (1995-2004)' started by Stubbs95tacoma, Oct 2, 2011.
  1. Oct 2, 2011 at 12:43 PM
    Stubbs95tacoma
    Stubbs95tacoma [OP] Well-Known Member
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    When i push my clutch down it sticks to the ground or halfway back up what is wrong with it? worn out spring? and how do i fix it?? :confused: :confused:
  2. Oct 2, 2011 at 12:51 PM
    Stubbs95tacoma
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    Bump cant move it out of my driveway :eek:
  3. Oct 2, 2011 at 1:14 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Try waiting more than 8 minutes before bumping a thread next time.
    Clutch can stick if the clutch master or slave cylinder are toast.
    You can also check the spring but I doubt that's your problem. My money's on the slave cylinder.
  4. Oct 2, 2011 at 1:21 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    +1 on the slave cylinder...easy fix
  5. Oct 2, 2011 at 1:24 PM
    Stubbs95tacoma
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    THe clutch works fine when i pull it back up with my foot? so could it be the spring?
  6. Oct 2, 2011 at 1:25 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I said my money is on the slave cylinder for a reason.
    Your description is exactly what happens to the pedal when you open the bleeder valve on the slave cylinder.
  7. Oct 2, 2011 at 1:37 PM
    Stubbs95tacoma
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    This is my 1st manual truck i have had so i was just asking about it... the only reason i was asking about the spring is because it squeaks when i push it in...
  8. Oct 2, 2011 at 1:40 PM
    TacoMX
    Jonathan
    Deltona, Florida
    Almost every 1st gen clutch is squeaky. Pretty common.
  9. Oct 2, 2011 at 1:42 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
