Clutchless shifting in manual 2001 Tacoma
Discussion in '4 Cylinder' started by jwa1028, Nov 23, 2009.
  1. Nov 23, 2009 at 6:38 AM
    jwa1028
    jwa1028 [OP] Active Member
    '01 4 cyl Tacoma
    Does anyone else not use the clutch between 1st and 5th gear? I do it all the time and am told it doesn't do any harm. It shifts smoothly with no grinding. Also, I use only 1st, 3rd, and 5th gear when accelerating normally, I just wind it out a bit further, makes for easier driving.
  2. Nov 23, 2009 at 6:41 AM
    rutherk1
    rutherk1 ElPhantasmo&TheChickenRunBlastarama
    09 Silver TRD 4door
    It wont hurt anything. I always did it in my old manual trucks.
    As long as you do it right, it will be fine. There is a sweet-spot if you get the timing right where it will dump right into gear.
    Accelerate and get the revs up, let off the gas, dump into gear.
  3. Nov 23, 2009 at 7:52 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    What's the point of not using the clutch?
  4. Nov 23, 2009 at 7:55 AM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    It's just so cool :rolleyes:
    I did it all the time in my accord when I was 16, but now I don't need to prove anything to myself and just drive like a normal human being.
  5. Nov 23, 2009 at 8:06 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    its easy because on alot of trannies, 5th isnt syncronized. But why do it? if it "makes for easier driving" get an auto. Doing that will eventually round the "dogs/teeth" on the gears (what happens when you dont hit the sweet spot) and eventually the gears could pop out during normal driving. Reasons to be very careful buying used vehicles...
  6. Nov 23, 2009 at 8:10 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    that's just stupid... if you didn't need the clutch, toyota would have never put it there.
  7. Nov 23, 2009 at 8:16 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Concur- You won't get a transmission explosion or create a blackhole- but down the road your manual transmission won't stay in gear....It'll be a long way down the road- but it's coming.
    It's your truck...do whatever you want.
  8. Nov 23, 2009 at 8:23 AM
    BWro
    BWro Well-Known Member
    If you know what your doing, it will be fine. Macks and Kenny's have clutch's too.... only for first and reverse.....and those trucks get 800k + miles
  9. Nov 23, 2009 at 8:27 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    And they have professional drivers...and transmissions built with that purpose in mind....
  10. Nov 23, 2009 at 8:52 AM
    Yoytoda
    Roland
    completely stock
    Were talking about a little yota 5spd not a big rig...
    CDL here and i use the clutch...sometime you have to double clutch. Trannies in rigs are a totally different animal and a wee bit tougher. They are also super close ratio which makes it easier. I have shifted without the clutch in my peterbuilt but see no benefit. it goes into gear easier using the clutch so i use it.
  11. Nov 23, 2009 at 9:20 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    And that is a pretty ignorant statement, sir. Have you ever driven a heavy truck before, as in an eighteen wheeler? You dont use the clutch at all except for taking off. The op is refering to the same concept.
    Do I do it, no, but it is more than possible if you know what your doing without causing damage to the transmission.
  12. Nov 23, 2009 at 9:37 AM
    Yoytoda
    Roland
    completely stock
    Truck trannies are totally different they are not synconized and rely on a good driver to match engine and tranny rpms... cars/suvs/pickups are different, you need the syncros to line up the gears. except alot of older vehicles top gears arent syncroed but you need to match the rpms perfect. the rev range on a rig is 3000rpms maybe less (depends on tractor) the range on a tacoma at least double that making it harder to match the speed so you should use the clutch...
    Dont bring truck drivers into the mix because they use the clutch in their cars in every gear...
  13. Nov 23, 2009 at 11:48 AM
    SC4333
    Grant
    FL
    I realize a trucks transmission is not sycronoized and a pickups trasmission is, and the fact that the rpm range is twice as high, if not more making it much harder to shift without the clutch and not cause damage to the transmission. It is still possible if you are a good driver and know what you are doing. I drove a truck (recreationally to tow a race trailer) and put quite some miles on it. I hardly used the clutch except on take off and never once had a problem with the truck. The point is, it doesnt have to be done to prevent damage to the transmission. If you can efficently match the tranmission speed to the engine speed, there really isnt much of a need to use the clutch in any of the upper gears.
    Now if that truck was making a living for me, which it was quite the opposite for me, sure i probably would have used the clutch through every gear.. I chose the more convienant route and it served me well for many miles...
  14. Nov 23, 2009 at 12:04 PM
    Yoytoda
    Roland
    completely stock
    i hear the argument but it only takes once to screw up and bingo your grinding. for sake of arguing what kind of truck was it that you drove?
    Yes the clutch gets old quick when you have 13 gears to choose from or go through but seriously you need to shift without the clutch on a 5 speed?
  15. Nov 23, 2009 at 12:09 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    well then tell me why the clutch is there? big rigs have nothing to do with if it should be done in a pickup truck, someone mentioned they are built for it, our pickup trucks are not.
    big rigs still have the clutch because they need it for accelerating and the first few gears, in a pickup truck it's intended to be used throughout every gear, the people who figured out why we need it are much smarter than most of us here, so i trust them, and seeing as it's been like this for so many years, i don't think they are wrong.
  16. Nov 23, 2009 at 12:13 PM
    Yoytoda
    Roland
    completely stock
    Hes saying it can be done with no damage which is correct. But, if you do it wrong even once you can do some real damage.
  17. Nov 23, 2009 at 12:30 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    right, so my comment saying it's stupid, is valid. (although im sure someone was offended by my choice of words)
    your asking for problems down the road, because guaranteed you will mess up at some point if you do it all the time.
  18. Nov 23, 2009 at 12:34 PM
    Timicha
    Timicha Timicha
    TIM
    Tillamook / Portland , Oregon
    04 White Tacoma
    Fabtech 4 inch lift, tinted windows, diff drop, 33 inch MTZ tires on Raceline Raptor wheels, ELITE OFF-ROAD bumpers and sliders
    why not just push the clutch in, its not to hard :rolleyes:
  19. Nov 23, 2009 at 3:53 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Clutches in big rigs are designed to be double clutched, none are "made" to not use the clutch. Double clutch means you push in about 1/2 way to go out of gear, reclutch to go into gear. (all the way down is a clutch brake on commercial rigs and the reason a lot just skip the clutch)
    And yes you can drive them w/o clutching, but once again YOU HAVE TO HIT THE SWEET SPOT, and that wont pass you on a driving test.
    It seems professional to not use the clutch, like "look at me i got skillz", you better know what you are doing and what happens when you don't do it right. Tried it in my taco, it works, I still use the clutch though.
  20. Nov 24, 2009 at 8:08 AM
    SC4333
    Grant
    FL
    I hear you, and I wasn't trying to ruffle any feathers here, my point was that it is entirely possible without any damage to either types of transmission. Would I do this with my pickup truck on any kind of a basis? No. Have I? Sure I have.
    The truck was a 2004 Peterbilt 330 Toterhome w/ a 10 speed.
