Code P0430
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4x4jeep, Dec 24, 2011.
  1. Dec 24, 2011 at 1:01 PM
    4x4jeep
    4x4jeep [OP] Well-Known Member
    Kyle
    Destin FL.
    Is that the code for a bad gas cap?
  2. Dec 24, 2011 at 1:21 PM
    Cajun1
    Cajun1 Well-Known Member
    Brooks
    Abbeville, LA
    Brush Gaurd 265 Destinations 5100's @ 1.75 LED Lighting Center console Home made Saatchi DDM 5K HID
    google it!
  3. Dec 24, 2011 at 1:22 PM
    Cajun1
    Brooks
    Abbeville, LA
    P0430 OBD-II Trouble Code
    Technical Description
    Catalyst System Efficiency Below Threshold (Bank 2)
    What does that mean?
    Basically this means that the oxygen sensor downstream of the catalytic converter on bank 2 is detecting that the converter is not working as efficiently as it should be (according to specs). It is part of the vehicle emissions system.
    Symptoms
    You will likely not notice any drivability problems, although there may be symptoms such as a rough/hard idle when cold.
    Causes
    A code P0430 may mean that one or more of the following has happened:
    • The catalytic converter is no longer functioning properly
    • An oxygen sensor is not reading (functioning) properly
    • There is an exhaust leak
    Possible Solutions
    First, inspect for exhaust leaks.
    Next step is to measure the voltage at the oxygen sensor on Bank 2. In fact, it would be a good idea to test each oxygen O2 sensor while you're at it.
    One thing to note is that many vehicle manufacturers offer a longer warranty on emissions-related parts. So if you have a newer car but it's out of it's bumper-to-bumper warranty, there still may be warranty on this type of problem. Many manufacturers give a five year, unlimited mileage warranty on these items. It's worth checking into.
  4. Dec 24, 2011 at 1:27 PM
    4x4jeep
    Kyle
    Destin FL.
    Its an 06 and second owner so no warranty. Haven't found or heard any exhaust leaks. Guess I will start with 02 censors . Thanks for the input
  5. Dec 24, 2011 at 1:28 PM
    4x4jeep
    Kyle
    Destin FL.
    and the truck only has 65K miles the catalytic converter should still be good correct?
  6. Dec 24, 2011 at 1:30 PM
    Cajun1
    Brooks
    Abbeville, LA
    more than likely yes
    but i can assure that any OBD code you get is not a Bad gas cap..
  7. Dec 24, 2011 at 1:40 PM
    4x4jeep
    Kyle
    Destin FL.
    Hooked up my scanner cleared the codes and the light stayed off. Both oxygen sensors are show 0.00V?
  8. Dec 24, 2011 at 1:41 PM
    4x4jeep
    Kyle
    Destin FL.
    Happened to my moms trailblazer. The light would keep coming on until we replaced the gas cap. Some evap threshold below level or something like that
  9. Jan 5, 2012 at 8:19 AM
    Taco John
    Taco John Well-Known Member
    Illinois
    4X4
    You might want to check, but I think certain emissions systems (like cats) are covered for 8yrs/ 80k miles regardless of whether you are the first owner or not.
