Code P0441
Discussion in '1st Gen. Tacomas (1995-2004)' started by bsandb, Apr 8, 2010.
  1. Apr 8, 2010 at 1:26 PM
    bsandb
    bsandb [OP] New Member
    2002 Tacoma SR5
    I am getting P0441 code and I really need some advice. I have put a new gas cap on, but when I pull my truck into the garage there is an overwhelming odor of gas fumes. If I put the old gas cap on the odor isn't as bad. The vacuum lines appear to be OK. If I clear the code it will stay off for 4-6 days and then come back on. The truck idles different when the CEL is on. Any advice will be greatly appreciated. Thanks in adance!
  2. Apr 8, 2010 at 4:00 PM
    Coolidge
    Coolidge Well-Known Member
    So Cal, Ca
    2003 Pre Runner
    King coilovers frt +3". Bilstein 5100 shocks rear w/AAL, K&N FIPK, Magnablow exhaust, Billet grill, clear corner lights, Sony stereo, JBL, Sub etc.
    Put a factory Toyota gas cap back on. Make sure it clicks a few times. Then check. Fords are notorious for CEL from gas caps. Dunno 'bout Toyota though
  3. May 21, 2010 at 5:33 PM
    bsandb
    2002 Tacoma SR5
    I finally took the truck to the dealership and had them put it on the diagnostic machine. They told me that it was the vacuum valve assembly. They ordered the part and put it on, and now my check engine light is out. Hopefully the light stays out. The truck does seem to idle better.
  4. May 21, 2010 at 7:21 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    What is a vacuum valve assembly? Anyone know its primary function and where it is?
  5. Oct 5, 2010 at 1:04 PM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    I'm want to know as well. After I changed my O2 Senor from the p1135 my CEL has come on twice and the codes where p0441, 442, and 446. Stays off for 3 or 4 days and comes on again. No telling how long this was going on since my CEL stayed on for 3 years due to the p1135.
    Spicy__taco likes this.
  6. Oct 5, 2010 at 11:41 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Sounds to me like they're refering the EVAP purge solenoid. It's the valve that allows the engine to suck in the gas vapors from the fuel tank. The vapors get stored in the charcol canister & the valve lets the intake suck in the vapors. On many cars the charcol canister is under the car in the rear close to the gas tank but on our trucks it's located under the hood.
  7. Oct 6, 2010 at 12:28 AM
    TacomaDan
    TacomaDan Don't go off ninjin
    Daniel
    Woodland, CA
    1996 Toyota Tacoma Fully Not Loaded
    Love, Cobra 29 LTD BT CB w/ A2000 Highgear antenna, FOX/Fabtech Coilovers, Magnaflow
    I dont think that is it. I threw a P0446 took it to the dealer and had them fix it. It ended up being the charcoal canister and the valve assembly/solenoid or whatever is right there on top of the charcoal canister. There are 1.5 million valve assemblies on our trucks so its hard to say which. Just look for a new part on or around your truck, take a pic and send it to us. Maybe it could help some folks out.
  8. Oct 6, 2010 at 7:00 AM
    brelandt
    Terry
    Dublin, CA
    yes please. I need to register my truck here in california and I will never pass smog if I have a cel......
  9. Oct 6, 2010 at 7:17 AM
    98tacoma27
    Ben
    Not Beech Creek
    There could be one of many different issues to cause P0441/446.
  10. Oct 6, 2010 at 7:19 AM
    98tacoma27
    Ben
    Not Beech Creek
    The VSV for the EVAP is under the hood on a 3RZ and 5VZ.
  11. Oct 6, 2010 at 9:24 AM
    brelandt
    Terry
    Dublin, CA
    I'm hoping in my case it was just my gas cap. The last time I put gas in it I noticed it was harder to get the cap to click. Once I put the extra effort into it I got it to click twice. Use to just click 3 times no issue.
  12. Apr 6, 2011 at 9:07 PM
    SargeSlapnuts
    SargeSlapnuts SargeSlapnuts
    Nick
    Pooler, Ga
    2003 taco TRD off road 4x4 dbl cab.
    255/85-16 BF goodrich km3's, modified trail gear Bumpers front and rear, 10k winch, ranch rear lift shackles, Rancho coilovers in the front, grey wire mod, aftermarket stereo, camper top on the back.
    well this has been the code im getting and already bought a brand new toyota gas cap. guess ill check the vapor pressure switch next. good thread by the way.
  13. Dec 1, 2012 at 6:19 PM
    rubens281
    rubens281 New Member
    auto dr
    l.a.
    Tacoma 2000
    P0441purge flow insufficient my diagnosis was the vsv with the hoses.going to the manifold and charcoal canister tried activating with solus pro scan tool would not open put a,screw driver to it to listen to it is was ticking on off but not opening at all and problem fixed with new vsv
  14. May 7, 2016 at 2:47 PM
    foampile
    foampile Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    Do you know where that's located on the V6 2nd gen engine?
  15. Jun 28, 2023 at 3:15 PM
    Spicy__taco
    Spicy__taco Well-Known Member
    2002 radiant red Tacoma SR5
    Stock
    Long shot as for how old this post is but I am having the exact same set of circumstances, replaced o2 now have the same codes.
