code po301 and po300
Discussion in '1st Gen. Tacomas (1995-2004)' started by LHAHN07, Apr 4, 2008.
  1. Apr 4, 2008 at 5:35 PM
    LHAHN07
    LHAHN07 [OP] Active Member
    Pennsylvania
    02 Stepside TRD 4x4 SR5
    AEM intake, Magnaflow exhaust, Summit Racing leveling kit, Westin stanless steel Bull Bar, Line-X bedliner, B&M shifter, Performance Products stainless sidesteps, grey wire mod, more parts on the way!
    All right guys, I'm working on a 1999 Taco w/ a 2.7 engine... It came to my shop with a misfire and barely running. Scanned the computer and got codes PO301 and PO300. Replaced plugs and wires and reset memory, now I still have the codes and it doesn't run any better. And I do know it's not the coil packs. I don't know which way to go. This truck has 305,000 miles on it also. Any help would be greatly appreciated...:confused: :pray:
  2. Apr 4, 2008 at 5:41 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    The codes are as follows:
    P0300 Random/Multiple Cylinder Misfire Detected
    P0301 Cylinder 1 Misfire Detected
    Not sure if that helps you any, hope you get it all sorted out though.
  3. Apr 4, 2008 at 5:55 PM
    LHAHN07
    Pennsylvania
    I know the code definitions... Thats why I started with plugs and wires, and checked the coil packs.
  4. Apr 4, 2008 at 10:53 PM
    RaiderSix
    RaiderSix Well-Known Member
    Got good compression?
  5. Apr 5, 2008 at 6:20 AM
    LHAHN07
    Pennsylvania
    I haven't checked that yet. I wonder if the valve adjustment could be causing this???
