Code reader
Discussion in '1st Gen. Tacomas (1995-2004)' started by PROseur, Jan 26, 2017.
  1. Jan 26, 2017 at 9:07 AM
    PROseur
    PROseur [OP] Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    what's the most cost effective, good PVD code reader ?
  2. Jan 26, 2017 at 9:14 AM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Depends on what you mean by "good", or "cost effective". Believe it or not I have pretty decent results with the shitty Harbor Freight code reader. All it does is read/reset codes. No trouble shooting or messing with settings or anything like that, but it works. Basic as hell for $25 on sale. I keep it in the truck and don't have to worry about it if I ever lend it out.
    If I ever need anything better than that, I borrow my father's Matco, but I rarely need to.
  3. Jan 26, 2017 at 9:26 AM
    PROseur
    Pussy
    yeah I just need something simple to keep at home to read codes :)
    Thanks I will check the Hb one you linked
    GHOST SHIP[QUOTED] likes this.
  4. Jan 26, 2017 at 9:29 AM
    GHOST SHIP
    GHOST
    FWIW, give Amazon a look see. I'd stay away form the blu-tooth ones if you're going the cheap route. Cheap blu tooth never works right.
    PROseur[QUOTED][OP] likes this.
  5. Jan 26, 2017 at 10:40 AM
    Obsessed2000
    Obsessed2000 Just a big dummy
    NC/VA line
    2000 SR5 4x4 3.4
    Deck plate mod Bilsteins All pro leaf springs All pro greasable shackles Camburg UCA Interior Led conversion Tundra TRD springs Extended SS brake lines Seat covers 33" yokos White herculined exterior
    http://shop.advanceautoparts.com/p/actron-pocketscan-plus-cp9660/11022471-P
    The picture listed looks nothing like the actual product. What I did was buy this, plus a small item to bump the price over $100. Then use promo code TRT41 I believe. (which is $40 dollars off your purchase, only online)
    The little thing does everything I have ever needed it to do and cost me a whole $60 bux in the end.
    PROseur[OP] likes this.
  6. Jan 26, 2017 at 10:50 AM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
  7. Jan 26, 2017 at 10:54 AM
    PROseur
    Pussy
  8. Jan 26, 2017 at 10:59 AM
    JL911
    JL911 Psshh
    PA
    5 spd 4 bngr
    I've had this one for a few years and it works great. Easy to use and straightforward.
  9. Jan 26, 2017 at 11:03 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
  10. Jan 26, 2017 at 11:04 AM
    98tacoma27
    Ben
    Not Beech Creek
    I use the Ultra gauge.
  11. Jan 26, 2017 at 11:07 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Torque app for reader torque-app-1.jpg is free or the pro version is $5.
    elnip, cruiserguy and PROseur[OP] like this.
  12. Jan 26, 2017 at 11:29 AM
    PROseur
    Pussy
  13. Jan 26, 2017 at 11:30 AM
    TooMuchToDo
    TooMuchToDo Well-Known Member
    2002 Gold Tacoma XtraCab with 192k
    ...we'll get there.
    i use a cheap bluetooth module from ebay ($12 dollars a few years ago, probably cheaper now) blue, translucent plastic. and i use torque. i'm not super into paying for apps...but damn did they earn that $5.
    the plug in hand held units are pretty much only good for reading codes. the bluetooth ones can send constant data to your phone and check for codes. good for getting more info out of your vehicle. i'd say go that route.
  14. Jan 26, 2017 at 11:52 AM
    Cowboycq
    Cowboycq Active Member
    Cody
    96 2.7l 5 speed 4x4
    I have an IOBD2 from ebay. It's Bluetooth and seems to work good. Only had it a couple months. But it reads and clears codes can monitor different things while driving. Has a performance test to see how fast it will do in 400meters or 0-60 and things of that nature if u want. It's pretty cool to play with. Little slow to initially connect.
  15. Jan 26, 2017 at 12:15 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    exact same one I got in Dec '15. used it for my drive to Florida. It reads codes and sensors via the Torque App (Android)
    I also bought a right-angle pass through cable to leave the OBD2 port available and this plugs into the end and sits below the ashtray.
    unfortunately it says on the page not compatible with iOS. :(
  16. Jan 26, 2017 at 12:17 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
  17. Jan 26, 2017 at 12:39 PM
    PROseur
    Pussy
  18. Jan 26, 2017 at 12:44 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    np :)
  19. Jan 26, 2017 at 1:02 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    almost 8000 reviews 4.5 on the other, but the both look identical. One will only do android the other supports IOs
  20. Jan 26, 2017 at 1:06 PM
    mechanicjon
    Jon
    Scottsdale Arizona
