Codes for check engine light
Discussion in '1st Gen. Tacomas (1995-2004)' started by Strato, Feb 27, 2010.
  1. Feb 27, 2010 at 3:36 PM
    Strato
    Strato [OP] Active Member
    texas
    White regular cab
    Stock
    I had Autozone check ..heres what came up
    1. Air leak in exhaust before rear H025
    {Heated Oxygen Snsor bank 1
    2. AF sensor error
    3.Fuel system fault
    4.Faulty Catalytic converter
    Any ideas where i should start?
    Thanks
  2. Feb 27, 2010 at 3:40 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    hate to say it, but sounds like the catalytic converter may be the root of the problems, cause if its bad....it'll trigger those other codes.
  3. Feb 27, 2010 at 3:50 PM
    Strato
    texas
    White regular cab
    Stock
    Is that a shop repair?...and is it expensive?
  4. Feb 27, 2010 at 5:37 PM
    Idrivetoys
    Idrivetoys Well-Known Member
    Yuma AZ
    I need a 4 door DC 4x4
    find a high flow cat from like summit racing i think there usually like $100 and probably another $50 for an install. a Factory cat will probably set you back a few, this is all what im taking from memory but yes unless you weld its a shops job.
  5. Feb 27, 2010 at 8:59 PM
    pdxwhiteout
    pdxwhiteout monster taco in the snow
    coty
    pdx
    monster tacoma
    3-inch body lift, 6-inch fabtech lift, 17-inch procomp black alloys wrapped in bfg 37s. trd v-6.
    not to tuff to install at all. just a few nuts. make yor life easy, grab a can of wd-40, let the truck cool and bang it out. no sweat:D. dont forget to buy the gaskets too.
  6. Feb 27, 2010 at 9:00 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    x2....and get an o2 sensor sim from urdusa.com to turn of the cel.
  7. Feb 27, 2010 at 9:02 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Before getting a new cat, make sure there are no exhaust leaks first! Then check your cats or have a shop check them to see if there bad or working propertly. But the last thing and most commen, Is your o2 sensors. They usually go bad first..
  8. Feb 27, 2010 at 9:03 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Good news, after market cats are a quarter to a third the cost of a factory cat. The down side is they only last a couple of years compared to five to ten years.
  9. Feb 28, 2010 at 7:58 AM
    Strato
    texas
    White regular cab
    Stock
    Thanks e for all the tips...i think i will let my local muffler shop knock it out..im going to change that 02 sensor to..something else i notice last nite..i had it warming up in the drive and i could smell a strong odor coming from the exhaust...it was fuel related odor...
