Cody's 2002 build "The Tank"
Discussion in '1st Gen. Builds (1995-2004)' started by sk8rjess, Dec 6, 2012.
  1. Jan 6, 2013 at 7:51 PM
    #101
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    we mean full lock as in the steering wheel is turned all the way
  2. Jan 7, 2013 at 12:32 PM
    #102
    sk8rjess
    sk8rjess [OP] IG: @whoishack
    Cody
    Nashville, TN
    02 4x4 sr5
    some duct tape and zip ties
    ^my badddd!
    i did as much as i could last night before having to get some sleep. the driver side is about fully cut but now i know i still have alot more to do on the pass. ended up having to cut off about 1.5" off my sliders. i'll plate that later.
    i need to go pick up some more sheet metal on my lunch break along with cutoff wheels.
  3. Jan 7, 2013 at 1:59 PM
    #103
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Hey where did you pick up your Kragen 7" lights?
  4. Jan 7, 2013 at 2:16 PM
    #104
    sk8rjess
    Cody
    Nashville, TN
    02 4x4 sr5
    i bought the first one(that was on my bedrack) off some website. i know that doesn't help but unfortunately i don't remember where. it was like $130 at the time. the other one was bought at the same time as my 4" last year from a group buy on here
  5. Jan 7, 2013 at 3:26 PM
    #105
    Slodgetto
    Slodgetto Über Posre
    Silas
    Just curious, what gauge sheet metal are you using? What kind of welder do you have? I forgot what I used, and I'm trying to gather supplies... lol
  6. Jan 7, 2013 at 3:31 PM
    #106
    sk8rjess
    Cody
    Nashville, TN
    02 4x4 sr5
    uhhh i don't remember. i want to say it was .22 ga. i'm going to lowes in 30 for more, i'll let you know. i want more thin but i think the next thinnest lowes had was aluminum and stainless.
    i don't even want to tell what welder i'm using :/ Lincoln 110. and getting the settings right for this was such a PITA. i ended up tacking then silicone over it all(pass side)
  7. Jan 7, 2013 at 3:54 PM
    #107
    Slodgetto
    Silas
    Sweet thanks, man.
    and lolz! That's better than the 80 amp stick welder i used for my tub job!:eek: I'm actually very surprised my tubs haven't fallen off yet.. hahahahaha I didn't post up close pictures for a reason. :anonymous: I'll be using my Lincoln 125 for when I redo it... :eek: I'm sure yours will be fine, man. Using flux-core .30?
  8. Jan 7, 2013 at 3:59 PM
    #108
    sk8rjess
    Cody
    Nashville, TN
    02 4x4 sr5
    oh they'll be fine. i've done all my welding on this truck with it, and everything has held up perfectly fine time after time. just gotta make sure the penetration is good.
    nope, normal mig .30 weld wire. though i do have flux if i happen to need it.
  9. Jan 7, 2013 at 4:11 PM
    #109
    Slodgetto
    Silas
    Nice. Wish I had gas so I could use .25... seems like it'd be a lot better for such thin metal.
  10. Jan 7, 2013 at 4:48 PM
    #110
    sk8rjess
    Cody
    Nashville, TN
    02 4x4 sr5
    why would you want thicker wire for thinner mat? i always heard most people telling me to use higher gauge for the thinner stuff :confused:
    but the thinnest lowes sells in normal steel is .22ga. .26 i feel would be perfect though :\
  11. Jan 7, 2013 at 5:28 PM
    #111
    sk8rjess
    Cody
    Nashville, TN
    02 4x4 sr5
    haha you guys wanna see something funny?
    this is the most ghetto thing i've ever done. i needed more sheet metal earlier when i was working on tubbing and didn't have any other vehicle since everyone at my place was at work. so since i had to work i just used duct tape to seal the hole.
  12. Jan 7, 2013 at 6:26 PM
    #112
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Duck tape...
    It's like the force..light on one side and dark on the other and binds the universe together :cool:
  13. Jan 7, 2013 at 7:15 PM
    #113
    Slodgetto
    Silas
    hahahah nice! if it's stupid but works, it ain't stupid. :D
  14. Jan 7, 2013 at 9:51 PM
    #114
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    hey, at least now you know where to smash or cut more
  15. Jan 7, 2013 at 11:41 PM
    #115
    sk8rjess
    Cody
    Nashville, TN
    02 4x4 sr5
    i've got most of the rubbing on the driver side taken care of. had to grind the body mount back to the first bolt and i barely rub at full lock.
    so, no moving when i'm at full lock haha. i could trim a little more off but i'd also need to take some out of the cab itself where the mount is and i'm afraid of it losing structural strength. i'm debating on calling this side done and starting to plate it
  16. Jan 7, 2013 at 11:44 PM
    #116
    Blackdawg
    Monte
    Wyoming/St. Louis
  17. Jan 7, 2013 at 11:46 PM
    #117
    sk8rjess
    Cody
    Nashville, TN
    02 4x4 sr5
    haha i'll post pics when i figure out if i'm going to cut more or not. i may call it a night while i ponder and get back at it in like 5 or 6 hours
  18. Jan 8, 2013 at 12:40 AM
    #118
    sk8rjess
    Cody
    Nashville, TN
    02 4x4 sr5
    okay can someone give me a good reason to not tack weld this mount where the bolt should be?
    if i ever need it off i can just grind the tack off, though i never see a need there. i'm never going to do a body lift. i'm never switching cabs. i'm thinking of cutting that whole mount and basically just shaving the whole bolt hole. that would solve all my rubbing issues. OH and to add to all that, i'm sure i'll eventually design some mounts and redo it.. even if that's while i'm doing my SAS later this year.
    i'm taking a break for the night, when i wake up i'm going to work more on it.
    :notsure:
  19. Jan 8, 2013 at 1:25 AM
    #119
    Blackdawg
    Monte
    Wyoming/St. Louis
    i didn't plan on a cab swap either..yet..here i am..with a new cab..haha
    i wouldn't weld it personally. even though there would still be 4 other body bolts i just don't think thats a good idea..
    but go for it if ya want..
    will be a major PITA to relocate it. even just and and inch or so. The body is double layed metal from there back so would be tricy getting it just right i think. Not impossible though.
    if you going to move it..do it now. Might as well which its all cut up anyways.
  20. Jan 8, 2013 at 1:31 PM
    #120
    sk8rjess
    Cody
    Nashville, TN
    02 4x4 sr5
    HEY GUYS GUESS WHAT. one side is finally done!
    even though it doesn't look all that hot i i'm positive it'll work fine. i shaved the bolt on the mount and tacked it. oh well. if i need to cut it off eventually then i will.
    at full lock it just grazes the frame. i mean just enough to knock the mud off! and doesn't touch anything else. gotta get some more silicone today on my lunch break and finish covering it up. gonna hit it from the inside too just incase i missed a spot or the silicone somehow comes off.
