Coil Kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KDUB, Jun 15, 2010.
  1. Jun 15, 2010 at 5:13 AM
    KDUB
    KDUB [OP] New Member
    Alabama
    07 Pre-Runner
    Leveling kit
    I have added a 2.5" leveling kit on my 2007 Double Cab Tacoma. I still do not have enough space to add tires larger than stock 265's. I was advised to add a coil kit and I would gain another 1/2 inch. This would allow more space for larger tires. Any input would be appreciated.
  2. Jun 15, 2010 at 5:44 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup
    A few bolts are different.
    Do not add lift coils to your spacer lift. If I'm thinking correctly, maybe not it's early, Coils plus the leveling kit will net you a lift greater than 3". There are many reasons that will not be good.
  3. Jun 15, 2010 at 10:20 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    If you actually have a 2.5" lift kit, then you should be able to run a 285/75R16 with minimal to no trimming needed.
  4. Jun 15, 2010 at 10:54 AM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    If you have installed the 2.5" leveling kit correctly you will have the clearance needed to run a 285/75/16 with minimal issues. Too many people have done it, what type/brand kit did you use?
