coil over lift vs. coil lift
Discussion in 'Suspension' started by alexamado, Nov 10, 2008.
  1. Dec 12, 2008 at 1:54 PM
    basktaco
    basktaco Well-Known Member
    Bliss, Idaho.
    2012 SR5 DCLB
    duratracs/ultra phantom wheels/plasti derped all the chrome
    thanks longhorntaco. i appreciate all the help guys
  2. Dec 12, 2008 at 1:56 PM
    basktaco
    Bliss, Idaho.
    2012 SR5 DCLB
    do you guys think the 884s would be ok for my access cab or would the 885s be better?
  3. Dec 12, 2008 at 1:58 PM
    Neubs
    Neubs Sold my Tacoma. Goodbye TW.
    Maryland
    06 TRD Offroad DC 4X4
    ToyTec 5100 Bilstein Adjustable Coilovers w/ Eibach Springs | OME Darkar Leaf Springs | 5150 10" Bilstein Rear Shocks| Light Racing UCAs | All Pro U-Bolt Flip Kit | Timbren Rear Bumps | Extended Stainless Steel Rear Brake Lines | ARB CKMA12 On-Board Air Compressor | Method 16" Race Wheels | Goodyear 285/70/16 MTR | 48" Hi-Lift Jack | ToyTec Diff Drop | Warn Hitch Shackle | TRD Cold Air Intake | PIAA Intense White Bulbs | PIAA Silicone Wipers | Toyota Bed Mat |Sockmonkey Graphics | 20% Tint | Sport Hood | Scan Gauge II & Blend Mount | Shrockworks Sliders | ARB Bumper | Warn M8000 Winch | Viking Synthetic Winch line | 12-Volt Guy In-Dash Winch Controller | Viking Delrin Rollers | Daystar Winch Isolator| ARB/IPF 900XS Lights | Weather Tech Liners | Rock Lights | Diff Breather Mod | Extra Bed D-Rings | Misc. LED bulbs throughout
    Lots on conservation going on here. Chris, I think you about covered it with your solid explanations. Here are a few additional points.
    1. Adjust ability - The OME kit can not be adjusted with a spanner wrench where as the 5100 Coil over kit can be fine tuned to compensate for things like "taco lean" or the added weight or a bumper. I have my driver's adjuster side set about 1/2" higher than the passenger to make up for a bad taco lean. The result is that the truck sits perfectly level. This could not have been achieved with the OME kit.
    2. Warranty - The Bilsteins in the ToyTec kit come with a lifetime warranty while I believe the OME stuff has a 2 year/40000km warranty.
    3. If you order from ToyTec I can get you a discount so your price will be lower than $799.99
    4.Another less expensive option would be to buy the 5100 adjustable kit and the shocks separately and build the adjustable coil overs using your stock top plates. Hope this helps.
  4. Dec 12, 2008 at 3:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Actually, The OME springs when used with the OME shocks can be adjusted via a "Trim packer" Or Shim" that sits under the spring bucket on the shock. You can adjust from just under 1/4" on up to 3/4". I used 1 trim packer on the drivers side to account for the weight, and the truck sits dead level from side to side with a half tank of fuel. :)
  5. Dec 12, 2008 at 3:20 PM
    Neubs
    Maryland
    :) Cool!!! To clarify I meant adjustable with a spanner wrench and some strong muscles :). I edited my original post.
  6. Dec 12, 2008 at 3:21 PM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    And to clarify, strong muscles = He-Man muscles if you want to adjust those things while they're still on the truck... :)
  7. Dec 12, 2008 at 3:24 PM
    Neubs
    Maryland
    Hey how much do you bench? - Just Kidding. Ha ha ha
  8. Dec 12, 2008 at 3:25 PM
    LonghornTaco
    Minnesota
    not enough...
  9. Dec 12, 2008 at 3:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL! I always just remove them and separate the spring to adjust them. Its not worth the struggle to try and do it on the truck. IMHO. :)
  10. Dec 12, 2008 at 3:28 PM
    LonghornTaco
    Minnesota
    Yeah, when I had to adjust mine, I took them off.
    And once you get it down, adjusting them without relieving the spring tension isn't very difficult. Plus, since I don't have a wall mount compressor, it's kinda necessary... :)
  11. Jan 1, 2009 at 11:51 AM
    Alaskaflyer
    Alaskaflyer My other ride Hovers
    Cape Cod, MA
    08 Prerunner DC TRD Off Road
    OME 885 AAL, 2.5* shim, Light Racing UCA's. BFG AT KO 285/75/16, Spidertrax spacers, OME Shocks up front, Bilstein 5100 Shocks in back.
    Where do you get these trim packers?
    Thanks
    Gary
  12. Jan 1, 2009 at 1:46 PM
    Neubs
    Maryland
