Coil over question spring differences
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Specalt, Sep 23, 2011.
  1. Sep 23, 2011 at 8:38 AM
    Specalt
    Specalt [OP] Well-Known Member
    Phoenix
    2001 TRD 4x4
    I was wondering if any one knows the difference in the Tacoma coil over springs
    So there is the 3 different types off suspension(s)
    The SR5 (Stock)
    The Sport
    The TRD Off Road
    I would imagine that the get progressively more stiff between the 3 What I would like
    to know is the difference only the shocks or does the spring stiffness change?
    I am looking for a stiffer coil over with out gaining lift. As I add more and more
    to the truck I'm starting to sag. Bumper, wench and armor.
    Currently I have just the basic SR5 4x4, will putting say a set of TRD off road
    springs help? Or does any one know of a spring that is stiffer than stock with out gaining lift?
    I was looking at the OldMan 886's, but I don't want to gain the 2.5 inches over stock.
    Any input will help a lot.
    Thanks.
  2. Sep 23, 2011 at 8:46 AM
    85yote09taco
    85yote09taco Well-Known Member
    Eric
    York, PA
    Tacoma TRD OR
    3'' OME lift, TRD CAI, Built Right UCAs, 285 Goodyear DURATRACS, black steelies, Fog light anytime, DTRL, Alternating turn signal, Diff breather relocated, Carrier bearing drop, Weathertechs, Bestop, Extended SS brake lines, CBI Sliders w/kickout, Cab mount chop, Total Chaos LCA skids, All Pro skids, Satoshi(HomerTaco), Bruteforcefab ''HC'' rear bumper, Bruteforce Hybrid front bumper
    I'm not so sure about the correct answer that you may be looking for, however i think that most coilovers are adjustable. I have no experience with them as i have never owned a pair, in my setup i went with the 884 coils which will give you a lift and is not recommended if you plan on putting more wieght on the front.
  3. Sep 23, 2011 at 8:49 AM
    85yote09taco
    Eric
    York, PA
    Tacoma TRD OR
    oh i reread your post and just figured out what you are trying to achieve. i do not think that they are differant but never looked into it. however if someone else chimes in and they are indeed differant let me know as i still have my stock TRD OR ones.
  4. Sep 23, 2011 at 8:52 AM
    Specalt
    Phoenix
    2001 TRD 4x4
    I might have used the wrong wording, I guess I just mean coil springs and not coil overs.
    I think a more direct question would be:
    I don't want to add a lift to the front of my truck but I want to add a stiffer spring. Due to the wait of the bumper and wench
    what would be a good choice?
  5. Sep 23, 2011 at 8:57 AM
    Specalt
    Phoenix
    2001 TRD 4x4
    Thanks for the responses.
    Awesome info.
    Thanks.
    Oh and the (wench), I was pulling into my drive way and mother-in law stepped out in front of my truck. Needless to say I picked the added weight of a wench.
  6. Sep 23, 2011 at 9:17 AM
    Specalt
    Phoenix
    2001 TRD 4x4
    Great visual thanks.
  7. Sep 23, 2011 at 5:42 PM
    pmo
    pmo Well-Known Member
    Nova Scotia Canada
    2007 Tacoma 4x4, DC, 6 Speed Manual.
    My SR5 has the blue and yellow bilsteins and same coil springs as the TRD Off road, from the factory...maybe another difference between Cdn and US trucks....
  8. Sep 23, 2011 at 8:39 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Do some more research, but it is possible that OME 883 springs are higher spring rate but about the same length as your factory springs. (I've also seen something that said 883 springs are much longer but softer -- so be sure of your data; perhaps call Wheelers or Downsouth motorsports.
