Coil over question
Discussion in 'Suspension' started by 06hawkman, Aug 19, 2013.
  1. Aug 20, 2013 at 9:57 AM
    #61
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    Then you have to deal with the spring at full compression binding because its too long. KISS - 14" spring with an appropriate spring rate for your truck and you'll be fine.
  2. Aug 20, 2013 at 11:14 AM
    #62
    06hawkman
    06hawkman [OP] Active Member
    Tony
    salt lake city
    08 Tacoma OR
    custom exhaust
    ^ So how do you like your Kings? Do you have standard or heavier coils? How much lift did you gain? Is it harsh? Did you remove your sway bar?
  3. Aug 20, 2013 at 11:36 AM
    #63
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    OME coils are longer, and more robust. This is an example from a Prado:
    That's not necessarily true. If the spring and strut/shock on a coilover are paired up properly (OME for example) than the suspension will travel as it should without any ill effect, given the owner installs the proper bumpstop.
  4. Aug 20, 2013 at 12:07 PM
    #64
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    He initially said 2" longer and i interprited that as 2" longer than the common lift springs (14" @600# and 13" @ 650#). So I think we're on the same page
    I've had OME and now my kings and my fiance has icons. I really love my kings. I have the standard 600# springs and they're fine because my front bumper and skids are aluminum. My sway bar is off and probably staying off
  5. Aug 20, 2013 at 12:17 PM
    #65
    06hawkman
    Tony
    salt lake city
    08 Tacoma OR
    custom exhaust
    Why did you decide to replace the OME with kings? and are the Kings noticeably smoother than the Icons?
  6. Aug 20, 2013 at 12:22 PM
    #66
    YOTA LOVER
    NH
    Ahhh, my misinterpretation. We are on the same sheet of music.
    Aluminum bumper and skids? :jellydance:
    No sway, good man! Sway-less myself and never going back.
  7. Aug 20, 2013 at 1:51 PM
    #67
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    While I had my 09 I learned what I liked to do and when I traded it in for my '11 I built it to be better suited for what I like. It would be hard to compare mine and my fiances. Maybe that means they are close, but they're the DSM icons that aren't valved like normal icons. Only reason she wanted icons was because the blue kings "would clash with all the pink on my truck". I'm not a fan of the icon design or spring choice.
