Coil Questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bosshoag, Feb 24, 2014.
  1. Feb 24, 2014 at 5:35 AM
    Bosshoag
    Bosshoag [OP] Well-Known Member
    Mr. Doogan
    Virginia Beach, VA
    '20 4X4 TRD Off Road MT
    I'm here for knowledge folks, please feel free to inform me. Expedition Essentials Track Mount Weather Tech floor liners and window vents K&N air filter Summit Dakars in Matte Bronze -25 offset King suspension from Filthy Motorsports MESO customs white/red interior lights and MESO customs gasshole
    My goal is to keep a soft smooth ride similar to stock while lifting my Taco 2". What would be closest to that if I go with bilstein 5100's?
    884's?
    Eibach's?
    Or the preloaded factory springs?
  2. Feb 24, 2014 at 10:02 AM
    Bosshoag
    Mr. Doogan
    Virginia Beach, VA
    Does anyone have any knowledge or experience with comparing different coil springs?
  3. Feb 24, 2014 at 2:08 PM
    Bosshoag
    Mr. Doogan
    Virginia Beach, VA
    75 views and no suggestions?! I did just read that billies set at .85" and Eibach springs would be an excellent set up, far superior to preloaded '08 TRD Sport coil springs and billies set to 2.25. Also that you should never set billies to 2.5" with a "lift spring" like Eibach's. Any thoughts? Or further info?
  4. Feb 24, 2014 at 2:14 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    884's and billies @ 0
  5. Feb 24, 2014 at 2:20 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    This is absolutely true. Never use a LIFT COIL and adjust the billies.
    One or the other.
    Lift coil + billies at ZERO (or stock)
    Stock Coils + billies set to your desired lift
    Why? Too much preload & pressure. A long time ago, I've seen what a LIFT coil and a coil spacer can do - and that's blow out the lower coil seat on the strut.
  6. Feb 24, 2014 at 3:52 PM
    Bosshoag
    Mr. Doogan
    Virginia Beach, VA
    Hey thanks for the input guys!
    So 884's and billies set at zero will be about 2.5" of lift and ride smooth like stock? I don't want my new truck to ride really rough. That's the goal here.
  7. Feb 24, 2014 at 3:55 PM
    OZ-T
    Peter North
    British Columbia
    2"
    That's what you said in the OP
    and they aren't going to ride like stock
  8. Feb 24, 2014 at 8:06 PM
    Bosshoag
    Mr. Doogan
    Virginia Beach, VA
    well whats the stock TRD Baja suspension? isn't it equivalent to a 2" lift? It must be a similarly smooth ride compared to bone stock TRD Sport but taller right?
  9. Feb 25, 2014 at 3:55 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    I went from stock straight to Toytec coilovers preset at 2.5" and rode equal to better than stock. No change in ride when I upgraded tire size to 275/65/18 Dynapro ATMS in a P-metric. Now ride is a tad stiffer but still smooth going to 285/75/16s Rocky mountains due to AT D load tire. Keep in mind the rear lift and shocks will have quite an effect on ride quality too. An AAL will ride stiffer than stock vs. a full soft riding leaf pack. I temporarily ran 1.5" block for the rear with no change in ride quality but it did wear out my factory springs and gave me an occasional axle wrap 'clunk'. My full leaf pack eliminated that.
