Coil spacer vs. Bilstein 5100
Discussion in 'Suspension' started by Justinclark19, Oct 4, 2011.
Coil spacers vs. Bilstein 5100
  1. Bilstein 5100
    93.5%
  2. Coil spacers
    7.0%
  1. Jan 5, 2013 at 7:27 AM
    #41
    Techy
    Techy Well-Known Member
    Montrose, CO
    06 trd off road dbl cab
    What would be better...
    5100's set to 2.5 or set to 1.75 with a spacer to get you to 2.5"?
    I ask cause I hear the 5100's ride rougher at 2.5.
  2. Jan 7, 2013 at 4:27 AM
    #42
    4banger09
    4banger09 Well-Known Member
    Alex
    Nb, Canada
    09 Tacoma Access cab 4cyl
    Leveled
    With the spacer in there is will ride rougher aswell so just save some money and set it at 2.5 or go get some new springs and achieve the lift that way
  3. Jan 26, 2013 at 9:08 PM
    #43
    mainewoodsballer
    mainewoodsballer YESSAHBUD...heyut
    Ol' Waltah
    Maine
    2015 DCLB TRD Sport (Pyrite Mica)
    Check out my Build to See!
    Billys Coil over adjustable set at 2 and rear all
  4. Jan 31, 2013 at 2:29 PM
    #44
    rob1
    rob1 Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
    :lalala: (i never lifted my truck but I want to everytime....I read threads.....need to ......stop....reading.....:lalala:
  5. Jun 6, 2013 at 10:14 PM
    #45
    Arhernan13
    Arhernan13 New Member
    San Diego
    13 DCLB
    What lift height do ou have?
  6. Jun 8, 2013 at 2:07 AM
    #46
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    i have my 5100s set to 2.5" and they ride pretty nice.. little stiffer than stock, but controlled.
  7. Jun 11, 2013 at 3:45 AM
    #47
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    It will ride rougher than stock but still like a truck should. You can go with oem linear springs off base model shocks with the lift and it'll ride a bit smoother or go with aftermarket coils and small to no lift on 5100s. The thing that'll irritate you going 2.5 will be the lack of caster without getting UCAs to get caster back. The wandering without enough caster will be worse than the ride with TRD progressive coils and 2.5 on the 5100s.
  8. Jul 25, 2013 at 4:43 PM
    #48
    Bearcoatoffroad
    Bearcoatoffroad Well-Known Member
    Barry
    Rincon, GA
    '07 TRD Off Road 4x4 Double Cab
    2.5" spacer lift, Tundra wheels with spacers
    I have a crap lift... 2.5? 3"? Front spacers with 1" rear blocks, stock bilsteins... I bought it like that, Absolute junk.
    300-350lbs in the back driving to Maine last month, literally rear end bottomed out and front topped out over every large over pass on the freeway. You can hear the upper ball joints slamming at the end of up travel every time.
    I don't think people realize the issue with front spacers, they cause the front struts to act as bump stops (they are not designed to take nearly that kind of force), and they cause the top ball joints to bind in top of travel. Real bad situation, I honestly think they should even make them.
    I am going after replacing rear blocks with AAL and good shocks first, then saving for front ICON's or similar and UCA's.
  9. Oct 5, 2013 at 7:37 AM
    #49
    902taco
    902taco Active Member
    JG
    Dartmouth, NS
    07 4x4 AC SR5 6-speed
    K&N CAI, Bilstein 5100s, PIAA 540 driving lights, American Eagle 146 16x8x5.50 wheels, ECGS front diff bushing
    I had originally lifted my 1st gen Tacoma with coil spring spacers in the front and the ride was so stiff I bought new complete coilovers as soon as I could afford it. This gave me a much better ride and I liked driving the truck again.
    I've now got 5100s on order for my 2nd gen to level it out. Coil spacers are junk in my opinion.
  10. Oct 24, 2013 at 7:29 AM
    #50
    902taco
    JG
    Dartmouth, NS
    Installed my front bilstein 5100's over the weekend set at 0.85" of lift and the ride didn't stiffen enough to notice. The dampening is much better than stock though. Measurements from wheel centre to fender are 21-5/8" for the front and 22-3/4" in the rear.
  11. Dec 31, 2013 at 1:30 PM
    #51
    specialized7
    specialized7 Well-Known Member
    ,Saskatoon, Canada
    05 v6 4x4
    I have installed both 3" coil spacers and bilstein 5100's.
    The coil spring with the spacers was a PITA to install... Think 10' 2x4 as leverage on the lower control arm to get the bolt holes lined up.
    The height looked great... Rode like a pile of shit and the Upper control arm rubbed the coil springs when going over bumps.
    I bought 2 front bilstein 5100's from Essex distributors(canada) for $99 each shipped.
    removed my old springs and put them on the 5100's. No more clunking and a much better ride... sure i lost half an inch but It was well worth it. Also no more rubbing the coil spring.
    Hope this helps you make your choice.
  12. Jul 7, 2014 at 5:20 PM
    #52
    D.Holliday
    D.Holliday Well-Known Member
    Jon
    Portland, Oregon
    2008 Tacoma DCSB TRD Sport SR5 4x4
    Extang Trifecta Tri-Fold Tonneau Cover|Pioneer AVH-P1400DVD|3" Revtek Lift w/AAL|Pro Comp 7069|285x70r17 Federal Couragia MT's|Extra D-Rings Mod|Anzo Black Headlights|Corbra 75 CB w/3' Cobra Antenna & 4' Firestix Antenna|DTRL's Mod|L.A. Angels Sticker Mod|Smoked Aftermarket Tail lights
    I know this is an old thread, but I don't understand why people think the 3" Revtek rides so rough? Of course I'd LOVE to have Bilstein 5100's eventually and plan to some day soon strictly due to it being better mechanically wise for your Tacoma's components, but the Revtek isn't THAT bad. Honestly, if my suspension were any smoother I'd probably fall asleep at the wheel every time I drove it. Is it a Caddy? No. Tank? Definitely not. It's fairly cush compared to some lifts I've had on vehicles before and they were coil-overs. Will I say its an amazing quality lift? Absolutely not, but its not a tank by any means.. Not ruffling feathers though, just putting in my experiences.
    Maybe I'm just partial cause I am ex-military and I know what riding in a tank truly feels like... :D:p:rolleyes:
    Anyways, I'll now let this thread fade back into thread abyss..
  13. May 11, 2016 at 6:59 PM
    #53
    CMD531_TRD
    CMD531_TRD Member
    Clovis, CA
    If I install the bilstein 5100, will I need to adjust the length of driveline or front diff?
  14. Apr 15, 2017 at 4:21 PM
    #54
    MojoOffRoad
    MojoOffRoad New Member
    2007 Tacoma DBCLB
    2.5 Inch front spacer lift and 2 inch rear block with Zone Shocks
    What is the ride quality like if I switch from my 2.5 inch spacer and a billy 5100 set at 2.5, spacer is just killin me, every drain or hole in road feels like truck has no shocks
  15. Apr 15, 2017 at 4:26 PM
    #55
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
    Necroposting?
