coilovers AND spacers
Discussion in 'Suspension' started by yotanation29, Jun 13, 2012.
  1. Jun 13, 2012 at 7:01 AM
    yotanation29
    yotanation29 [OP] Well-Known Member
    ADRIEL
    CHULA VISTA
    98 TRD
    all pro upper a arms, icon extended travel 3", bumper cb, clarion nav, and much more to come!!
    right now im running 3' icon extended travel coilovers on my 98 taco, but now i want it to be a little bit higher, but my icons are awesome so could i maybe use regular spacers to get that extra inch/inch and a half of lift? i know itll fit, the real question is will it affect the ride and performance or would it just be best to get new higher coilovers?
  2. Jun 13, 2012 at 7:12 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If your coils are cranked all the way up, it might be time for new coils (not knowing how old they are). Personally, I wouldn't stack lifts, maybe look into taller coils and I'm not sure at what point you'll have issues with a 1st Gen and require a drop bracket style lift. Also, over 3" of lift your CV joints will hate you assuming you have a 4x4, unless you're considering going with a drop bracket lift.
  3. Jun 13, 2012 at 7:22 AM
    yotanation29
    ADRIEL
    CHULA VISTA
    98 TRD
    well i got all pro upper a arms right now and the lift isnt all the way up, it goes up to 3.5" but i figured cranking it all the way up would only make it worse if i stack lifts. and theyre fairly new, less than a year of use
  4. Jun 13, 2012 at 7:29 AM
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    why not just crank them up a little bit and call it good? i wouldn't put spacers with that nice lift
  5. Jun 13, 2012 at 7:50 AM
    jsmarine
    jsmarine Well-Known Member
    Jeff
    Dallas, TX
    2005 Tacoma SR5 Crew Cab 4x4
    ARB front & rear lockers ARB bull bar Warn XP9000 winch IPF lights
    3 inch lift up front is MAX without going to a drop bracket lift. Unless you want to replace CV axles often...
    If you really want another inch or so, look at a 1-2 inch body lift.
  6. Jun 13, 2012 at 10:22 AM
    yotanation29
    ADRIEL
    CHULA VISTA
    98 TRD
    Thats a good idea, probably what I'll end up doing then
