cold air intake problems
Discussion in 'Technical Chat' started by lane338, Jun 24, 2007.
  1. Jun 24, 2007 at 11:02 AM
    lane338
    lane338 [OP] New Member
    I have 2007 tacoma 4x4 4.0 liter. I bought afe cold air intake and put on my truck. The check engine light came on immediately and it runs bad and shifts bad. The dealership reset the light and even replaced the mass air flow sensor
    three times but the light came back on immediately.
    Any help out there?
    Thanks
    Lane
  2. Jul 1, 2007 at 8:27 AM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    Before you install the intake, you're supposed to remove the negative battery terminal. If you do that, that will help your computer learn the new air system quicker, in about a couple days. Usually takes about a tank of gas if you don't remove the negative battery terminal. It shifts early/late because its still used to the amount of air it was receiving before.
