Cold air intake
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Johnny2525, Mar 20, 2014.
  1. Mar 20, 2014 at 2:42 PM
    Johnny2525
    Johnny2525 [OP] Well-Known Member
    California
    '14 TRD OFF ROAD DCSB
    ICON stage 3 suspension kit, Amp Research retractable steps, LED interior lighting, headlights, fog lights, MB wheels, FlowMaster exhaust. Rigid Industries back up lights, aFe Cold Air Intake with URD MAF sensor Calibrator
    Anybody running one of systems? I have a 2014 prerunner. Is it worth it?
  2. Mar 20, 2014 at 3:34 PM
    OffsetPlayer2
    OffsetPlayer2 Cornbread fed
    In the woods and fields, NC
    17 DCSB Off Road 4wd
    Weather Tech floor mats
    I don't have one so I can't speak from 100% experience on these on a Tacoma, but expect to gets lots of replies stating that "your truck already has a built in one", "your factory one is better", and all that good jazz. Pretty much comes down to personal choice on if you want to hear it often or not. Also, be sure to check if it'll pass the smog test since it looks like you're from California.
  3. Mar 20, 2014 at 3:36 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    There you go.
  4. Mar 20, 2014 at 3:39 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    If you want one then buy one! Personally I would splurge for an AFE prodry filter instead to save tons of money.
  5. Mar 20, 2014 at 3:41 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I have the original TRD CAI (similar to AFE Stage 2). I believe it's the only one dyno'd to have a very slight increase. It's all preference. I like it as it allows for better pedal feel though not smog compliance.
  6. Mar 20, 2014 at 4:25 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Unless you have a supercharger with greater than stock boost you will see almost zero gains. Stock intake is a cold air intake, with cruising intake temps only a degree or two above ambient.
  7. Mar 20, 2014 at 4:36 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    I've heard both sides - some say it does nothing, some say try gain a few horses and MPG from it....I would def keep researching prior to coming to a decision
  8. Mar 20, 2014 at 4:37 PM
    Faryota
    Faryota Well-Known Member
    Mic
    Ridgefield, WA.
    13, 4x4, long bed, Sport, Debad
    6" BDS lift in front, warn winch, AFE cold air intake & exhaust, Body Armor Rear bumper, Tuffy in bed storage box, DZ bed mat, ARB front bumper & Warn winch w/light kit, Husky floor mats, dash mat,
    I have a AFE cold air intake and exhaust!!! It shows a gain of 39 hp & 51 torque...I think just never buying a air filter is worth it!!!!
  9. Mar 20, 2014 at 5:06 PM
    TheGrayRider
    TheGrayRider MARANATHA !!!
    NW Florida
    2017 BBP DC 4X4 OR
    I have a K&N 63 on my 2011 and had one on my 2002
    Over 170,000 miles on my 2002
    Over 75,000 on my 2011
    Properly serviced it works fine ... I never had any issues with MAF sensor covered in oil or dust in the intake pipe past the K&N filter
    Whatever you decide just ensure you know how to properly service the filter
    My Ultraguage readout keeps me from pushing the gas pedal too far so I'm getting around 21mpg
    increase or decrease in mpg will vary depending on how you drive
  10. Mar 20, 2014 at 5:38 PM
    Rsoxfan1
    Rsoxfan1 Well-Known Member
    Mass
    2012 DCSB TRD Sport 4x4
    What shows that gain??
  11. Mar 20, 2014 at 5:42 PM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    It makes absolutely 0 difference other then sound.
  12. Mar 20, 2014 at 5:46 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    A lot of guys just do the deck plate mod. If you feel like cutting a hole in your factory air box.
  13. Mar 20, 2014 at 5:47 PM
    SoCaltaco65
    Except he has a pre-runner and a 4.0 Liter?
  14. Mar 20, 2014 at 6:07 PM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    Your truck already has a built in one, your factory one is better
  15. Mar 20, 2014 at 6:21 PM
    SoCaltaco65
    nope, not true at all, the stock box has acustic plenum that gives the waves some place to be absorbed and pulled from the main body of air.
    and the stock box pulls just as much air as a an after market CAI.
    in my sig also has a link to a gent that tested air filters including cotton types, the benefits are not worth the risk of less filtration.
  16. Mar 20, 2014 at 6:51 PM
    1tacoplease
    1tacoplease I like my truck!
    Temecula
    2008 BSP 4x4 6 speed
    265/70/17 BFG RT's, FJ 17" rims with 1.25" spidertraxx Debadged, HID's, URD short shifter, Bilstein 5100's in the front, TSB and 1" block rear, URD TCAI with maf calibrator, JBL long tubes, DT Y pipe, Gibson exhaust, Walbro 255 fuel pump, Pioneer stereo, Bak flip G2 tonneau, TRD skid plate, MB Quarts all around with dynomat, Viper Alarm with motion sensor
    I'm running the URD TCAI and I felt a difference right away. The intake temps did run around 25°lower than stock. I also coupled it with the URD MAF calibrator and it feels like a V-tech pull in the higher RPM's. I haven't fine tuned the calibrator yet but I know it will make a difference and then*I*can give you guys a dyno.
  17. Mar 20, 2014 at 6:56 PM
    dad32509
    dad32509 Thinking of something clever
    Dave
    San Diego
    Blacked out 05
    5100's front and back, OME 885x's, LR UCA's, OMD rear springs, Pioneer AVH-P2300DVD, HVAC Green led's MOD, Blacked out bumper, Plastidip emblems, custom front tube bumper, 32" combo led bar, rigid duallys, otrattw switches, my own Satoshi grille, shorty antenna, Spyder LED halo headlights. csjumper2003 map/dome, 3rd brake, DTRL white/amber and parking LED's. Pelfreybilt IFS skid, Cab mount chop, sliders and rear light bar w/blitzpro 5LR dust light. Uniden CB, Magnaflow 18" exhaust, Rear tire carrier, sway bar removed, spidertrax 1.25" spacers, Wheelers 16" Alloys w/265/75r16 Goodyear DuraTracs
    I had a k&n 63 series and my throttle body and maf sensor got coated in grime within a couple months. Got rid of that and got the afe stage 2 si with pro dry filter. The afe ran a lot cleaner than the k&n but I didnt see a difference in anything. My mpg actually went down a little and I didnt see any improvement in hp. The stock intakes on the tacomas are pretty nice
  18. Mar 20, 2014 at 11:47 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
  19. Mar 21, 2014 at 12:39 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    URD is also proven
    I disagree on the n/a vs f/i claims and there is dyno proof out there, but i agree COMPLETELY on the temperatures. Stock will pull ambient at approx 40MPH and can be easily measured.
    Great info..... OP, do plenty of homework here and on http://www.xr-underground.com
    dyno slip?
    incorrect, and theres dyno proof
    he has a 2014
    incorrect, the stock 1 is restrictive on the 4.0..... the design of the intake with its baffles, chambers, and bends in order to muffle the sound also costs some performance.
    Gadget ran his xrunner on a dyno with the stock setup as a baseline.
    Then he ran it without the charcoal trap....NO GAIN
    Then he ran the truck with no air filter, and no charcoal trap....NO GAIN
    Now we have dynos with the AFE "TRD", and the URD with.......GAINS
    The 25 degree drop must be at idle, because the stocker pulls ambient air at approx 40 MPH. I have measured with 3 different gauges.
    Ive tested this with these setups and all got to ambient temps at approx 40MPH.
    • BONE STOCK
    • AFE STAGE 2Si (plug in)
    • AFE STAGE 2 SI (plug out)
    • AFE stage 2 Si (plug out AND removed washer fluid tank and have a mesh grille with functional triangles as well as hole cut in radiator support from the URD).
    • URD with shield
    • URD with no shield
    again, all pulled ambient temps at cruising. the only way to drop below ambient is basically an icebox.
    Ur MAF calibrator is leaning out the fuel in open loop and YES, this is giving you less stumble and waking up the engine.... Just be careful on hot days if going up any large grades.... You can only run so lean.
    yes, Ive also had the MAF cal and installed a couple others.....Never run 1 again without being able to flip a switch and disable it.
    K&N are supposed to flow great, but at the price of filtering.....ya just cant have the best of both worlds. Ive also seen a handful of K&N slimed maf sensors, even if they have never been oiled by the owner and were straight from K&N... They can come over oiled.
    Make sure u clean the MAF sensor and your throttle body after that K&N gummed crap up. Then you MIGHT see some MPG improvement from the AFE (and then again maybe not).
    As for a "HP improvement", well thats gunna be so minute that Id only trust a Dyno.
  20. Mar 21, 2014 at 3:46 AM
    RogerRZ
    RogerRZ Well-Known Member
    New Brunswick, Canada
    White '14 DCLB TRD Sport
    I have a home made one:
    Seat of the pants dyno feels a 14.5hp gain...
