Cold air intake
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacomaboy12, Jan 31, 2016.
  1. Jan 31, 2016 at 7:43 PM
    Tacomaboy12
    Tacomaboy12 [OP] Member
    Lincoln, il
    02 Tacoma 2.7L SR5
    What's the best cold air intake for the 2.7?? What's everyone's thoughts
  2. Jan 31, 2016 at 7:49 PM
    Tacomaboy12
    Lincoln, il
    02 Tacoma 2.7L SR5
    I've heard a lot of guys talk about the deck plate mod. I wanna start with the air filter first then deck plate got a few other things to do to it first
    Coils,fuel filter,exhaust leak,vacuum leak somewhere.
  3. Jan 31, 2016 at 10:42 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    IMHO, the stock cold air intake is best. It draws air from the outside.
    So-called aftermarket 'cold air' intakes draw hotter air from under the hood, sometimes from directly above the extremely hot exhaust.
  4. Feb 1, 2016 at 4:39 PM
    CStoy
    CStoy mountain-top maniac.
    majestic gold 4x4... 1/4 million miles and counting!
    improved toyota goodness.
  5. Feb 1, 2016 at 8:24 PM
    Tacomaboy12
    Lincoln, il
    02 Tacoma 2.7L SR5
    What brand of coils do you recommend?? And what brand of cold air intake?
  6. Feb 2, 2016 at 1:41 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    ^^^agreed! Youve already got a cold air intake on there OP and the deck plate will just negate that feature...
  7. Feb 2, 2016 at 2:56 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    It is possible to have aftermarket intake with washable non-oiled filter that breathes thru same spot as oem.
  8. Feb 2, 2016 at 2:36 PM
    CStoy
    oem denso's i got mine at advance auto -but you may be able to find the same cheaper online...i seem to recall Amazon haveing them for about 30$ less than what i paid...
    as for the deck plate being a negative; seems to read about 7-9 degrees colder air coming at the same outside temperature vs. stock or with the plate in place. it is also reading more atmospheric air pressure (-8psi vs. -11 psi @ 60mph ) at speed than stock or closed with sensor in the ''box'' location (box removed) on the intake tube.
  9. Feb 2, 2016 at 2:48 PM
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    You already have cold air intake.
