Cold Air Intake?
Discussion in 'Performance and Tuning' started by Krystal32490, May 4, 2016.
  1. May 4, 2016 at 1:52 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Gives you a washable non-oiled filter...............drop-in or not
  2. May 4, 2016 at 1:58 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    I've heard good things about the AFE dry drop in by itself.
  3. May 5, 2016 at 4:51 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    It's what I have in the oem intake box in the attic. It was fine but...........
    I didn't like the Volant intake nor the K&N by themselves for different reasons so I combined the best things about both of them and ended up with better looking less clompy cluttered underhood with sealed clear lid filter box breathing thru oem fenderwell spot and a washable non-oiled filter with more sound. Something not found on every other truck is just extra plus. Truck loves it, it tells me so and that is what matters most............
    Jbleezie86 likes this.
  4. May 5, 2016 at 7:36 AM
    Nighthawk
    Nighthawk 'streme spoats
    Levi
    Casper Wyoming
    2008 Red TRD OR AC V6
    Bilstein 5100's w/ Eibach coil overs in front (set at 3" of lift). Front diff drop kit. Extended Bilstein 5100's in the rear. Deaver 2" AAL in rear w/ axle shims. 285 x 75 r 16 Goodyear Duratracks. Wheelers steelies type B, AFE cold air intake. Sway bar delete. All Pro Apex front bumper (rattle canned Rustoleum primer + flat black). Plasti-dipped emblems. Mud flaps removed.
    That dry filter is the bomb. I had an oiled K&N on my 95 pickup and it was the nastiest POS. Too much time wasted cleaning off all of the grime it attracted.
  5. May 5, 2016 at 7:51 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    This is funny. You don't need an air filter anyways, just remove it.
    Mr.PowerTrays likes this.
  6. May 5, 2016 at 8:03 AM
    Nighthawk
    Levi
    Casper Wyoming
    According to digitalbravos logic, the engine always takes how much air it needs regardless, so you might as well just tape over the intake :)
  7. May 16, 2016 at 10:39 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Some are better than others. @Krystal32490 , Validated dyno's are in my signature. Best one will be the AFe, whom also used to make the 1st Gen TRD intakes for the 2nd gen Taco's.
    Laminar flow. All about the laminar flow. That is where the AFe improves over the flow of OEM. Both are sealed in an ABS plastic to abate heat saturation, and keeping IAT's as close to ambient as possible, through all driving conditions.
    Some people have even adapted the Volant scoop to the AFe.
  8. May 16, 2016 at 11:20 AM
    ABA180
    East Bridgewater MA
    Torspd, just the AFE dry drop in help over stock?
  9. May 19, 2016 at 10:05 PM
    Talbott24
    Talbott24 Active Member
    Talbott
    2009 White Tacoma SR5 DCSB
    Window tint and 265 70 r16 Mastercraft courser MSR tires
    Honestly the stock intake is fine. But I got the K&N washable filter, does seem to breathe just a little better and my fuel economy went up by about .6mpg
  10. Jun 15, 2016 at 1:41 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    I was going to go for the cool factor but decided to save my money. Went with AFE drop in instead. I may take out the charcoal filter.
  11. Jun 15, 2016 at 2:32 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    All K&N cold air intakes do is let more dirt into your engine and cost you money.
  12. Jun 15, 2016 at 2:42 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    If you want the best out of a cold air intake you need to keep the air flow at the throttle body at or near outside ambient air temp . This can be done by sleeving the intake tube with heat barrier wrap to keep air temps cooler
    Also placing the filter in a high press area to get the airflow as strong as possible into the filter
  13. Jun 15, 2016 at 2:43 PM
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
  14. Jun 15, 2016 at 2:46 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Not if you run a K&N filter sock over the filter media . Ever see a dirt Sprint car with a filter sock ?? , I've never seen dirt inside the Airbox of a Sprint car
    I'm running a K&N filter sock on my K&N CAI on my 2002 2.7 4cylinder Tacoma .Also I run the filter dry as a wet filter is like running a fatter fuel mixture
  15. Jun 15, 2016 at 2:56 PM
    #35
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Ever thought of getting air into the motor from the cowl ?? Cut a hole in the firewall that accesses the cowl area . This would create a ram air effect ,only thing is filter placement or location
    Think of how a NASCAR Cup car gets air into the motor , yep thru the cowl as it is a strong high pressure area
    Look at this mfg ..... http://www.ramairbox.com
    MadDaddy[QUOTED] likes this.
  16. Jun 15, 2016 at 3:14 PM
    #36
    cosmicfires
    David
    Everett, WA
    I've never heard of filter socks, sounds like a good idea. The dyno tests I've seen of K&N CAIs there was no significant increase in horsepower, something like 1-2 hp out of 150 hp which is probably within the uncertainty of the testing equipment.
  17. Jun 15, 2016 at 3:16 PM
    #37
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Wrap the intake tube with heat resistant sleeving and watch those hp#'s increase drastically !!!!
    Like mentioned I've got a 2.7 4 cylinder and it's making alot more than 150hp . It has a TRD Supercharger , K&N CAI , Doug Thorley header and 2.5" exh with 3" dia Spintech race muffler
    Torspd likes this.
  18. Jun 15, 2016 at 3:19 PM
    #38
    cosmicfires
    David
    Everett, WA
    When I see the dyno test results I'll reconsider, butt dyno doesn't count.
  19. Jun 15, 2016 at 3:24 PM
    #39
    Clearwater Bill
    Billy
    Largo Florida
    None. You already have one. Just keep the filter clean/replaced, based on either a normal maintenance schedule or sooner if you drive in harsh conditions.
    Nope. Unless lightening your wallet helps MPG. But since no one pays with cash anymore, I guess that's out.
    No see, wasn't that a much nicer set of answers than all the gibberish that went on above? :anonymous:
  20. Jun 15, 2016 at 3:28 PM
    #40
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    The rule of thumb is basically 1% hp increase per 10 deg drop in air temp
    So let's say you can get a 15deg cooler intake charge that's an easy 22.5 hp increase
