cold engine start clicking noise, what is it?
Discussion in '1st Gen. Tacomas (1995-2004)' started by paulmars, Jan 22, 2016.
  1. Jan 22, 2016 at 3:55 PM
    paulmars
    paulmars [OP] Well-Known Member
    I replaced my fuel filter on my 2004 2.4L tacoma 2wd. 65k miles. At the same time I
    checked the valves. No valve adjustment needed. Now I hear 4 to 6 rapid metallic clicks when i start the engine cold. Once it happened when it was warm. This fuel filter is not originalequipment.
    ideas?
    tks,
    pa
  2. Jan 22, 2016 at 6:00 PM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    I had a similar issue with a different car and it ended up being a bad battery. And just the clarify, the clicking sounds I was hearing was not the same sound you hear when your battery is drained and not able to turn the crank, the engine started every time.
  3. Jan 22, 2016 at 7:15 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Is it cold where you live? Maybe it's just a dry valve train on startup. Mine does it pretty often in winter on cold nights because the oil drains down into the oil pan overnight and gets really cold so it takes it a couple seconds longer to circulate on startup making a few rapid rattles before quieting down. Although when it's warmer out it never makes any rattles on startup. I just assume it's normal, and Toyota engines have never been known to be the most quiet either.
  4. Jan 22, 2016 at 7:33 PM
    paulmars
    central florida.
  5. Jan 23, 2016 at 12:01 AM
    2004TacomaSR5
    Jon
    Montana
    Hmmm, well does it get cold there this time of year? I've only been to Florida in the summer and that was in Melbourne where my sister in law lives and she claims it gets really chilly because of systems and wind that come off the ocean. But then again, she's the type of woman who bundles up in a parka when it's 60 degrees outside!
  6. Jan 23, 2016 at 5:26 AM
    paulmars
    me too:
    70s here now
