cold engine starting difficulties
Discussion in '2nd Gen. Tacomas (2005-2015)' started by raffy, Apr 3, 2008.
  1. Apr 3, 2008 at 10:01 PM
    raffy
    raffy [OP] Member
    Toronto
    08 TACOMA TRD
    Hi everyone,
    My first taco trd 4x4 4L 2008 6 speed manual transmission having a problem at cold engine starting, more than three or more revolution before the engine start.
  2. Apr 4, 2008 at 4:50 AM
    flavalk
    flavalk 2-Broke 2-Care
    Orlando, Florida via Huntsville, Alabama
    '07 PreRunner SR5 Double Cab 2WD - Short Bed - Automatic- Silver Mica
    Not much. Toyota bed mat, Toyota step bars, tinted windows, Toyota seat covers, Toyota all-weather mats, quart of Wild Turkey in the glove box, KelTec PT3AT in the center console, backseat full of old speeding tickets
    Deleted post...bad info
  3. Apr 4, 2008 at 4:50 AM
    squad314
    squad314 Thinks he's Steve McQueen
    Marc
    Into the mystic....(foggy Saint John, NB)
    2018 TrD Sport Upgrade
    "Hello Kitty" steering wheel cover.
    Mine acts the same way sometimes and another guy who has the same truck at work said his seems to turn over longer at times.....Never been a problem,but I've definitely noticed it.
    Enjoy your new truck and before you know it you won't notice it anymore.
    Edtited to add...I didn't know there was TSB's for this...^^^^
  4. Apr 4, 2008 at 5:22 AM
    flavalk
    Just realized that one of these apply to the V6 and the other for earlier models. Sorry, nevermind :rolleyes:
  5. Apr 4, 2008 at 6:03 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    mine cranks for awhile too, alot more than other trucks I've owned. Nice to hear its sorta common.
  6. Apr 4, 2008 at 12:41 PM
    BLOCKADE
    BLOCKADE Well-Known Member
    TRD Off Road
    Weather Tech Floor Liners, Front Bed D-Rings...
    I was having the same problem. I live in North Texas and when it got colder the truck started taking longer to start up. I called the dealer and let them know what was going on. The service manager asked me what grade fuel I was using and I told him Super. He suggested I switch to regular for the winter, he said super has been known to cause longer starts in the winter. I switched to regular and haven't had a problem since.
  7. Apr 4, 2008 at 1:21 PM
    no_werries
    no_werries Well-Known Member
    Simcoe County, Ontario, Canada
    2005 4x4 reg cab Indigo Ink 5 speed
    CAI, 2 1/2" rear lift AAL, Ready Lift strut ext. & diff drop = 2 1/2" front lift, tweaked clutch, Magnaflo Muffler & Custom exhaust 265/75/16lt Nitto Terra Grappler 8ply on stock rims. Huskyliners
    Hmm, this is kinda unrelated, i bout a 2005 reg cab 4x4 from florida ( I live in norther ontario, canada -40c on the worse of days) and the thing starts fine, even though i heard rumours (think their bogus) about the trucks being manafactured in southern states have less insulation on the wires and such things like alttenators are different like i said bogus rumours, but U cant hold me to that!
  8. Apr 4, 2008 at 2:55 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    take it to the dealer and get the ecu reflashed....should help out....per tsb.
  9. Apr 4, 2008 at 10:40 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    the other day mine kinda scared me with this. usually is takes like 3-4 revolutions before it starts, but the other day it didn't start like usual. then i cranked it for another good 5 seconds straight before it finally fired. kinda weird too because it was like 50 outside and usually its pretty much the same regardless of the temp.
  10. Apr 5, 2008 at 11:32 AM
    Labatt 50
    Labatt 50 Active Member
    Montreal,Qc,Canada
    06 Access cab 4x4 4cyl
    DRL,weathertech floor liner and bug deflector
    My 4cyl also had problem to start(slow cranking) and a lot of noises apeared after engine running at cold temperature. First I was desapointed because cold start my taco sound worst than my 320 000km mitsubishi .I have flush the oil (cold)and noticed it was very viscous,it was the oil used by the previous owner in NH.(always changed at the dealer)
    I have change the oil for 0w30 and it has cut a lot the noise and cranking needed before starting at cold temperature.
  11. Apr 5, 2008 at 11:34 AM
    TACOROCK
    TACOROCK Well-Known Member
    FAYETTEVILLE NC
    06 TACOMA LIFTED
    URD SUPERCHARGER 80MM PULLEY, DOUG THORLEY LONG TUBE HEADERS, MODIFIED Y-PIPE, TRUE DUAL EXHAUST MAGNAFLOW 2 IN 2 OUT, PRO COMP 6" LIFT, WIDEBAND 02/FUEL SENSOR, AVIC D3, 2 PIONEER SUBS ON A MEMPHIS 1200 WATT AMP RMS, DIY MOD FOR ALL INTERIOR SPEAKERS FULL TINT, LEER CAMPER, EURO LIGHTS, BILLET GRILL, BULL BAR WESTIN RUNNING BARS, AIR HORN, AND A RADIATOR POPPER
    upgrade your starter wire and or your battery
  12. Apr 5, 2008 at 1:45 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Yeah once and a while mine will do that, but it always starts. :D
  13. Apr 5, 2008 at 2:15 PM
    gdawg25
    gdawg25 Zoom-Zoom
    Victoria, BC
    '08 Mazdaspeed 3
    I have noticed mine does that from time to time. It has happened in the cold and when it is warm, so I don't think it is temperature related.
  14. Apr 8, 2008 at 5:13 PM
    Labatt 50
    Montreal,Qc,Canada
    I don't need to upgrade starter and all wires are like new. It was just a problem of viscosity and probably this engine was more noisy because if I'm right it as a timing chain.
  15. Apr 8, 2008 at 5:39 PM
    waynea4
    waynea4 Active Member
    Western N.C.
    Red 08' Double Cab TRD Sport 4X4
    I noticed that my truck did the same thing, several turns of the starter before it would fire. Seems fine though.
