Cold Start Noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by addg9e, Sep 12, 2008.
  1. Sep 12, 2008 at 6:21 AM
    addg9e
    addg9e [OP] New Member
    Burlington, Kentucky
    07 Off Road SR5
    I have a 07 Dbl cab Trd when I go to start it in the morning it make a knocking sound on the passenger side for only a second . Then when Iam backing out of the drive the exhaust make a fluttering noise only when its cold and only when Iam backing up . I have taken it to two Toyota dealers
    one said to use synthetic oil which I all ready do and one told me it was my tires , which I find that just out of the question since this truck has only 27000 miles on it and I have had it since it was new . I then went and call Toyota customer service and got a case number and ever thing and made another appointment which I had to ride with the head of service and the dam truck didn't do it for him . He told me that the exhaust on the Tacoma is so thin that you can some times here it in the cab well I think that is just bull shit when it makes the noise it is loud . I was wondering if anyone else is having the same problem?
  2. Sep 12, 2008 at 11:35 AM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    I've had the same damn thing going on now and can't figure out what it is. I thought it was the air conditioning but does it with or without AC on cold starts.
    Keep us posted on what Toyota says i'd love to figure out what it is and have them fix it.
  3. Sep 12, 2008 at 11:39 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    is the sound coming from under the truck by any chance?? check the backing plates by the rotors, one could be bent a little and catching on something, and also, maybe check the airbox, something could be loose around that side and hitting against something. let us know what you find.
  4. Sep 12, 2008 at 3:58 PM
    TacoNut
    Adam
    Denver, Co
    but if something was catching on the backing plates or something was loose wouldn't it be on all starts and not just cold starts...
    i'll try to take a vid of it tomorrow so yall can hear it
  5. Sep 12, 2008 at 4:03 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    hard to really tell man. hope you get if figured out pretty oon.
  6. Feb 5, 2009 at 5:00 AM
    ballon78
    ballon78 Well-Known Member
    Amesbury, MA
    06 CC SR5 TRD
    Mine does the same thing, so this morning (4 degress) i found that the top plastic engine cover that says vtti on it rattles on the left if your looking at the engine, almost right where the airfilter is, just tap on the cover and you can make the noise, once it warms up the plastic doesnt vibrate a bad. I took some sticky weather stripping and installed it on the intake plentum and hoping this fixes the noise. Also where the air box intake tube goes into the pass. side fender it hits and vibrates a bit, so i took a small hose and cut it the long way and installed it on the fender all around the round opening in the fender.
  7. Feb 5, 2009 at 8:39 AM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Cold weather seems to create more noise problems. Maybe its just a seasonal thing? Once it warms up it will go away and then come next winter just expect it.
  8. Feb 5, 2009 at 8:41 AM
    bobwilson1977
    bobwilson1977 Well-Known Member
    KaliFORN-I-A
    96 Tacoma 2WD ( pizza delivery model)
    none except for crappy hub caps and floor mats.
    Since its cold, it could just be the short time it takes for oil to get to the lifters, valves, etc. I have an old Mercury that does this no matter how warm.cold it is. It was common back then. I wouldn't worry about it.
  9. Feb 7, 2009 at 1:08 PM
    ballon78
    Amesbury, MA
    06 CC SR5 TRD
    Its not an engine problem, its a vibration between plastic and plastic on the engince cover and plastic on metal where the air intake goes into the fender, fixed min 2 days ago and its quiet now. Its been 0 degrees for the last few mornings and no more vibration.
