Cold start problems?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 00tactrouble, Dec 24, 2010.
  1. Dec 24, 2010 at 4:06 PM
    00tactrouble
    00tactrouble [OP] Active Member
    South Texas
    2000 Toyota tac prerun
    New Dakota A/T tires in 31x10.50-15", 2 coat Rhino Liner on the the bed, Mossy Oak package interior, 8" bazooka system pumping my jams, Platinum system plugs underneath the hood with Gates belts keeping it turning, 6" deckplate mod and amsoil is keeping this thing lubed year around.
    Hey TW, I have a 2000 yota with a v6 3.4 with 162,000 + miles in and just recently it started missing when I start it. Early in the morning it is the worse, it will not stall that long once you get up and go it goes away, but once it sits for an hour or so it acts up. I recently changed plugs (1 month ago NKG with wires) I replaced fuel filter (wix) and run high octane with lucus treatment. If anyone has any info please help me out, thanks.
  2. Dec 24, 2010 at 4:20 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Open the hood when you first start it when its cold and dark outside and see if there is any spark jumping at the plug coils/wires.
  3. Dec 24, 2010 at 4:23 PM
    98tacoma27
    Ben
    Not Beech Creek
    Did you use this type of plug?
  4. Dec 24, 2010 at 4:40 PM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    I have herd your problem happening if your oil is to thick. If your not using 5w-30 oil this may happen. The w in the 5w means winter for the cold.
    twfsa probably has the fix for your problem.
  5. Dec 24, 2010 at 8:46 PM
    00tactrouble
    South Texas
    I am using the NGK platinum, it is a single and the tip is pen point thin. I am using amsoil 10w30 because of the high milaege. I had never thought about my oil being to thick, but will take that into consideration. No spark when I open the hood at night, the only spark I saw was the neighbor blazing with his wife....
  6. Dec 25, 2010 at 12:17 AM
    YotaComa
    YotaComa Well-Known Member
    NorCal
    2004 Tacoma Double Cab
    With the 3.4 motor, you should always run a plug with dual-leads.
    NGK makes the standard replacement, and also theLaser Platinum model has dual leads too.
  7. Dec 25, 2010 at 7:13 AM
    98tacoma27
    Ben
    Not Beech Creek
    ^^This^^
    The 3.4 will run like sh*t with out the dual ground. I suggest this to be the problem. Easy fix is to swap them out will OEM replacement (you can get at any local auto parts store) then wait and see.
  8. Dec 25, 2010 at 7:25 AM
    twfsa
    Tom
    Omaha Ne
    04 TRD 4X4
    Let us know if the plugs fix the problem.
  9. Dec 25, 2010 at 2:14 PM
    00tactrouble
    South Texas
    Thanks guys I will try a different set of plugs asap. I am also going to clean the injectors as soon as the holidays are over.
