Cold start whine.. normal thing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Brauhlen, Oct 11, 2019.
  1. Oct 11, 2019 at 8:00 PM
    Brauhlen
    Brauhlen [OP] Member
    2007 tacoma double cab trd offroad
    1st real freeze with my truck, and when i go to turn her over, she begins to whine nice and loud at me till i warm her up nice and good. Sounds like my lady.
    Seems like it might be coming from the front driver side of the engine, down by the compressor. Is this typical or may i have a pulley going on me soon... any thoughts?
  2. Oct 12, 2019 at 4:49 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    Hard to diagnose without a recording/video but a simple fix would be to check your serpentine belt. Have you recently replaced your belt in the past few years? Now might be the time to swap it out. Mine is starting to squeal in the early mornings when the truck is wet from dew or after a rain.
    -J
  3. Oct 12, 2019 at 5:03 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Mine does that also for about 5 seconds.
  4. Oct 12, 2019 at 11:05 AM
    JC15Taco
    JC15Taco Well-Known Member
    Jeff
    SK, Canada
    '15 TRD DCLB
    Pretty normal, I think. Mine does it too, and so did my '04 Gen 1
    Jeff
  5. Oct 12, 2019 at 11:39 AM
    RoastyToastyMan
    RoastyToastyMan Well-Known Member
    Jayme
    2010 White Tacoma TRD Offroad
    I get whining when it cold or cold and wet. I'm pretty sure it's a pulley bearing. Only lasts a few seconds and goes away. When it's warm the sounds is gone.
  6. Oct 12, 2019 at 2:58 PM
    Fish Taco 4x4
    Fish Taco 4x4 Well-Known Member
    NC
    2013 TRD OR
    265/70/17s
    12-15s whine on start up due to the air injection pump (emissions thing). Sounds like a vacuum cleaner
    Alexely999 likes this.
  7. Oct 12, 2019 at 7:43 PM
    Brauhlen
    I'm thinking it's a pulley beginning to show signs of wear. Wasn't able to hear it this morning for more than a few seconds, not enough time to zero in on, but the sound whined on and off for a few seconds then went away.
  8. Oct 12, 2019 at 7:58 PM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Completely normal. It's the secondary air thingy.
  9. Oct 12, 2019 at 8:01 PM
    Gerard6778
    Gerard6778 Well-Known Member
    Gerard
    2015 TRD Sport
    If you can, post a recording of the sound.
  10. Oct 12, 2019 at 10:33 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    first thing I thought of too. If that’s what op is describing, normal.
  11. Oct 13, 2019 at 4:11 AM
    JustAddMud
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    If @Brauhlen bio is current, they are listed to have an 07. I wasnt sure that the 07s had the secondary air injection, I thought that system was introduced with the 12's+ but I may be incorrect. Furthermore, OP described that the sound seemed to be originating from the drivers side front where the secondary air is found on passenger rear corner. I understand that sound does crazy things inside the cab of a vehicle so I just based my hypothesis based on the info I had at hand. If I were to attempt to pinpoint the origin of this mystery sound based on pulleys, either the alternator or possibly water pump?
    -J
    Alexely999[QUOTED] likes this.
  12. Oct 13, 2019 at 7:30 AM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    The secondary air pump shouldn't make a whining noise (I have a 2012 and it doesn't whine...even when the temps are in the teens and twenties).
    I'm betting it's a pulley failing and causing the belt to squeal.
  13. Oct 13, 2019 at 8:06 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Unplug the alternator connector with the engine running and see if the noise goes away
  14. Oct 13, 2019 at 8:53 AM
    Brauhlen
    I tried to catch it in sub freeing temp this morning, but it was nowhere near as cold as Wednesday in UT. Was able to get a couple seconds of the sound, yet can't seem to directly link the vid through my galaxy 6. File over 20 mb. Better method available? Almost uploaded to youtube but got sick of hunting for the file upload tab.
