Cold, won't shift
Discussion in '1st Gen. Tacomas (1995-2004)' started by betardfoosier, Nov 4, 2010.
  1. Nov 4, 2010 at 6:16 AM
    betardfoosier
    betardfoosier [OP] Well-Known Member
    Kansas
    2000 TRD SR5
    3" Skyjacker, 33x10.50 AT/TAs
    Last couple mornings have been in the low 40's where I live, and when the trans is cold in the morning, it will NOT shift into any gear. It takes me a minute or so to get it into first, then its really tough in all gears till I go a couple miles. This morning, I had to start in second, because first was completely inaccessible. After it warms up, shifts perfectly. :confused: Clutch does not slip, 100,000 miles on truck. Taking truck into shop on monday to replace front cv boot, Guess I will have them check the tranny too. :(
  2. Nov 4, 2010 at 9:18 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Drain the trans and go with a synetheic, gear oil, would be my first move.
    750ml likes this.
  3. Nov 4, 2010 at 9:19 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    x2 redline mt-90
    Xbeaus and 99SuperTaco4x4 like this.
  4. Nov 4, 2010 at 9:38 AM
    betardfoosier
    Kansas
    2000 TRD SR5
    I do have a gallon of mt-90 that just showed up yesterday, do you really think it will make that drastic of a change? Seems like a mechanical issue to me, Feels like I don't even have the clutch in. Just will not go in.
    750ml likes this.
  5. Nov 4, 2010 at 9:39 AM
    98tacoma27
    Ben
    Not Beech Creek
    Have you checked the clutch fluid?
  6. Nov 4, 2010 at 9:41 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    well the fact that it does fine when warm makes me think changing to mt-90 will help a lot.
    def check all the clutch components though (pedal free play, fluid level).
  7. Nov 4, 2010 at 9:55 AM
    kws129
    kws129 Well-Known Member
    PA
    TRD Off Road Double Cab
    I had the same problem when I changed the gear oil in my 1st gen one time. I changed it with regular gear oil, couldn't shift just as you describe. Drained it again and went with Amsoil Severe Gear.....ouila problem solved and shifted better than ever.
  8. Nov 4, 2010 at 10:03 AM
    JBear
    JBear Spiral Out... Keep Going!
    Orange County, CA
    2003 Extra Cab 5 spd 4x4 TRD Off-Road
    2" suspension lift with King Coilovers up front. Standard Bilsteins on rear with a Fabtech 1.5" AAL. Leer 100XL Shell.
    Im having the exact same issue, only mine has only been happening up in the mountains. I thought it had to do with the altitude, but now that you mention it, it's been in the low 40's both times when it happened to me... are you any higher than 7500 ft or so?
  9. Nov 4, 2010 at 11:17 AM
    betardfoosier
    Kansas
    2000 TRD SR5
    Nope, I'm in Kansas. My clutch is fine, I can hear my kanky input bearing come to a stop when I put my clutch in. I will dump my MT90 in and see what happens. Thanks guys!
  10. Nov 4, 2010 at 11:21 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    cool deal, mine shifts great even when its 15* out with the synthetic.
  11. Nov 4, 2010 at 12:23 PM
    JBear
    Orange County, CA
    Ima give that shot too... thanks guys.
  12. Nov 7, 2010 at 1:18 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    It is the fluid!!! When trans warms up, oil gets more viscus(sp).
  13. Feb 9, 2011 at 8:25 AM
    TuffTruck
    TuffTruck Member
    Virginia
    98 Tacoma 4x4 3.4L, 3" lift & 31's
    3in lift, 31x10.5 BFG AT, K&N Cold Air, Flowmaster Exhaust
    Great old post! I just bought my truck and they must of warmed it up REAL good before I came over to test drive it and buy it. The next morning it wouldn't go into gear until hot!
    Do I have to do the transfer case too when I do the trans? I can only find 3 quarts of Redline MT90 locally. That's enough to do the transmission but I need another 1.2qts to do the transfer case.
    Oh yeah my current transmission fluid in the dark grey/black! Yuck!
  14. Feb 9, 2011 at 8:38 AM
    tacomaforlife
    tacomaforlife Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    ive gotta change my trans fluid because every time i start my truck cold and go for a drive it doenst wanna shift gears, it drags them out but once it warms up it shifts fine but gets annoying after awhile.
  15. Feb 9, 2011 at 8:53 AM
    maconhurler
    maconhurler Well-Known Member
    Harrisonburg, VA
    04 4wd v6 sr5
    Deckplate Mod, Catz Fog lights, Roll Top Tonneau Cover, Pioneer Premier 800prs HU, 10" Kicker L7, Kicker 5 1/4 components, Polk dB 5x7s, Oznium superflux puddle lights and bed lights
    Had the same issue myself. Often skipped second gear on cold mornings due to impossible shift. Changed the fluid to something from Advance Auto and it was just as bad. Ordered Amsoil Sever Gear and that has helped significantly, although on mornings in the teens it can still be a little rough. After the first shift into second, from there out all shifts are smooth as silk.
  16. Feb 9, 2011 at 8:56 AM
    tacomaforlife
    Robbie
    AIKEN, SC
    so the amsoil sever gear is what i would need
  17. Feb 9, 2011 at 8:59 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    I have mobile 1 75w-90 in the transfer case and both diffs. The only thing with mt-90 is the tranny.
  18. Feb 9, 2011 at 9:03 AM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    Seems weird 40 degrees isnt that cold. My manual transmission gets a little hard to shift when its below 0 but once it runs for a few mins and I start driving it loosens up.
  19. Feb 9, 2011 at 9:04 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    x2, its my battery that has trouble at those temps lol
  20. Feb 9, 2011 at 9:04 AM
    tacomaforlife
    Robbie
    AIKEN, SC
    yea but autos are a little diffrent i think.
