Cold, won't shift
Discussion in '1st Gen. Tacomas (1995-2004)' started by betardfoosier, Nov 4, 2010.
  1. Feb 9, 2011 at 4:16 PM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    But at 40 degrees? Never heard of such a thing. It can drop to 40 in the summer time. Seems like something else going on to me.
  2. Feb 10, 2011 at 4:10 PM
    TuffTruck
    TuffTruck Member
    Virginia
    98 Tacoma 4x4 3.4L, 3" lift & 31's
    3in lift, 31x10.5 BFG AT, K&N Cold Air, Flowmaster Exhaust
    Hey guys a big thumbs up to those that recommended switching over to Redline MT90 for the manual transmission fluid!
    I bought my truck a couple days ago as I mentioned and little did I know it would only shift easily when it was hot. I found out this the next morning when it was about 30 outside . Well yesterday it stopped going into gear altogether unless you rev'd it above 3k and man handled the shifter!
    Last night I drained the old transmission fluid and transfer case. I filled them up with Redline MT90 which is synthetic too I might add. I also flushed my clutch master cylinder because that brake fluid was black! And a buddy suggested changing it.
    No test drive over night I let it get nice and cold in the 20's over night. This morning I warmed the truck up to operating temp and drove off. It went into every gear slick as snot! I drove the truck to a few stops I had to make some city some highway. I shifted great all day, warm, cold, and hot.
    Thanks!
    750ml likes this.
  3. Feb 23, 2011 at 9:49 AM
    maconhurler
    maconhurler Well-Known Member
    Harrisonburg, VA
    04 4wd v6 sr5
    Deckplate Mod, Catz Fog lights, Roll Top Tonneau Cover, Pioneer Premier 800prs HU, 10" Kicker L7, Kicker 5 1/4 components, Polk dB 5x7s, Oznium superflux puddle lights and bed lights
    It made a huge difference for me.
  4. Feb 23, 2011 at 10:08 AM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    always drive/shift slower to start out with when it's cold out
    also don't shifter higher than like 2500/3000 rmp for the first while
    much easier on the tranny with the thicker oil
  5. Mar 7, 2017 at 4:56 PM
    Trask97140
    Trask97140 New Member
    Trask
    2004 Tacoma 4x4 TRD V6 Manual
    Im still having the problem in the mornings. I changed fluid out to Redline MT90. Almost seems worse than before. First and second gear are very hard to get into. Once it warms up(few miles down road) shifts flawlessly. Could it be a fluid level problem? I put the recommended in...
    Thanks,
    Trask
    wow this is an old post! haha. REVIVE.
  6. Mar 7, 2017 at 8:52 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Usually when it's cold I let it "fall" into the gear when shifting, basically equivalent to rev matching. As the RPMs drop between shifts, just give it a little pressure and it'll drop into place when the tranny and engine speed sync up. Plus it's easier on the synchros
    Das it mang and cruiserguy like this.
  7. Mar 7, 2017 at 10:47 PM
    gearcruncher
    Canadain bumper technician
    If your clutch master cylinder as well as slave cylinder fluid is black , its a sign of the internal seals wearing . Brake fluid in the clutch master also oxidizes over time .
    Hows that shifter bushing ? A very common problem is the shifter bushing .
    Marlin Crawler . Guys are saying this bushing is much stronger than the factory bushing . Also stands to reason that if your changing the bushing , you might as well change the transmission fluid and transfer case if 4X4 . It,s so much easier filling the transmission through the shifter hole and it only uses 2.3 quarts . This is going to save you from trying to use a flimsy pump underneath the truck .
    https://www.marlincrawler.com/transmission/shifter-parts/heavy-duty-sockets
    750ml likes this.
  8. Mar 9, 2017 at 8:30 AM
    Trask97140
    Trask
    Thanks, Appreciated. Everything seems clear and in good shape. Ill just make a few slow and easy shifts in the mornings.
  9. Mar 9, 2017 at 8:35 AM
    robupstateny
    robupstateny Well-Known Member
    Rob
    Upstate NY
    2003 Lunar Mist Tacoma DLX
    Gray wire mod, Gentex 177 mirror, cupholder from @bradrn22, custom dog seat., AJT Design shift knob., Cb install
    Do you let the truck warm up at all? or just jump in and go? I found letting it warm up for a few mins on a cold morning helps a great deal. Also just changed to the MT-90, first trip out WHAT a difference already. Going to try to change the front diff today, only thing left on fluids.
  10. Mar 9, 2017 at 10:52 AM
    Taco_4x4_Guy_
    Taco_4x4_Guy_ Member
    USA
    2017 Toyota Tacoma DC TRD Off Road Premium
    3" Toytech Lift, Toyota Billstein Shocks, TRD Pro Grill, 18" Fuel Rims with 285 65 R18 Cooper Discovery SST Tires.
    It is always a good idea to let your truck warm up in the morning regardless. I start mine up about 5 minutes before I leave every morning (or any time I start it after it has been sitting for a long period of time).
  11. Mar 9, 2017 at 11:27 AM
    Trask97140
    Trask
    Yea ive never given myself that time in the morning unless my windows are frozen over. Ill have to make a mental note to give it 5-10 in the winter months
  12. Mar 9, 2017 at 11:28 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    I dunno, there's a lot of info from the experts online saying anymore than 30 seconds is a waste. The old days, yeah carbs needed a few minutes to warm up. But with these modern engines it's just not necessary. At least for the longevity or benefit of the engine, the data just doesn't support the 'warming up for a few minutes' argument. Now, if you like your car toasty, more power to you. Go for it. Just isn't necessary for your engine well being. It'll warm up quicker and more efficiently just letting engine warm up as you drive 'mindfully' until operating temp is reached.
    750ml likes this.
  13. Mar 9, 2017 at 11:31 AM
    robupstateny
    Rob
    Upstate NY
    It isn't to warm the interior up, It's to let the fluids in the transmission and such get a chance to get moving and warm up.
  14. Mar 9, 2017 at 11:33 AM
    cruiserguy
    Elijah
    SEKS
    In that case, anything more than 30 seconds is unnecessary.
    99SuperTaco4x4 likes this.
  15. Mar 9, 2017 at 11:37 AM
    #35
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I'm not sure if the tranny will warm up if it's just sitting. I always thought you had to get moving to get the gears moving and warm. Unless we are talking about residual heat from the engine or something
  16. Mar 9, 2017 at 11:43 AM
    #36
    cruiserguy
    Elijah
    SEKS
    It does need to be moving to warm up the transmission fluid. It won't pump unless moving, if automatic, or won't splash unless moving, if manual.
  17. Mar 9, 2017 at 11:59 AM
    #37
    robupstateny
    Rob
    Upstate NY
    OK seems I know nothing about the subject so I'll leave you all to argue this amongst yourselves
  18. Oct 31, 2020 at 1:10 PM
    #38
    Dufus
    Dufus Well-Known Member
    Located in Colorado
    99 Taco 3.4L manual 4x4 SR5 - Imperial Jade Mica
    Mods: bent frame and sun weathered roof paint.
    Old post, but at least I'm searching for answers right? Anyway, I am having the same trouble trying to shift into gears on cold days with my truck. Takes a lot of warming up for it to start shifting normally. Going to try and replace the transmission fluid (with synthetic), differentials and transfer case as I suspect it probably has never been done before on this truck. Crossing fingers and hoping it helps. I will update with results. Happy Halloween!
    GQ7227 likes this.
  19. Nov 1, 2020 at 4:04 AM
    #39
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    This is a strange problem I have ever yet to see even using 85/140 for years in my W-56 transmissions and transfer cases at such warm temperatures when I gets down to zero F for a few days things were a little stiff.
    Then my clutch hydraulics and gear oil was fresh and shifter bushings done.
    Might be a combination of all 3 making the cool weather shifting harder then normal.
    Over the years I have seen a few times so much moisture in gear boxes they froze talk about hard shifting .
    GQ7227 likes this.
  20. Nov 1, 2020 at 5:15 AM
    #40
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    I bought my truck recently and on the first cold morning it wouldn’t shift either. I finally got it to go and went to work. The guy in my shop changed out my transmission fluid and clutch fluid with regular OEM fluids. Works perfectly now. There’s still some black sediment in my clutch fluid so I plan on using a turkey baster to suck it out from the top where it’s floating around and not let it get so low that it needs to be bled. But otherwise it’s a 1000% difference than initial driving
    Dufus likes this.
