Collinite 845
Discussion in 'Detailing' started by NMTrailRider, Jun 14, 2015.
  1. Jun 14, 2015 at 12:11 PM
    NMTrailRider
    NMTrailRider [OP] Well-Known Member
    New Mexico
    so is Collinite 845 a sealant or a wax? In my research on here it seems some guys refer to it as a sealant and some refer to it as a wax. And several people recommend putting it on top of a sealant like jet seal. Reading the description on the Collinite website- it sounds like it is both a sealant and a wax. So then why are guys putting it on top of jet seal. Ok guys, set me straight...
    Is it a sealant or a wax?
    Or both?
    Ok on its own or better over jet dry?
  2. Jun 16, 2015 at 10:05 AM
    AMarkham40
    AMarkham40 Well-Known Member
    Roanoke, Virginia
    2014 MGM DCSB TRD O/R
    NMTrailRider[OP] likes this.
  3. Jun 19, 2015 at 4:37 AM
    Mr. Sparkle
    Mr. Sparkle Well-Known Member
    Bryan
    Long Island, NY
    Silver 09 TRD Sport
    Leer Cap Subfloor, water pump, marine battery, 45 gal water tank & plumbing to wash cars anywhere
    Its a 'wax' because it contains carnauba but really its a hybrid. Which is the case with a lot of over the counter stuff. Either way, great product. I usually switch over to 845 for winter maintenance work
  4. Jul 10, 2015 at 6:14 AM
    VermontTaco
    VermontTaco Well-Known Member
    Vermont
    2015 DCSB TRD Sport Silver
    Weather Techs Mats front and rear, Wet Okole seat covers, BakFlip Fibermax tonneau cover, Power Pop N' Lock, Flyzeye interior lights, Scangauge 2, IMMRYO Rearview mirror bracket, upgraded Homelink, temperature gauge, and compass rear view mirror, Matt Geko bed lights, OEM bed mat, Beerad's Antidark engine lights, interior LED lights, TRD SEMA 17" Wheels in gunmetal gray, LT265/70/17 BFG KO2 Load Range C, and center console/glove compartment organizers.
    I would consider it a wax as well. The secret that I found is to spread it really thin. I use it on my vehicles right before winter and the stuff is bullet proof.
  5. Nov 9, 2015 at 8:46 PM
    NMTrailRider
    New Mexico
    Bump. Any new thoughts on this one?
  6. Nov 10, 2015 at 8:10 PM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    I agree with Mr. sparkle...it's a wax with sealant durability. Good stuff
  7. Nov 12, 2015 at 6:34 PM
    NMTrailRider
    New Mexico
    FYI I tried the 476 today. Removal was a bear. So bad that I was worried about scratching the clear with even the best of towels. I tried removing immediately after application, after it hazed, after it dried, everywhere in between. Super thin application. I likely won't play with it again. As much as I enjoy waxing, I'd do anything else more frequently rather than try the 476 again.
  8. Nov 12, 2015 at 8:33 PM
    ace96
    Western KY
    Jeez you must be addicted to waxes/sealants. 845 is good....really good. I wouldn't bother with 476 if it is that hard to remove. Lol.
  9. Nov 12, 2015 at 9:21 PM
    NMTrailRider
    New Mexico
    Ha yeah I'm hooked. I just like trying out different products and trying to one-up myself. But I think I'm done for the year! Weather is gonna change. Just wanted to get something on that's gonna last me until April.
  10. Nov 13, 2015 at 6:34 AM
    ace96
    Western KY
    You need to try Optimum gloss coat. 2 year coating that can be layered with wax if you like. The beading is amazing. Don't think I will ever use a regular wax or sealant again.
  11. Nov 13, 2015 at 8:09 AM
    NMTrailRider
    New Mexico
    Thanks- I've been doing some reading about coatings over at autogeek. Any reason you went with optimum and not one of the others?
  12. Nov 13, 2015 at 2:43 PM
    NMTrailRider
    New Mexico
    Well, gotta say- the 476 looks awesome a day later. Incredible reflections.
  13. Nov 13, 2015 at 3:21 PM
    ace96
    Western KY
    I was originally going with cquartz, then I came across Gloss Coat....it has more pop to it. Plus I have a wax addiction like you, so thought it would be nice to use them up. Lol
  14. Nov 14, 2015 at 7:36 PM
    NMTrailRider
    New Mexico
    The 476 is really bringing out the flake in the pyrite mica. Amazing stuff. This is the edge of my hood looking down on the bug deflector.
    stbear likes this.
  15. Nov 27, 2015 at 9:46 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I used 476 on my Truck too, it is a little harder too remove than normal wax but was not that bad.
  16. Jan 17, 2016 at 10:53 AM
    3rdGenDCOR
    3rdGenDCOR Well-Known Member
    TX
    16 OR DCSB
    I am very new to wax/detailing... I have a new 2016 Tacoma and wanted to put a protective wax on. I purchased Collonite 845 and applied after a normal wash. I'm now realizing I have some water spots and should have dried and used a clay bar and detailing spray prior to the application of collonite.
    To remove I've seen recommendations to simply wash car with a mixture of dawn soap. Does this seem correct? Any suggestions on any change in plan aside from wash with dawn soap, claybar with detailing spray, then application of collonite 845?
    Many years ago I had simply used Zymol wax cleaner... I'm contemplating whether a simple person like myself should return to that? I'd appreciate your suggestions.
  17. Jan 17, 2016 at 11:09 AM
    NMTrailRider
    New Mexico
    You can just go ahead and clay now (after a wash with car wash soap)- no need to wash with dawn. Claying will remove "some" of the wax, as well as any above surface bonded contaminents. If that doesn't remove the water spots, a light polish might be required. When you are done, go ahead and reapply the Collinite.
    CAM37 likes this.
  18. Jan 17, 2016 at 11:16 AM
    NMTrailRider
    New Mexico
    Some guys have done experiments with "dawn washes". What's actually happening is that surfactants in the soap remain on the surface after a dawn wash. And this gives the illusion of the wax being "washed off". They then do a isopropyl alcohol wipe down, and the beading properties of the wax return (i.e, surfactants removed), illustrating that dawn isn't really removing the wax.
    A wash with dawn once in awhile probably won't hurt, but it will dry out rubber eventually. I've had vehicles in the past show drying of seals when I used to use dish soap before I knew how to properly wash a vehicle. Why use it when you don't have to. Just use a car wash soap. Claying/polishing will remove most of whatever wax you laid down.
  19. Jan 17, 2016 at 11:18 AM
    3rdGenDCOR
    TX
    16 OR DCSB
    Thanks - very helpful. My plan will be to wash with car wash soap, detail spray / clay all surfaces, then apply the collonite 845. For all plastic and soft surfaces I'm applying 303 protectant and that is my current plan - anything else you'd recommend for someone trying to keep it simple yet protect the vehicle?
  20. Jan 17, 2016 at 11:24 AM
    NMTrailRider
    New Mexico
    There are also dedicated pre-wax cleaner products to accomplish what you are after- Meguires Ultimate Polish would work as a good pre wax paint cleanser also. Lots of polishing oils and would do well on dark colored paint. A quality all-in-one, such as Meguires new Mirror Bright Polishing Wax, would also work for you- and you could even top it with Collinite. That might really be nice.
