Colorado B.S. Thread
Discussion in 'Colorado' started by Kappes03, Jan 1, 2011.
  1. Jun 14, 2016 at 1:37 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    :rofl::rofl:
    this was a nomination from a member :spy:
    Deathbysnusnu[QUOTED] likes this.
  2. Jun 14, 2016 at 1:44 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Ray, you may have only taken two pictures the entire trip, but you really captured the perfect point in time. :D
  3. Jun 14, 2016 at 2:47 PM
    Red Baron
    Red Baron Let's call it livabetes, no more die
    Aaron
    Lost on a roundabout
    07 Radiant Red DCSB
    Things with metal, dog hair, more metal and lights
    Just different angles of view is all, Steve tried to get you "as straight as possible" pics down the side of the truck
    CO MTN Steve likes this.
  4. Jun 14, 2016 at 2:56 PM
    Stig
    Stig Resident smartass
    Brandon
    Ta no mo
    So... Its looking like ARB gave up on the search for a shock that was designed for, and will correctly work with their "bolt on" lift kit.
    Are these the 5100's that'll work with the 885/886 OME springs and dakar leaf pack?
    http://toyteclifts.3dcartstores.com...e-5100-Series-Front-and-Rear-Shocks_p_31.html
    I read somewhere that the 5100's will work great up front and in the rear I'll have to get extended brake lines for the additional 3" of droop provided by the springs.
  5. Jun 14, 2016 at 3:04 PM
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    I run ARB shocks, the same that you run. The catch is, I have enough weight in the front to keep them from topping out. If you run 886 springs without a bumper you will quickly damage the shock.
    I would never run a 5100 again. You thought you had issues with the ARB shock, expect more with the 5100. They have no more travel then the ARB so the same design limitation will come into play, vehicle sitting too high for the shock travel (you have little to no down travel).
    The best solution is to make the jump to a true performance shock. Spend the $1500 and do it right, for the last time.
    Stig[QUOTED] and Squeaky Penguin like this.
  6. Jun 14, 2016 at 3:26 PM
    Red Baron
    Aaron
    07 Radiant Red DCSB
    as @thefatkid said do it right. I am regretting and have been for over a year getting the 887 and nitros, I have been topping out a bunch due to no real armor on the front. the rear you wont need extended brake lines for the dakars until you go past an 11" shock IIRC, only reason I say that is I haven't changed mine yet and I am running the dakars with the nitros in the rear as well
    Stig[QUOTED] likes this.
  7. Jun 14, 2016 at 3:36 PM
    Stig
    Brandon
    Ta no mo
    So I must have the 885's, whatever is for no front bumper.
    And I read in another thread that the 5100's have an extra inch of travel which would make them work perfect?
    Why was everyone saying OME was a great lift when I bought it a year ago!! Damnit.
    edit: 5100 info
    https://www.tacomaworld.com/threads...d-and-adventures.362772/page-33#post-11122860
  8. Jun 14, 2016 at 3:40 PM
    Red Baron
    Aaron
    07 Radiant Red DCSB
    I still think it is a great lift and I have nothing against it. I just pulled a stupid and didn't look at everything like I should of when I bought it. the springs are totally my fault but ill live with it.
    Main thing is I am limited to what I want to do with the set up so I want to change eventually.
  9. Jun 14, 2016 at 4:18 PM
    Stig
    Brandon
    Ta no mo
    It seems like a decent budget lift as long as you won't use it offroad... I expected it to be pretty to look at AND useful.
    Red Baron[QUOTED] likes this.
  10. Jun 14, 2016 at 4:20 PM
    Red Baron
    Aaron
    07 Radiant Red DCSB
    We both did, it holds its own in areas but just not enough...
  11. Jun 14, 2016 at 4:32 PM
    Stig
    Brandon
    Ta no mo
    horseshit! just sucks that It was a 'waste' of $1300'ish that could've almost purchased a real lift kit. Guess the leaf pack would've been extra but yeah..
  12. Jun 14, 2016 at 4:35 PM
    Red Baron
    Aaron
    07 Radiant Red DCSB
    Mine was $1500 with the Dakars... im keeping the pack for now but doing a relocate with 12" or 14" for the rear... and I have been eyeballing some true coilovers...
  13. Jun 14, 2016 at 5:31 PM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
    Who does good vinyl wraps near Denver, or north on The 25?
  14. Jun 14, 2016 at 5:39 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    So what's the problem? Myself and @NYCO rocked ome stuff for a long.... time. I still have ome up front on the tundra. It works great for a reasonable priced lift that will hold up to alot of abuse. May not be the best riding, or most flexi suspension but u can beat the piss out of it.
    alee891 and 303tacoma like this.
  15. Jun 14, 2016 at 5:50 PM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    I think they're running the new OME kit, which is very similar to a coilover or 5100.
  16. Jun 14, 2016 at 6:01 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    New ome? Same stuff it's always been. I install them all the time
  17. Jun 14, 2016 at 6:09 PM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
  18. Jun 14, 2016 at 6:29 PM
    Red Baron
    Aaron
    07 Radiant Red DCSB
  19. Jun 14, 2016 at 6:31 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    Right, bp51 was just released, like not even a month ago for tacoa I thought?
    What's wrong with the nitro setup?
  20. Jun 14, 2016 at 6:33 PM
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    What's left on your lease. I recall that was the reason you didn't do a performance coilover
