Commercial shells, especially on DCSB?
Discussion in 'Tonneau Covers, Caps and Shells' started by dman100, May 29, 2016.
  1. Jun 13, 2021 at 2:38 PM
    #281
    BertaTRD
    BertaTRD Member
    2017-AC Tacoma TRD
    That's awesome, thank you! To know you have experience with the same cap and it wasn't noticeable is good to hear.
    For discussions sake: I looked to the DCU specifically to get the extra height without the weight of a midrise fiberglass cap (read: so heavy). My prior setup was in a Frontier with a cab height cap and it was alright but the Frontier's bed is deeper and the cab slightly higher; of course it didn't have the Tacoma's beautiful high stance haha. You're definitely right, even 23" is a trade off vs 26 or a wedge... maybe if I could afford it I'd just get this https://fourwheelcampers.com/model/project-m/ but it has downsides too.
    Anyway, thanks again
  2. Jun 13, 2021 at 6:25 PM
    #282
    03maurderman
    03maurderman Well-Known Member
    I might add Tacoma's engine & transmissions have all to do with weight & performance...Mine is a 4 cylinder access cab with an automatic transmission...Payload is 1000 lbs give or take. ...A 5 speed with a V-6 does not have the struggles of my truck....something to greatly consider.....
  3. Jun 13, 2021 at 8:08 PM
    #283
    Aau80
    Aau80 Well-Known Member
    Alan
    Alexandria Va
    2020 cement taco off-road
    Meso ultimate turn signals, Meso pod lights, bestop soft topper Nothing major... yet...
    I have the are dcu 23” cap and i haven’t really noticed much of a drop in my fuel economy, i would say barely noticeable, i did have a soft top on there before but found a deal on marketplace for the dcu cap. There is a slight wind noise bc of the ladder rack but not really an issue for me since i have my music turned up
    Ngneer and BertaTRD[QUOTED] like this.
  4. Jun 14, 2021 at 9:46 AM
    #284
    FoxenTec
    FoxenTec Active Member
    Californication
    2017 TRD OR
    OVR LND Camper and build
    I have the A.R.E. DCU with 26" height. While the shell is taller then the cab it is not by a significant amount. My mileage did drop but I also run 10 ply mud terrains that are much heavier then the stock tires. I think the 1-2 mpg drop was a combination of both changes. I previously had a Four Wheel Camper Grandby on a Ram truck and when it was closed up, it was still quite a bit higher over the cab then what the A.R.E. DCU is on the Tacoma. As I have learned in my old age is everything seems to be a compromise when it comes to trucks and camping. All depends on priority ranking. For us, camping and room came first over mpg but I understand if you do a lot of windshield time, you may not want to hurt your mpg. Picture is my 26" with ladder rack. I also now run two solar panels on the roof and am planning on maybe adding a DIY gravity Shower. Ugh...gotta stop adding weight. Having air bags installed as I type this.
    Ngneer, benshawdle, Sna and 3 others like this.
  5. Jun 14, 2021 at 11:47 AM
    #285
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    Interesting, another previous FWC owner going to an aluminum shell. I just made a second shower for my truck. I can pressurize it but have found that it works fine being vented and gravity fed.
    FoxenTec[QUOTED] likes this.
  6. Jun 14, 2021 at 5:37 PM
    #286
    Islandtaco671
    Islandtaco671 Well-Known Member
    Daniel
    San Diego
    2006 Double cab Tacoma TRD O/R
    Anyone need shelves for a shortbed? Came off my century cap
    Justintheegreat likes this.
  7. Jun 15, 2021 at 12:13 AM
    #287
    BertaTRD
    BertaTRD Member
    2017-AC Tacoma TRD
    (truck is V6 access cab) The power difference does matter; I've read about the impact a thule box can have on a small car-- 20-30% economy lose.
    That 26 height looks good actually and is that the ARE grey?
    It is truly a challenge not to just bolt fun stuff all over your truck! I find myself heading to BC and doing 8-16 hours of driving with a lot of it through the mountains so the fuel adds up fast.
    Ngneer and FoxenTec like this.
  8. Jun 19, 2021 at 3:57 PM
    #288
    bodean
    bodean Well-Known Member
    Shawn
    Crowsnest Pass, AB
    02 Taco RCSB, 16 Taco AC6MT, 07 FJC, 22 Bronco
    Got out this week for some R & R
    0FB74596-F45F-48A2-8FF5-1C39DDA3D538.jpg EC9C6940-0DF9-4967-BC7D-A499FB56398F.jpg
    Ngneer, DJB1, Sna and 4 others like this.
  9. Jun 23, 2021 at 5:24 PM
    #289
    FoxenTec
    Californication
    2017 TRD OR
    Regarding the A.R.E. Color. I gave them the paint code off the Taco (silver sky). Think it was 1D3. (((CORRECTION CODE 1D6)))
    BertaTRD[QUOTED] likes this.
  10. Jun 23, 2021 at 11:17 PM
    #290
    FoxenTec
    Californication
    2017 TRD OR
    I didn't realize that you also had a 4WC prior to your Tradesman Aluminum shell until I read your ETAV8R Gini Build. Awesome thread.
    So.....my question is after the Flippac and the 4WC, what was the reasoning for changing out to an aluminum 26" shell? Was it mainly due to weight and getting to where you wanted offroad?
    ad my 4WC Grandby on a 17 Ram Tradesman regular cab 2WD. I replaced the Grandby with a A-Frame hard-side trailer and now have some regrets after 16 months later. Wish I had re-considered keeping the Grandby and replacing the 2WD regular cab with a 4WD extended cab truck. I bought the Tacoma 4x4 DCSB and the A.R.E. aluminum shell for storage when camping and if I decided to head off alone camping and leave the trailer at home I could sleep in the Tacoma. Thank you again for the great thread.
    ETAV8R[QUOTED] likes this.
  11. Jun 24, 2021 at 7:52 AM
    #291
    ETAV8R
    ETAV8R Out DERP'n
    Just the basics
    Thank you for the compliment on my thread.
    I sold the FWC because I was starting nursing school and was reducing my debt. I enjoyed the FWC but it was heavy. IMO too heavy for the Tacoma. On a full-size truck FWC is a great option.
    Ngneer and FoxenTec[QUOTED] like this.
  12. Jul 22, 2021 at 12:09 PM
    #292
    NHmachinist
    NHmachinist Member
    Jon
    New Hampshire
    2018 TRD OR access cab
    OME lift SPC uca 255/85/16 on steelies A.R.E. DCU cap 270 awning smitty built winch rock sliders 270 awning
    How much did your cap hurt your gas mileage?
  13. Jul 22, 2021 at 2:32 PM
    #293
    bodean
    Shawn
    Crowsnest Pass, AB
    Hard to say, I added a lot of weight also when I put it on. Bumpers, sliders, etc. Also I’m in Canada and our speed limits aren’t as high. But I usually average around 12-14L/100kms or around 16.5 to 19.5 mpg.
  14. Nov 6, 2021 at 2:02 PM
    #294
    BertaTRD
    BertaTRD Member
    2017-AC Tacoma TRD
    Update on the ARE DCU cap:
    The cap is a well spring of utility and versatility and I think it looks cool on the truck.
    It has impacted fuel economy more than I'd hoped, though.
    Before the DCU I had a cab height fiberglass cap and consistently saw around 10.2 L/100 Km on flat-ish highway; up to 11.4 in a bad head-wind.
    With the DUC the best I've seen is 12.8 L/100 Km and 13.2 pretty regularly. I've seen 15 to 15.6 in bad winds.
    Sidenote: kayak on the roof rack doesn't seem to make any difference. Gear weight is consistent between fiberglass cap and DCU-aluminum cap.20211017_121919.jpg 20211017_121919.jpg
    All #s are for highway kms; city L/100km is a noticeable decrease but less so.
    Overall I have to call it a solid 20% decrease in fuel efficiency--arguably higher.
    I still really like the cap just putting the info here for anyone making choices.
    Ngneer and Sna like this.
  15. Nov 6, 2021 at 2:11 PM
    #295
    NHmachinist
    NHmachinist Member
    Jon
    New Hampshire
    Thanks for the information. That is exactly what I was afraid of.
  16. Nov 6, 2021 at 6:39 PM
    #296
    bodean
    Shawn
    Crowsnest Pass, AB
    Can confirm. Headwind is the biggest killer. And anything over 110km/h and you’ll start seeing a pretty big dip.
  17. Nov 8, 2021 at 7:13 PM
    #297
    Deepcreektacoma
    Deepcreektacoma Member
    2009 Sport Double Cab
    New ARE 26” cap on the double cab. Building out the shelves next for all my tools. 690EF2F1-3FC4-4FC5-9FB4-CA02D5917DB8.jpg
    BertaTRD likes this.
  18. Dec 13, 2021 at 1:34 PM
    #298
    Sna
    Sna Well-Known Member
    Alberta
    ‘15 trd sport 6MT dcsb, mostly stock?
    Edit @bodean - no TRD PRO wheels??
    A cap like that will effect mileage but as bodean mentioned, when you have bumpers and lots of extra weight it doesn't help. I average between 13-15mpg with my truck. She is a brick on wheels and weights almost 7k all loaded up.
    These trucks looks great with contractor type caps....especially if the truck is modified with other stuff. I really like the ulilitarian look.
    Yep...I try to stay between 104-111km/h for my 'best' mileage but with a rolling brick and being pretty chonky, it's best just to keep a steady pace and not be in a rush.
    Ngneer, Naveronski and beatadrum like this.
  19. Dec 13, 2021 at 5:06 PM
    #299
    bodean
    Shawn
    Crowsnest Pass, AB
    I wish! Wife claimed them for her FJ.
    We did just back from a 24 day road trip through Utah, Nevada and Arizona.
    182A9C7A-5B8F-44D9-93F0-B05AE5E4CBC5.jpg 4B11D963-0E6C-4401-991F-4E2B82892F9C.jpg 53091C6F-1672-4DE2-AFA9-52360156203D.jpg 893334C8-8255-434F-87A4-6D8950E2145B.jpg BCB8BF37-7D86-4753-B762-E67C72629859.jpg
    Ngneer, BertaTRD, chrslefty and 2 others like this.
  20. Dec 13, 2021 at 6:52 PM
    #300
    Sna
    Alberta
    Looks like an awesome trip. It’s on my list to get down there.
    I didn’t realize they weren’t going on the Taco….if I’d know that, I wouldn’t have sold you that single. Lol:p
    Joking of course…..
