Compass and Temperature HELP
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Spidious, Nov 13, 2014.
  1. Nov 13, 2014 at 4:27 PM
    Spidious
    Spidious [OP] 2006 Tacoma SR5
    Fred
    Champaign, IL
    2006 Tacoma SR5
    Forward & reverse camera monitoring Bed Mat Tyger Black Tonneau Cover Tyger Sport Bar, 36" led light bar Hikity Android Car Radio Pro grill with lights Sport hood Cold air intake Sprint Booster throttle controller Flip down bed extender 265/75R15 tires 2"spacers New led tail lights Internal/external thermometer Chrome Bullbar Chrome step tubes LED F&R led turn lights
    I have a 2014 Tacoma and really miss the compass and temperature. I have checked, and the extra wiring connector is up in the center console area. Also the outside temperature sensor is in front of the radiator on the center below the hood latch area.
    If I can find and but a new one and plug it in will it work ?
  2. Nov 13, 2014 at 4:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If everything is there, I don't see why it wouldn't.
  3. Nov 13, 2014 at 4:33 PM
    rwhisen
    rwhisen Member
    TX
    '15 DCSB 4X4
    You're looking for a Gentex model
  4. Nov 13, 2014 at 4:49 PM
    cmbondo
    cmbondo Well-Known Member
    San Diego CA
    2021 Cement DCSB TRD Offroad
    FOX 2.5 DSC and some other stuff too.
  5. Nov 13, 2014 at 5:36 PM
    Spidious
    Fred
    Champaign, IL
    2006 Tacoma SR5
    Not sure I am on the right track. On my 2008 Tacoma. The flip down sun glass holder was a temperature and compass display.
    Did they change it where it is no longer in that area ?
  6. Nov 13, 2014 at 6:41 PM
    mrkabc
    mrkabc Mall Crawler with a Locker
    Art
    Corona, CA
    2017 MGM DCSB TRD OR
    Morimoto XB LED Head & Fog Lights, Cali Raised Stealth Light bar, OEM Roof Rack, Homelink Compass Mirror, Power Tailgate Lock, LED bed lights, MESO mirrors, gashole, switch panel & Stage 2 tails, PRO grille. Where's the mall?
    They deleted it. For 2014 you'll need to get a Gentex mirror.
  7. Nov 13, 2014 at 6:45 PM
    Spidious
    Fred
    Champaign, IL
    2006 Tacoma SR5
    I see where their is a complete kit. But who sells it.
  8. Nov 13, 2014 at 8:16 PM
    mrkabc
    Art
    Corona, CA
  9. Nov 14, 2014 at 5:56 AM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    my '12 was prewired for everything except the power to the homelink inside the mirror. so if you plug it in, and everything works except the homelink function just drop a power wire into the missing pin on the harness from the map lights and the homelink will have power.
  10. Nov 14, 2014 at 7:25 AM
    ttttrd
    ttttrd Member
    Central Washington
    14 Tacoma Dbl Cab TRD
    WeatherTech mats, LED lights for: bed, interior & exterior, Wet Okole heated seat covers, Gentex Auto-dimming mirror, Bloodwood custom gear shift knob, AVS hood Aeroskin, Fog light mod, Bed compartment combo locks
    I just installed an auto-dimming mirror with temp and compass display on my 14 TRD DblCab . I got one off Amazon for a little over $200. Gentex model#: 50-GenK-20A. Kit came with connector to mate with the existing connector in headliner. The kit is year specific. You do have to add a temp sensor, also included in the kit. The OE temp probe is probably for engine fuel management, do not tap into it! The kit also included very good instructions. Whole thing was fairly easy to do and works great.
    Hope this helps. PM me if you need any help with the install.
  11. Nov 16, 2014 at 7:21 AM
    Spidious
    Fred
    Champaign, IL
    2006 Tacoma SR5
    I ordered a used one from him with the kit. Total cost was only $139 ! A bargain as far as I am concerned. Still can't believe Toyota took it off of the vehicle !
    As far as the built in radio HD weather. It does actually work if you live in Chicago, or another major place. But since we have HD radio in Champaign,IL, I personally think that any location that has HD radio should have the weather for the radio !
