Complete engine failure Tacoma 2017
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KejiuaQC, Sep 27, 2022.
  1. Sep 27, 2022 at 4:35 PM
    #41
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    OP says he needs a short block?
    A short block doesn’t typically include heads.
    Hopefully the dealership knows for sure the heads are good. If they aren’t, and the short block is already there and ready to drop in. You’re at the mercy of the dealership.
    I’d make sure you really don’t need a long block.
    cryptolime and Ricardo13x like this.
  2. Sep 27, 2022 at 4:35 PM
    #42
    Calamity_taco
    Calamity_taco your friendly neighborhood weeb :3
    Jacob
    I have no idea. send help!
    2017 f-150, 23 Klx300R, 2022 tracer 9 gt
    just a couple of things tbh
    i mean its not like the 3.5 has been flawless soooooo ye
  3. Sep 27, 2022 at 5:04 PM
    #43
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    They probably saw a cylinder wiped out from poor lubrication. Virtually all automotive engines now have parent-bore blocks, meaning there are no removable cylinder liners. One damaged cylinder means the whole block is junk.
  4. Sep 27, 2022 at 5:16 PM
    #44
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    im inclined to agree with the guy warning about used vehicles. without an known history this truck appears to have been abused and traded in. Not sure how this reflects poorly on toyota without knowing the real cause of the failure.
    GilbertOz and Lt. Dangle like this.
  5. Sep 27, 2022 at 5:17 PM
    #45
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    what kind of abuse only messes up one cylinder?
    (and so far, appears to not affect anything else?)
  6. Sep 27, 2022 at 5:19 PM
    #46
    auskip07
    Skip
    Atlanta, Ga
    carelessness when changing out spark plugs, a single piece of metal let loose (washer etc) in the intake. It only takes one piece of debris to cause 1 cylinder to get abused.
  7. Sep 27, 2022 at 5:20 PM
    #47
    0xDEADBEEF
    I suppose, but that’s so unlikely on such a low mile engine. Why would they have it apart to begin with
    Ozark_RegCab and Junkhead like this.
  8. Sep 27, 2022 at 5:20 PM
    #48
    Calamity_taco
    Jacob
    yes a used vehicle can cause issues.
    but for real thou most people that own these trucks and keep it stock that long just drive it back and forth to work and maybe to carry a bit of trash once and awhile so it would be a bit odd to say this one was abused when its bone stock... now it could have had a factory defect and the person noticed an issue and ditched it now this is a more probable thing to have had happen since no company is perfect!
    Ozark_RegCab and 0xDEADBEEF like this.
  9. Sep 27, 2022 at 5:21 PM
    #49
    Calamity_taco
    Jacob
    yes but that would be an accident that someone prob didnt notice if that did happen thats not really abuse...
  10. Sep 27, 2022 at 5:21 PM
    #50
    auskip07
    Skip
    Atlanta, Ga
    it didnt just do it all by itself.
  11. Sep 27, 2022 at 5:22 PM
    #51
    0xDEADBEEF
    And yet we have 24+ instances of the engines failing on this site alone with similar issues
    are they all abuse?
  12. Sep 27, 2022 at 5:23 PM
    #52
    Calamity_taco
    Jacob
    i mean the 3.5 has made windows on its own in cylinder 6 :notsure:
    there is also reports of valve issues on them as well anything can happen! hell it could have been a poorly tightened something and it just now failed
    ford was having issues with the 2.7 for awhile i think it had to do with valves? and they would literally fall out which as we know isnt a good thing haha but it turned out to be something very simple and they fixed it sometimes something like this could fly under the radar or there isnt enough having the issue for toyota to issue a recall
    Superdave1.0 and DJB1 like this.
  13. Sep 27, 2022 at 5:25 PM
    #53
    Calamity_taco
    Jacob
    ye i said mean things to them and they decided it was better to not be around!
  14. Sep 27, 2022 at 5:28 PM
    #54
    auskip07
    Skip
    Atlanta, Ga
    jumping to conclusions, why dont you just wait and find out what really happened to the engine?
  15. Sep 27, 2022 at 5:30 PM
    #55
    Calamity_taco
    Jacob
    lol what? im stating facts about others whos engines have died.... the cylinder 6 issue if i remember right had to do with oil but i dont fully remember because i dont own a 3rd gen
    DJB1 likes this.
  16. Sep 27, 2022 at 5:33 PM
    #56
    auskip07
    Skip
    Atlanta, Ga
    its oil pooling in the valve train because of steep angles. the whole point of "stating facts" is actually knowing the facts lol
    Lt. Dangle, FredRed315 and hiPSI like this.
  17. Sep 27, 2022 at 5:34 PM
    #57
    Calamity_taco
    Jacob
    i mean i was literally right...... it had to do with oil i just forgot about the steep angle bit because oh right i dont own a turd gen lmao
    DJB1 likes this.
  18. Sep 27, 2022 at 6:27 PM
    #58
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Let's see those 24 examples with this similar issue. A scope will show issues with a cylinder wall and they said it needs a short block. So this isnt the valve issue based on the limited info op has given.
  19. Sep 27, 2022 at 6:28 PM
    #59
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    The 3.5 is not a parent bore nor a traditional liner block. It's a cast aluminum block with embedded liners, specifically thin spiny cast-iron liners. Embedded means non-replaceable, and thin means no overboring - at least per Toyota. So yeah throw away, but not for the reason you mention.
    FredRed315 and SR-71A like this.
  20. Sep 27, 2022 at 7:05 PM
    #60
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    And yet here you are, blessing us with your wisdom. I'm sure we are all grateful.
