Complete list of tools, sockets and wrenches for 2nd Gen Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crom, May 22, 2011.
  1. May 22, 2011 at 10:54 AM
    Crom
    Crom [OP] Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I am looking for a complete list of sockets and wrenches that are needed to work on the 2nd gen Tacoma--FACTORY PARTS ONLY. I have searched and I can't find such a list. I am willing to compile and keep this list. If you have good information let me know and I'll add it to this list.
    Metric sockets
    • 5.5 mm, blower motor resistor screws.
    • 8 mm, Running boards if you have them.
    • 10 mm, Center console bolts, Stereo, engine cover, tail lights, interior
    • 11 mm, Battery terminal
    • 12 mm, Skid plate bolts, e-brake mounting bracket
    • 13 mm, Tube steps if you have them.
    • 14 mm, Transmission drain plug, Oil drain plug and Drive shaft bolts, exhaust system, center support bearing, Radiator bolts, and many, many more!
    • 16 mm, Deep socket for spark plugs (16mm is virtually same as 5/8"; If you carry a 5/8 dedicated spark plug socket you don't need the 16mm)
    • 17 mm, Power steering, Sway Bar, Cab mount nuts, leaf spring bolts, nuts.
    • 19 mm, Lower Control Arm bolts and nuts., Deep socket for PCV valve
    • 21 mm, Wheel Lug nuts
    • 22 mm, Crank pulley bolt, Alternator
    • 24 mm, Transfer case & Rear diff, drain and fill plugs
    • 27 mm, shallow socket for reverse switch on manual transmissions
    • 30 mm,
    • 35 mm, front Axle nut
    SAE sockets
    • 7/32 socket for Blower Motor Resistor screws, 5.5mm works too.
    Metric Hex Sockets (Same as Allen Keys)
    • 5 mm, , transmission overflow plug
    • 6 mm, Suspension, Front Axle
    • 8 mm,
    • 10 mm, Front Diff fill and drain plug,
    • 12 mm, Front Diff Removal
    Torx Sockets
    • T20,
    • T25, mirrors
    • T30, , , , , tailgate bolts
    • T40, Bed D-Rings
    • T55, Bed bolts
    External / Interior / Female Torx Sockets
    • E7 Torx socket to remove the 2 studs from the intake manifold
    • E14 Torx (diff removal)
    OTHER
    • 10 mm flare nut wrench (brake lines)
    • (2) M8 x 1.25 bolts (Needed to remove the rear brake drums, need to be at least an inch and a half long) YOU CAN USE THE BOLTS THAT HOLD THE FACTORY SKID PLATE ON TO DO THIS. THEY WORK GREAT.
    • Bi-hexagon Wrench 10 mm,
    • Straight Hexagon Wrench 14 mm,
    • Oil Filter wrench
    • 5/8" Spark Plug Socket or 16mm deep socket will also work for spark plugs.
    • Torque wrench
    • Breaker Bar
    • Large and Small pair of adjustable pliers
    • Long Needle nose pliers
    • Knife or box cutter
    • Long 8" screw driver
    • Assorted ratchet extensions 3", 6" and 8"
    • Phillips screw drivers, flex extension
    • Grease gun (if 4x4) for zerks on drive shaft
    NOTES
    Metric Thread Data
    Pray4Mojo, Mh2015, FastJK and 141 others like this.
  2. May 22, 2011 at 10:58 AM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    cool idea. sub'd
  3. May 22, 2011 at 10:59 AM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian aka B-Lang
    San Luis Obispo, CA
    2010 Tundra
  4. May 22, 2011 at 11:00 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Well, if you want the minimum I guess you could do this. Personally, I find that I carry a whole extra shit ton of tools that I rarely use but that when I need them I'm god damn happy I have them. This is dumb.
  5. May 22, 2011 at 11:01 AM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    32mm socket for ball joint on lr uca
  6. May 22, 2011 at 11:55 AM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    Just food for thought.
    If you go on a trail ride with someone else, and they don't have tools, wouldn't it be beneficial to carry MORE than what you just need for your own vehicle? As a Just In Case thing.
    Personally, I just carry a generic socket/wrench set that fits in behind one of the seats.
  7. May 22, 2011 at 11:57 AM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    10mm to remove stereo.
  8. May 22, 2011 at 12:04 PM
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    12mm fine thread nut for the bolt that hold the front/rear shocks/struts in place
  9. May 22, 2011 at 1:59 PM
    TOYOTA 09
    TOYOTA 09 Kicking Ass Since 1981
    Maine
    2009 SR5 MT 4x4 Access Cab
    Preview 2009 SR5 4x4 MT Black Sand Pearl (Access Cab) SUSPENSION ToyTec 5100 Billstein Coil Overs (3" Lift) Fox 2.0 Remote Res Rear Shocks Total Chaos UCAs Full Dakar Leaf Pack w/Extra AAL TIRES & WHEELS BFG AT KOs 265/75/16 load range E American Rancing AR-23 Wheels Borla CAT back exhaust AFE cold air intake w/custom TRD clear cover Satoshi grill w/Grill Craft insert Hella 500 behind grill lights Rigid Industries Backup lights Interior Custom LEDs and Bed Lights Backup Cam Anytime MOD Leather armrest and rear seat MOD Weathertech floor liners Custom rear gear/dog platform Cobra CB and Garmin GPS Bed Mat UWS low pro tool box with Custom LED lights Diff breather MOD Custom painted engine cover Wet Okole seat covers
    A lot of the smaller bolts are 10 mm ....you may want to invest in a Haynes Manual
    Charlie Bravo likes this.
  10. May 22, 2011 at 4:58 PM
    fvtalon
    fvtalon Well-Known Member
    Southern BC
    07 DC TRD/Yamaha
    285/65/18 BFG ATs on MKWs Leer Cap
    I haven't had much need to work on the Tacoma, but I know my cars have all 10, 12, 14, 17mm bolts, no 11, 13, 15mm at all. But... when you need a bolt the ones at the autoparts store tend to have 13 or 15mm heads. If you're trying to minimize the amount of gear for an expedition outfit or something this might be something to consider. Hate to break a bolt and find a replacement but then not have the right size wrench for it.
  11. May 22, 2011 at 9:17 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Interesting. I could've used this earlier when I was at Harbor Freight (found what I needed anyway). Not a bad idea, really.
  12. Jun 15, 2011 at 11:19 AM
    Crom
    Nick
    San Diego, CA
    Millions
    Thread bump. Anyone have anything else to add?
  13. Jun 15, 2011 at 11:25 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I thought the axle nut was a 35 like the 1st Gens didn't know that one i guess the 2nd Gens wheelin with me better bring a 36mm because I'm not buying one :D
  14. Jun 15, 2011 at 11:29 AM
    Hunter500ky
    Hunter500ky Well-Known Member
    E-Town Ky
    06 Tacoma 4x4 SR5
    Weathertech Mats, Toolbox, 6k HID fogs, Hardwire Escort 8500 x50,
  15. Jun 15, 2011 at 11:31 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Axle nut on the 05+ trucks is 35mm.
    Someone posted the wrong information somewhere early on and it's been perpetuated ever since.
    SR-71A likes this.
  16. Jun 15, 2011 at 11:34 AM
    JLee
    Jerry
    Benicia, CA
    LOL that's what I thought :)
  17. Jun 15, 2011 at 11:35 AM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    :popcorn:
    I have a basic generic set but it would be cool to put together a set of everything needed to do anything, as well as spare bolts and shit
    TacoYes likes this.
  18. Jun 15, 2011 at 11:35 AM
    Crom
    Nick
    San Diego, CA
    Millions
    Great! It's been corrected. :)
  19. Jun 15, 2011 at 1:34 PM
    mjp2
    NJ
    bobboberson likes this.
  20. Jun 15, 2011 at 1:41 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    10mm will take out the driver side dash also
